+1 to vpnv6 over IPv4.We are still waiting for VPNv6 support over IPv4 infrastructure.Did anyone configure VPNv6 successfully to work?
That freed extra 80kb, thanks.Try:
/console/clear-history
Turns out, it does.If is just netinstalled... already the history do not exist...
+1 6vpe, 6pe hope they listen+1 to vpnv6 over IPv4.
Yep! I agree!Are you referring to MPLS L3 VPN RFC 4364, a generic IPv6 VPN RFC 4213, or tunneling methods like those in RFC 2473 or 2784/2890?
If you’re talking about MPLS, there are plenty of other mainstream capabilities I’d prefer to see implemented as well like EVPN, SR, TE and OAM.
Interesting! Good to know! I'll try and keep an eye out for that too. I hadn't noticed those issues, but we also haven't done any big file transfers recently.I also perceive somewhat of improvement, but wifi "stalls" still happen a few times per day, especially when there is more traffic, for example when i push some heavy transfer from one laptop to another across wifi there is more chances of happening
I'm not sure what the difference might be. I reported an issue with iOS devices in particular struggling with the beta, and beta6 improved the situation immensely--to the point that they no longer seem spurious. IOW, my hAP ax2 has been handling the situation better since upgrading to beta6.
.. I am able to venture that perhaps MikroTik will have to think about different Software and Firmware (Routerboard) for the same hardware for different applications. ... If the fight to split the main software package is already big, imagine thinking about multiple flavors of firmware? It's going to be CHAOS.
It's a dangerous slippery slope thoughI have been saying for years that the only valid solution following the current MK market strategy (ROSE, Home Market) is to create a "RouterOS HomeEdition" for the "hAP" series of Routerboards with only the "basic" functions + wifi + storage (DLNA, SMB) full of simple wizards for example the creation of a wifi mesh (capsman home edition?). This would allow to streamline the devices with 16MB of flash on which it will always be possible to install the classic professional version of ROS. As for ROSE, for me a dedicated environment should be created from scratch using open source projects and various collaborations dedicated exclusively to the storage environment.
I'm aware of that, but why to put more and more bells&whistles on the tree if they do not fit on branches?ROSE is already a separate package, so nothing to worry about.
What we need is removal of other functions from the base package so it again fits in a 16MB flash device. That is totally unrelated to ROSE.
https://mikrotik.com/product/wap_lr8g_kitThe problem is that MK released, I don't remember which model of RB, a short time ago still with 16 MB flash so the first is not a viable path..
yeah, some weeks ago i received a CRS-309 with 32mb of storageI think Mikrotik already realized that 16MB is a little tight. There are refreshes of existing device like Chateau LTE12 (2025) now with 32MB flash. There are other devices in the pipeline, see viewtopic.php?t=213245#p1131190, now with 32MB flash as well. Good to see Chateau 5G R15 has now 32MB. Where the 5G R16 only had 16MB (like the original Chateau 5G). I like the funny fact, people will think R16 is better/newer than R15. But it is the other way round.
Interesting, this is not indicated on the product page (yet?).
That been my thought too. But if true... do some package split & put 2 x 16MB in device - market it as "redundant flash", given folks already worry about flash failures. i.e. make lemonaid from lemons.The only explanation I can come up with is that they’re sitting on some massive warehouse full of 16MB chips they’re desperately trying to offload...
You never know... Here people sued (yes, SUED) my ISP. Because it was selling 500Mbps and delivering 1Gbps. I kid You not - they had to put traffic shaping, by court order! Why? WHY?......Nobody (except you ;-) ) complains about getting more than expected and paid for (I never complained due to getting 256MB RAM version of hAP ac2).
Did you just tell people to not use routing functions on an L3-Switch? What?without MPLS and routing functions, and baking routeros-diet.npk later (for switches)
I believe that anything small enough that precludes me to use partitions, is too little. Really. Yes, do backups. Yes, do both an export and a binary dump. Yes, save both on your desktop, update winbox and netinstall - don't forget to download the right image too.I don't think that 16MB of storage on LMP 5G is that critical. Since it hasn't got wifi, ROS installation is imediatelly around 2.5MB slimmer. And with "only" 256MB RAM iz's also not prime candidate for running containers ... I hope.
I agree with that.I believe that anything small enough that precludes me to use partitions, is too little. Really.
Yes, that's just logical. Why they aren't doing this is beyond me.As RouterOS now allows a RAMdisk to be configured by the user, it could instead use a RAMdisk that is already configured, or dynamically configure a temporary RAMdisk, for the download and upgrade.
I updated my hAP ax2 from 7.16.2 to 7.19beta6 and while things seem to work well, I noticed CPU load is averaging 50% while idle. According to /tool profile, this seems to be caused by the routing process. There is a BGP peer on this router but it's only taking in ~2000 routes and there aren't any updates to process, so I'm not sure why the load is so high.
Update: if I enable "bgp, debug" logging I see hundreds of "Output publish 10.1.1.0/30" lines per second (10.1.1.0/30 is a subnet of a connected ROSv6 device on which the BGP peer with this router isn't even enabled). Downgrade to 7.18.2 fixed the problem.
true.7.15.x was the last version where BGP worked OK
That's not new, is it? I guess the real issue is that ROS 7 does not have a long-term release channel.MikroTik pushes a release to the 'stable' channel far too early, when it is often anything but stable.....
