nichky
bgp vpls signaling over rr?
Fri Feb 28, 2025 8:53 am
does bgp vpls signaling work over route-reflector ?
loloski
Long time Member
Long time Member
Re: bgp vpls signaling over rr?
Tue Jun 10, 2025 4:16 pm
If your PE router is v7 you can use v6 router as route reflector and BGP VPLS signaling will work in v7 just test it in v7.19.1 and it works! I don't know when MT will gonna fix this in v7
