tleifight
LoRaWAN Driver CSMA Support
Wed Mar 05, 2025 11:00 am
is the LoraWAN driver able to implement CSMA with the SX126x?
denissMT
Re: LoRaWAN Driver CSMA Support
Tue Mar 11, 2025 9:13 am
Hello!
Per the description, "CSMA" looks similar to our "Listen Before Talk" implementation.
Our LoRa gateways support LBT:
https://help.mikrotik.com/docs/spaces/R ... Properties
lbt-enabled (yes | no; Default: no) -> Whether gateway should use LBT (Listen Before Talk) protocol.
listen-time (integer [0us..4294967295us]; Default: 5000us) -> Time in microseconds to track RSSI before TX (used when lbt-enabled=yes).
rssi-threshold (integer [-32,768 .. 32,767]; Default: -65dB) -> RSSI value to determine whether forwarder may use specific channel to talk. If RSSI value is below rssi-threshold, channel could be used (used when lbt-enabled=yes).
____
In other words, the gateway will not send out anything if the channel is "reserved/used".