Is there a thread where I could read up on what is wrong with BGP? I just upgraded our 2216s to 7.18.2 and they seem to be running fine with full table Internet peering.7.15.x was the last version where BGP worked OK
They do kind of, on 16MB (and some other) devices upgrade packages are downloaded to RAM not disk...Yes, that's just logical. Why they aren't doing this is beyond me.As RouterOS now allows a RAMdisk to be configured by the user, it could instead use a RAMdisk that is already configured, or dynamically configure a temporary RAMdisk, for the download and upgrade.
Please read the posting again. What works for 16MB devices should work for all, but it does not.They do kind of, on 16MB (and some other) devices upgrade packages are downloaded to RAM not disk...
Wait until they are up for a day or two...Is there a thread where I could read up on what is wrong with BGP? I just upgraded our 2216s to 7.18.2 and they seem to be running fine with full table Internet peering.7.15.x was the last version where BGP worked OK
But could You do a quick heads up here? Just a little list of small bullet points, Mikrotik style? :DWait until they are up for a day or two...
The problem has been discussed in release topics.
If someone (preferably from Mikrotik) could take up this would be good which i know has been requested beforeBut could You do a quick heads up here? Just a little list of small bullet points, Mikrotik style? :DWait until they are up for a day or two...
The issue should be fixed in the next release.I updated my hAP ax2 from 7.16.2 to 7.19beta6 and while things seem to work well, I noticed CPU load is averaging 50% while idle. According to /tool profile, this seems to be caused by the routing process. There is a BGP peer on this router but it's only taking in ~2000 routes and there aren't any updates to process, so I'm not sure why the load is so high.
I've just noticed that I have the same issue on recent betas (in my case, an RB5009UG+S+), which has been ongoing for a few weeks. I also have BGP session (about 100 routes).
Rebooting doesn't solve it. Copied config over to secondary partition running 7.18.2 and switched to that, and now everything is fine again (< 10% CPU usage).
We don't insist to the IPv4-only backbone, we like IPv6, or we would like to :-)We are still waiting for VPNv6 support over IPv4 infrastructure.Did anyone configure VPNv6 successfully to work?
I have already done that in almost every release topic after 7.16 so no need to repeat it.But could You do a quick heads up here? Just a little list of small bullet points, Mikrotik style? :DWait until they are up for a day or two...
I did, and you said "it could instead use a RAMdisk that is already configured, or dynamically configure a temporary RAMdisk, for the download and upgrade." which is exactly what MT does...Please read the posting again. What works for 16MB devices should work for all, but it does not.They do kind of, on 16MB (and some other) devices upgrade packages are downloaded to RAM not disk...
No, that is not correct.I did, and you said "it could instead use a RAMdisk that is already configured, or dynamically configure a temporary RAMdisk, for the download and upgrade." which is exactly what MT does...
But they could respond like: "Hello Mr. Pe1chl, at the moment, we do not have any available resources to address these issues. We will get back to you as soon as we start working on them. Thank you."I have already done that in almost every release topic after 7.16 so no need to repeat it.
My support ticket was created July 2024 and has not received a reply after August 2024 despite several updates from me.
I fear there again is no available BGP developer at the moment.
That is likely against company policy...But they could respond like: "Hello Mr. Pe1chl, at the moment, we do not have any available resources to address these issues. We will get back to you as soon as we start working on them. Thank you."
The IT Crowd ;)But they could respond like: "Hello Mr. Pe1chl, at the moment, we do not have any available resources to address these issues. We will get back to you as soon as we start working on them. Thank you."
They can outsource programmer if they want. And they have responsible to their customer that already bought they hardwareI have already done that in almost every release topic after 7.16 so no need to repeat it.
Agreed, IPv6 route/forward/distribution using VPNv6 over IPv4 or SR are more efficient way for now and in the future when IPv6 implementation start rising massively, it will reduce memory/cpu requirement.We don't insist to the IPv4-only backbone, we like IPv6, or we would like to :-)
Sure, it would be appreciated to move from MPLS to SR, maybe it would be better for the vendor and for the end-users, or SRv6 if too hard to implement IPv6 route over IPv4 nexthop.
World moving tovards IPv6 and SR.
Are you calling us from 2010? Or is it an April fools joke?in the future when IPv6 implementation start rising massively
I updated 1xARM, 1xARM64, 1xMIPSBE.What's new in 7.19beta7 (2025-Mar-31 10:55):
OK... I need to agree that:Are you calling us from 2010? Or is it an April fools joke?
I was pushed too hard! Sounded like negating round earth.in the future when IPv6 implementation start rising massively
Excellent ... very nice to read !IWord is Mikrotik has recently brought on about 15 people ...
Beta7 still does not fix fast track for me on my CCR2116.
It works fine on 7.18.2 but the moment I try the beta my speeds drop from 1Gbps to 0.15Mbps. This is for IPv4 currently, disabling the HW offload on the fast track filter on the beta does fix the speed issues. The moment the HW offload is enabled, I get 0.15MbpsBeta7 still does not fix fast track for me on my CCR2116.
It apparently works for many other users (or else there would be a massive outrage going on). It works for me on 7.18 (and .1 and .2).
So it must be something in your particular config.
And I'm sure you're aware that fasttrack is only enabled by adding a particular IPv6 firewall filter, without it it's disabled (just like it's done in IPv4). And ROS upgrades never changes configuration (it might convert existing configuration to newer syntax, but doesn't add new items).
please don't scare me, I got 8 BGP connections and a AS on a CCR running 7.15 since July I think and just considering to update and saw this :P7.15.x was the last version where BGP worked OK
*) route-filter - fixed the "blackhole" option setting process;Set blackhole yes on routing filter broken on 7.19.beta6
Last known work 7.18.2
Reported SUP-183157 with supout from both version.
Thx
They not able to make stable VPn4 but you want ipv6 already.+1 to vpnv6 over IPv4.
That make sense, given they've long implemented the now ratified RFC-9759It might actually happen sooner than you'd expect. Word is Mikrotik has recently brought on about 15 people, supposedly working full-time on developing business-oriented features.
True word or gossip?It might actually happen sooner than you'd expect. Word is Mikrotik has recently brought on about 15 people, supposedly working full-time on developing business-oriented features.
what do you want to achieve?anyone have problem with bgp filtering for local as?
regexp ^$ or bgp-path-len < 1 did not works
Advertise any prefix originately from the router itself.what do you want to achieve?anyone have problem with bgp filtering for local as?
can you share the documentation link, google was not enough for me to find itAs is stated in the documentation, the check for locally originated routes is "if ( bgp-network )"
As I know, RouterOS 7 is based on Linux kernel, maybe a 5.6.3 version, with a lot of MTik specific patch. If I see the kernel source of version 5.6.3, IPv6 route over IPv4-mapped nexthop is supported:Deploying VPNv6 Over IPv4 LDPv4, on an environment of per-vrf label allocation seams to be really simple in the point RouterOS is now.
Seams that if they just rework a bit how the NLRI of MP-BGP is created for this scenario and they are good to go.
linux-5.6.3/net/ipv6/route.c @ line 3319
if (gwa_type != (IPV6_ADDR_LINKLOCAL | IPV6_ADDR_UNICAST)) {
/* IPv6 strictly inhibits using not link-local
* addresses as nexthop address.
* Otherwise, router will not able to send redirects.
* It is very good, but in some (rare!) circumstances
* (SIT, PtP, NBMA NOARP links) it is handy to allow
* some exceptions. --ANK
* We allow IPv4-mapped nexthops to support RFC4798-type
* addressing
if (!(gwa_type & (IPV6_ADDR_UNICAST | IPV6_ADDR_MAPPED))) {
NL_SET_ERR_MSG(extack, "Invalid gateway address");
goto out;
Hope the new MT guys will solved thisAs I know, RouterOS 7 is based on Linux kernel, maybe a 5.6.3 version, with a lot of MTik specific patch. If I see the kernel source of version 5.6.3, IPv6 route over IPv4-mapped nexthop is supported:Deploying VPNv6 Over IPv4 LDPv4, on an environment of per-vrf label allocation seams to be really simple in the point RouterOS is now.
Seams that if they just rework a bit how the NLRI of MP-BGP is created for this scenario and they are good to go.However, I don't know if this is enough to simply implement VPNv6 over LDPv4.Code: Select alllinux-5.6.3/net/ipv6/route.c @ line 3319 if (gwa_type != (IPV6_ADDR_LINKLOCAL | IPV6_ADDR_UNICAST)) { /* IPv6 strictly inhibits using not link-local * addresses as nexthop address. * Otherwise, router will not able to send redirects. * It is very good, but in some (rare!) circumstances * (SIT, PtP, NBMA NOARP links) it is handy to allow * some exceptions. --ANK * We allow IPv4-mapped nexthops to support RFC4798-type * addressing */ if (!(gwa_type & (IPV6_ADDR_UNICAST | IPV6_ADDR_MAPPED))) { NL_SET_ERR_MSG(extack, "Invalid gateway address"); goto out; }
LDP is bleeding from multiple wounds in RouterOS, so if SR is easier to implement even if SRv6, we would be happy as most of high-end vendors simply skipping LDPv6 from their codes, they prefer SR over LDP. You said right, SR seems as complex as simple it is.
https://help.mikrotik.com/docs/can you share the documentation link, google was not enough for me to find itAs is stated in the documentation, the check for locally originated routes is "if ( bgp-network )"
*) system - fixed "/system reboot" when the system disk is completely full;
What's up with that?
no idea how to check firmware. it was shown only in old 6.x routeros. also, no firmware for RB2011UiAS-RM on mikrotik website.Routerboard firmware (mostly) up-to-date? Does another reboot change anything?
no idea how to check firmware.Routerboard firmware (mostly) up-to-date? Does another reboot change anything?
/system/routerboard/print
Flash memory full?After upgrading old RB2011 to 7.19 beta7, can't upload anything any longer (e.g. can't upgrade to beta8). File list empty. Scripts that create backups fail.
The RB2011 has 128MB of flash so unless you have installed a lot of other packages or an extremely large adlist there should be many issues I would guess?Flash memory full?After upgrading old RB2011 to 7.19 beta7, can't upload anything any longer (e.g. can't upgrade to beta8). File list empty. Scripts that create backups fail.
How large are your partitions?I have ax3 and 2 partitions and dns adlist are configured. And I'm tired of deleting adlist to install the update.
Also, if you interrupt the download of the update, then it is impossible to restart it without rebooting the entire device due to lack of memory.
Disabling and setting a pause for adlist does not free up memory.
I would prefer to store the downloaded adlist data in ram memory.How large are your partitions?
have you checked the free storage space using the /system resource print command in the terminal?
Just returns routeros as firmware./system/routerboard/print
routerboard: yes
model: RB2011UiAS
serial-number: 77AD0866172B
firmware-type: ar9344
factory-firmware: 3.41
current-firmware: 7.19beta7
upgrade-firmware: 7.19beta7
My screenshot above shows plenty of memory.Flash memory full?
Absolutely nothing out of ordinary there. Default admin user and default full/read/write groups, that I never changed. All checkboxes are there.Check System -> Users: Is there any other user groups than full/read/write. Does the group full still have all checkboxes? Is your login still member of the full group? Is there any unrecognized usernames?
can confirm too. same for me.we tested 7.19beta7 and it is working fine about bgp on x86 and arm64!
thanks Mikrotik.
> /interface/veth
> add address=2001:db8:1:1:1:1:1:1/64 gateway="" gateway6=2001:db8::1 name=example
> :put [get example value-name=address]
2001:db8:1:1::/64
[admin@MikroTik] > /interface/veth/add address=2001:db8:1:1:1:1:1:1/64 gateway="" gateway6=2001:db8::1 name=example
[admin@MikroTik] /interface/veth> :put [get example value-name=address]
2001:db8:1:1::/64
[admin@MikroTik] /interface/veth> /system/resource/print
uptime: 2m2s
version: 7.19beta8 (testing)
build-time: 2025-04-04 10:24:19
factory-software: 7.1
free-memory: 57.5MiB
total-memory: 256.0MiB
cpu: QEMU
cpu-count: 1
cpu-frequency: 3192MHz
cpu-load: 1%
free-hdd-space: 70.4MiB
total-hdd-space: 89.2MiB
write-sect-since-reboot: 1600
write-sect-total: 1600
architecture-name: x86_64
board-name: CHR QEMU Standard PC (i440FX + PIIX, 1996)
platform: MikroTik
ros_version ticket_id title description status_code created_on will_be_fixed_on_version?
It was not said to make the ticket system public. This would not make any sense at all - as you said - many tickets may not even be bugs.It's company policy and I can't comment on that, but what I can tell you personally, is that we get hundreds of "bug reports" every day, and 99.99% of them are bad configuration or misunderstanding about something. If all these would be turned into bug reports directly, it would be utter chaos. It would be very nice if more people made some proper testing, steps to repeat, etc. as a normal bug tracker requires. This is not a DIY hacker software or github, there are millions of home users and basic level techs that are using these devices.
As I have said multiple times, this forum is a deep dark corner of geeks, amongst millions and millions of other people that have never seen this forum in their life, but are using mikrotik products.
So there is a bug tracker - a different system than the ticket system. I totally understand the "company policy" thing - the fear of "leaking" details to exploit issues. I would not suggest to make the bug tracker public either. But a curated list of issues with a description and to which version it applies would be great - other vendors do that (without risking to disclose critical data).This is an automated message. Our bug tracker reports that your issue has been fixed. This means that we plan to release a RouterOS update with this fix. Make sure to upgrade to the next release when it comes out. To be sure this specific fix is included, read the changelog when the next version comes out. If your issue is not mentioned, it might mean it will be in the next release.
Mikrotik support would even benefit from this. Now bugs get reported over and over again. Because nobody knows if it is already known to Mikrotik.When you file a bug with us you receive a number that you can share publicly and that other customers can use to look up the basic information on the bug
So do u think that your product already perfect?It's company policy and I can't comment on that, but what I can tell you personally, is that we get hundreds of "bug reports" every day, and 99.99% of them are bad configuration or misunderstanding about something. If all these would be turned into bug reports directly, it would be utter chaos. It would be very nice if more people made some proper testing, steps to repeat, etc. as a normal bug tracker requires. This is not a DIY hacker software or github, there are millions of home users and basic level techs that are using these devices.
Even if bugs are resolved, no one knows what they were as solutions are hidden in one-liners: "improved stability", "corrected behaviour", "better handling".Mikrotik support would even benefit from this. Now bugs get reported over and over again. Because nobody knows if it is already known to Mikrotik.
Or in JIRA allow the reporter to have some "mark public", so if you link to a issue (especially "feature request" type) in forum, it's be read-able (perhaps requiring some help.mikrotik.com login).Developers for Apple ecosystem have a thing called Open Radar (https://openradar.appspot.com/page/1 w) which has similar origin story.
By making better documentation, the MikroTik team would achieve this wish.It would be very nice if more people made some proper testing, steps to repeat, etc. as a normal bug tracker requires.
I completely agree with your statement.@felixka I have been arguing many times that this should be done at least for the release notes. Right now we get basic and cryptic statements about what has changed in a release, but we never see a complete description and an underlying bug report.
It is often difficult to guess what is really meant with "system - improved system stability when sending TCP data from the router" (an example picked from the release notes above) and it would be so much better when there would be a link to a more detailed description of what was changed or added....
Do you mean disable the HW offload on the internet facing port on the switch ? I have L3 HW offloading on on all ports and the switch1 cpu with v17.8.2, and speeds are fantastic, on the beta, even with L3 Hw Offloading disabled on SFP1 which has my XGSPON module for my WAN and a vlan on it in order to get internet access from my ISP, speeds drop to 0.10Mbps. Only if I do Switch -> Settings -> L3 Hw Offloading disable, do the speeds restore the full ISP speeds. So I need to fully disable it on the Beta, where are the stable release seems to have no issue (or doesn't work properly? ).If you're doing NAT, you need to disable the Internet-facing port. Presumably you've done that already for other versions.
Well, there is always something left to be desired....And to be clear, the MikroTik team has improved A LOT regarding documentation in recent times!
I don't know who, but someone deserves to be congratulated for this. Please give it to this person.
What I miss the most are the use cases!
Something that there was much better back in the wiki days.
It is irritating that you see it this way. A bunch of geeks. I visit the "active topics" section daily and what I see is: regular people seeking for help and solutions to their issues with Mikrotik products. That is I guess the primary purpose of this forum - people helping each other.As I have said multiple times, this forum is a deep dark corner of geeks, amongst millions and millions of other people that have never seen this forum in their life, but are using mikrotik products.
It's nice that you described what some of us actually want from you, MikroTik.[..] we get hundreds of "bug reports" every day, and 99.99% of them are bad configuration or misunderstanding about something. [...] It would be very nice if more people made some proper testing, steps to repeat, etc. as a normal bug tracker requires. [...]
...It would be very nice if more people made some proper testing, steps to repeat, etc. as a normal bug tracker requires.
What I miss the most are the use cases!...
He probably means that there are millions of users that use a MikroTik router as a plain home WiFi AP and NAT router, running with default config.It is irritating that you see it this way. A bunch of geeks. I visit the "active topics" section daily and what I see is: regular people seeking for help and solutions to their issues with Mikrotik products. That is I guess the primary purpose of this forum - people helping each other.As I have said multiple times, this forum is a deep dark corner of geeks, amongst millions and millions of other people that have never seen this forum in their life, but are using mikrotik products.
Also not exacly a public bug tracker, but at least they have this: https://arubanetworking.hpe.com/techdoc ... 12.0.5.htmCan anyone provide an example of another commercial networking vendor with a public bug tracker ?
https://vyos.dev/Can anyone provide an example of another commercial networking vendor with a public bug tracker ?
Mikrotiks backend for supportcases is Jira so would that really be that much of work in reality?Also not exacly a public bug tracker, but at least they have this: https://arubanetworking.hpe.com/techdoc ... 12.0.5.htmCan anyone provide an example of another commercial networking vendor with a public bug tracker ?
But for MikroTik to have even something like this requires work and manpower, and require the bugs filed via the current bug tracker to pass the initial "we couldn't reproduce" ping-pong replies that take some .. time.
Isn't vyos open source?https://vyos.dev/Can anyone provide an example of another commercial networking vendor with a public bug tracker ?
The list of issues should not only include the known issues but also the resolved issues. Then the list of open issues is (hopefully) relatively short compared to the total list.It's almost like MT is afraid to publish a super-long list of known issues and scare customers away. Well, at least give us a page of the top 20 or so of the most important issues, at your discretion.
"Opensource" and "commercial" aren't mutually exclusive.Isn't vyos open source?
So that's far from "commercial"
.Can anyone provide an example of another commercial networking vendor with a public bug tracker ?
Its an opensource project but with commercial licenses:Isn't vyos open source?
But - I can see systems like Aruba being pointed to in regards to support, which I would like to comment on. Thouse f*ckers created incompatible generations of wireless equipment / firmware in just maybe 2 years? We were told by the integrator, that we need to scrap the old ones, or move them to the secondary locations, if we want to run new ones.
I know, this is not that vendor's forum, but what kind of incompatibility? AireOS WLC can drive C9100 APs and vica versa, IOS-XE WLC can also drive 3800 APs. BTW if you want to throw 3800 APs out at all costs, tell us where to look. Save the planet from unnecessary littering ;)That's not unusual. Cisco do the same. The incompatibility between 3800 series and 9100 series meant we had to retire hundreds of 3800. Apparently related to roaming between the WiFi 5 series 3800 and WiFi 6 series 9100.
That's what v7.19.1, v7.19.2 and 7.19.x is forNo, please don't rush v7.19. Instead, prioritize stability for everyone’s sake. @merkkg, if you have a business case, request access to v7.20 for internal testing.
YEEEESSS!!!@Mikrotik time for v7.19 to to go RC, then release so we can get v7.20 out the door.
I will keep pushing for fast releases until I see the key features I need for my business
- VRF L3HW Offload
- MPLS Multi Threaded and/or MPLS L3HW Offloaded
I still have tickets open since October, November last year.... contacting support is pointless, by the time i get a response v7.23 will be outIf it is really urgent, contact support and ask for a custom patch.
100% agree with you and hope these are being actively worked on.@Mikrotik time for v7.19 to to go RC, then release so we can get v7.20 out the door.
- VRF L3HW Offload
It makes absolutely bugger all difference. We've been 'pushing' for things like Segment Routing for well over a decade and gotten absolutely nowhere. MikroTik does its own thing, often spending an eternity and barely improve any of the core routing functionalityIts great to have more people pushing Mikrotik for these features!
To be fair to Mikrotik, they have redeveloped the routing engine from the ground up in that timeframe. But in theory they have a nice new clean code base to work with, they should be able to implement new features like SRv6/SR-MPLS and fix bugs much more quickly, but so far the only major feature addition we have seen has been ISIS support.It makes absolutely bugger all difference. We've been 'pushing' for things like Segment Routing for well over a decade and gotten absolutely nowhere. MikroTik does its own thing, often spending an eternity and barely improve any of the core routing functionality
loloski, you mean this April's fool joke?It might actually happen sooner than you'd expect. Word is Mikrotik has recently brought on about 15 people, supposedly working full-time on developing business-oriented features.
There is no need to turn all of them ticket numbers into bugID, but if some of them is misunderstanding, then you could improve your documentation if/where it needed, maybe asking the reporter what should be in the documentation to get it more understandable. For misconfiguration the same. Unfortunately the lack of knowledge is in the game many times. In our company there is a layered customer service with 4 layer. There are 50-100 "soldiers" in the front line, and we are on the end of the layers in a little office, like a cone. 10-15 years ago I have been on the front, respectable job!we get hundreds of "bug reports" every day, and 99.99% of them are bad configuration or misunderstanding about something. If all these would be turned into bug reports directly, it would be utter chaos.
RouterOS has made fun of me many times. I successfully reproduce a bug 3 times and filed a ticket and of course it didn't work that way the 4th time.But I guess the 99% of cases is not this. I feel sometimes the frustration caused by support jammers when a MT support staff response to my email and asks totally basic info which is in my original email. All my respect to you!It would be very nice if more people made some proper testing, steps to repeat, etc. as a normal bug tracker requires.
#on 7.18.2 the logs for peer not responding was:
wg-vpn: [<peer-name>] <public-key>: Handshake for peer did not complete after 5 seconds, retrying (try 2)
#on 7.19betaX is now:
wg-vpn: Handshake for peer did not complete after 5 seconds, retrying (try 2)
Well, I admit that I have been guilty myself of submitting a ticket in one or two cases where I had been pulling my hair for days about a problem which I did not see, but which finally turned out to be a typo in an IP address or similar, which I had overseen all the time and which the support person saw immediately.There is no need to turn all of them ticket numbers into bugID, but if some of them is misunderstanding, then you could improve your documentation if/where it needed, maybe asking the reporter what should be in the documentation to get it more understandable. For misconfiguration the same. Unfortunately the lack of knowledge is in the game many times. In our company there is a layered customer service with 4 layer. There are 50-100 "soldiers" in the front line, and we are on the end of the layers in a little office, like a cone. 10-15 years ago I have been on the front, respectable job!
This or that, they are already human like us, but as I imagine it, they rather be a jungle fighter, whom fighting with the jungle with machete.However, there also are the cases that are certainly not a config issue, are reported by several people on the forum, but still are being ignored (both on the forum and in tickets).
I can sympathize with it, sometimes there are issues that a developer would rather not admit or he knows it will be a lot of work to find and fix it, but as a "victim" it remains irritating to have them...
Not so fast, first there will be a release candidate.i got feeling that the stable version will come very very so0n
Do you mean disable the HW offload on the internet facing port on the switch ?If you're doing NAT, you need to disable the Internet-facing port. Presumably you've done that already for other versions.
Sounds like you are asking for a Cisco Bug Tracker from Mikrotik. Let's start with the fact that Mikrotik doesn't have TAC to maintain such a database. Who is going to maintain it? Developers?Perhaps if we did get a bug tracker, it would be best as a split community and developer effort. If MikroTik support receive multiple reports, it gets escalated and it is a CONFIRMED bug then it gets assigned an ID number with public visibility. This would indeed cut down on support tickets for the same issue over and over
At the same time the community could submit a bug but it sits in an unconfirmed/pending state until curated and voted on by a sufficient number of community members to confirm its an issue
All bugs should have version tracking capability with a similar voting process so we could see i.e. 'memory leak in XYZ process' has been marked as fixed by MikroTik in version 7.21.3 however the community has voted it is still present, thus it re-opens. MikroTik acknowledges and marks it as fixed in 7.22. Some months/years down the track the problem arises again and the community looks it up, finds the problem and marks it again as a problem in 7.31. So we can blatantly see that its fine between 7.22 and 7.31 and if that is a major problem for you, don't use a firmware that has the problem
This should be somewhat curated and not open to any and all comments to cut down on the noise. Members need to register with MikroTik and keep information short and to the point. MikroTik themselves could benefit from having more precise information and see what bugs are actively looked at and voted on by users. And users could benefit from having some transparency and direct to-the-point information on bugs without having to submit a support ticket 'to the void', completely oblivious to whether or not anyone else is having the same problem, and not just hoping and praying by trawling through all the changelogs only to find "improved stability" with zero tangible information beyond that
I said split responsibility. The community can largely be the ones that maintain it but as mentioned things can be curated, and that can be done by the community as well. Not everything that gets submitted is listed as confirmed, it would take X number of people/votes to list it as such. Devs and community members both can provide input in a streamlined fashion - not random forum posts - ergo if 1 dude with some extraordinary obscure configuration posts a bug report, and nobody else can replicate it, then it never proceeds into a confirmed bug and it'll disappear into the void. If it's a well written bug report by a community member that outlines steps to reproduce the issue and community members can replicate and acknowledge the issue, then the community can vote and get it pushed into a confirmed state. Community members themselves can help clean up and curate said list, which devs would benefit from by having strictly confirmed bugs and not have to piece together often half assed information from support ticketsSounds like you are asking for a Cisco Bug Tracker from Mikrotik. Let's start with the fact that Mikrotik doesn't have TAC to maintain such a database. Who is going to maintain it? Developers?
That's not always how things work. Companies that have been doing things a certain way for a long time often get stuck in a "this is how we do things" mode, and suffer from "Not Invented Here" syndrome. The recent back-and-forth with the community over changes in device-mode is a great example of MikroTik not doing a lot of (the right kind of) research ahead of the decision-making process. It takes a good set of leaders in the C-suite to be introspective and re-evaluating processes and comparing "the way we've always done it" to alternatives. (It usually centers around resources; if you're stretched thin, you tend to spend as little on retooling as possible.)If Mikrotik saw value in this it would have already done something in that direction, so I don't think you could count on their support for this effort.
Well when the release mgmt discussions start to overwhelming the "testing" thread... the "process" is that beta becomes a rc ;).this will be for sure going in circles for eternity
Dont hope too.much as they said, 99% problems caused by miss configuration.Not so fast, first there will be a release candidate.i got feeling that the stable version will come very very so0n
FTR: MPLS offload support is not in all Marvell switch chips, only in carrier ethernet optimized series like 98DX73xx.@MT if you truly start the development of EVPN + VXLAN could you please update the routing protocol overview page and include RFC 7432 to make it official and for our peace of mind :) roadmap pleaseeeee heheeheheh
Agree! But VRF hardware off load (the base for L3VPN in MPLS, SR-MPLS SRv6 and VXLan Type 5 Route) are present in all the chips chosen by MT over the last 10 years.FTR: MPLS offload support is not in all Marvell switch chips, only in carrier ethernet optimized series like 98DX73xx.
As far as I know "VRF Lite" is not a VRF L3VPN, VRFLite is a locally and logically separated routing table on a given L3 device. The MPLS overlay, the routing decision based on MPLS label stack would also has to be programmed in the HW for wire-speed. Without that the box is only a software router with very limited forwarding capacity (max 1-2 Gbps/CPUcore). MPLS Fast-Path is existing on P type routers, but that is not always wire-speed and could eats up control-plane too. What you did mention is egde functions which are the most expensive.Agree! But VRF hardware off load (the base for L3VPN in MPLS, SR-MPLS SRv6 and VXLan Type 5 Route) are present in all the chips chosen by MT over the last 10 years.
If they start with hardware off-load of simple VRF-Lite (technique of 30-40 years) ... The control plane will come easy later for all the protocols.
the problem also happen in 7.19.beta8,SUP-185949, reported CCR1072 v7.18.2 setup as PE with vpls and L3-VPN4 inside, having random rebooted by proper shutdown.
if you find any miss configuration at least you can reply which configuration that caused it.
this router running well in v6 and just upgraded last weeks and already having 2 random rebooted.
thx
Where did you find this info? The L3HW docs has different information:The fact that simply activating a VRF for Out-of-Band Management by dedicating an interface, this DISABLES the Hardware offload of THE ENTIRE BOX is a DISGRACE.
Yes, it will. I have opened a case to this issue, and they confirmed they missed the arm32 architecture fix first time (in 7.18).Hello,
Will the cipher problem (AES-*-GCM) concerning the OpenVPN server on RB4011iGS+ routers be solved in version 7.19?
viewtopic.php?t=214028
I hope, MikroTik Team will backport this fix to a near future 7.18.3 release also.
I have a CCR2116 on 10gbps service, and my Switch -> Settings -> L3 Hw Offloading setting is enabled. I get full speeds--on speedtests, IPv4 traffic barely registers 1-3% on a few cores, and IPv6 30-50% on a few cores.Do you mean disable the HW offload on the internet facing port on the switch ? I have L3 HW offloading on on all ports and the switch1 cpu with v17.8.2, and speeds are fantastic, on the beta, even with L3 Hw Offloading disabled on SFP1 which has my XGSPON module for my WAN and a vlan on it in order to get internet access from my ISP, speeds drop to 0.10Mbps. Only if I do Switch -> Settings -> L3 Hw Offloading disable, do the speeds restore the full ISP speeds. So I need to fully disable it on the Beta, where are the stable release seems to have no issue (or doesn't work properly? ).
I think much more priority have to be done to fix mpls ldp adv filters. Yes i will prefer BGP LU . but to be realistic i am already reconstructed network so for me it is not critical anymore . I see a lot of requests here about mpls hw offload. but for me it is bit strange to hear about it. i have a network with more than 5 hundreds CPEs and there are much more problems with LDP adv filters and OSPF limitations because routing table full of loopbacks which not possible to aggregate than with offload.VRF-LITE is the basis for any other L3VPN implementation that may exist.
If the routes for each VRF are going to be entered via LDP, OSPF, or static routes??? We are talking about Control-Plane.
And none of these protocols will matter if when doing VRF the hardware offload is not supported.
So yes, activating VRF without breaking the hardware offload should be a priority!
You are talking about CCR2116 that is brute-force on CPU, right? How many of those? 20? 30?I using CCR2116 and basically not hit yet limitation to require offload but i started to worry about it can you please tell me your case where you hit issue with hw offload ?
What is considered by "much more problems with LDP filters"? There are currently no known problems or reported problems with LDP filters.there are much more problems with LDP adv filters
Certainly going into the details of MPLS configurations for a specific environment is much more OFF-Topic than even I like to go.Can you please tell me how you found workaround to solve or avoid issue with ldp adv filters in ros 7?
SUP-186238.
Millions and millions of customers for MikroTik.........? Perhaps over XYX period of time...... I would look at your year over year growth, or lack of [With current direction of hardware and software]. Or are you contributing the "millions of customers" to 1:1 of hardware sales. Most of the hardware sold is through vendors and resellers; MikroTik doesnt sell direct to consumer - so how can you say this?It's company policy and I can't comment on that, but what I can tell you personally, is that we get hundreds of "bug reports" every day, and 99.99% of them are bad configuration or misunderstanding about something. If all these would be turned into bug reports directly, it would be utter chaos. It would be very nice if more people made some proper testing, steps to repeat, etc. as a normal bug tracker requires. This is not a DIY hacker software or github, there are millions of home users and basic level techs that are using these devices.
I will do it with pleasure...While you make good points, this thread is not place for these discussions.Please keep this forum topic strictly related to this particular RouterOS release.
I concur with you on this and your points. I feel MikroTik is too busy managing their Discord channel and taking feedback & suggestions from consumers, rather than professionals.I will do it with pleasure...While you make good points, this thread is not place for these discussions.
As soon as there are specific places where the MikroTik team really interacts as actively as here on new releases.And all this being done without lies or half-truths, and without wordplay and generic phrases like "improved stability" or "issue fixed", without additional details.
- A place for official roadmap.
- A place for known bugs.
Wrong topic but if you're running wifi-qcom-ac check the last benefit here:Can anyone explain why hAP ac3 is transmitting VHT parameters on 2.4GHz ?
Reminds me of this:But this is not part of the standard, some clients might still not like it? No way to turn it off?
management-protection=disabled
That is quite common, also with other manufacturers. WPA3 requires management protection, but even setting it to optional (to allow a WPA2/WPA3 transitional setup) breaks some clients.I didn't enable WPA3 this time and did setNow the naughty clients behave, it wasn't related to what I've said above. I'll move them to another SSID in the future.Code: Select allmanagement-protection=disabled
In most cases, WPA2+WPA3 is enabled. How do you suggest to be in such a case?2. If WPA3 is set WMP, = required, and can't be set to allow because it's mandatory for WPA3.
That's case nr. 2. from above, if WPA3 is one of the chosen auth types, no matter what others you choose, you have no say over WMP, it gets set to Required if you leave it unset, but if you force it to Allowed or Disabled the wireless interface will not go up due to misconfiguration (it will say so in the logs too).In most cases, WPA2+WPA3 is enabled. How do you suggest to be in such a case?2. If WPA3 is set WMP, = required, and can't be set to allow because it's mandatory for WPA3.
Especially old and IoT clients have trouble with that.
*) wifi - add information on CAP uptime and connection uptime in "Remote CAP" list;
*) wifi - added "eap-identity" to registration table;
Unfortunately, the fact that it is "inconvenient" will not make it go away.However, such “division” of WiFi network by authentication type into several subnets is absolutely inconvenient for mass use. Explaining to users that their phones should be connected to one WiFi network and their laptops to another.... If their laptops don't normally want to work on the same network as their smartphones. With ioT devices it's easier - dedicate a separate WiFi network for it. Just like CCTV cameras.
I came to this conclusion a long time ago, even some old apple devices wont connect when FT is enabled. It's Infuriating actually and not as I envisaged my New Mikrotik WiFi 6 setup to be. Whats that saying... "You Can't Always Get What You Want, But if you try sometimes, well, you might find You get what you need"The problem is in the clients, and there is absolutely no way the AP manufacturer can solve them, the only workaround is to have different networks (SSIDs).
