Ihstewart
Newbie. Need help with PTPv2/VLAN configuration on CRS326
Tue Mar 11, 2025 7:37 pm
Hi. Getting a CRS326. Need to know if I can do this and some configuration assistance.
Background. I will be setting up the CRS326 as a switch (no routing). There will be two VLANs.
One of them will be 100% isolated. Meaning no communication to other vlans or the internet.
Let’s call these VLANs
Vlan 100 - general
Vlan 200 - radio
Vlan 100 will have internet and access to rest of building.
Vlan 200 is an isolated network for aoip only.
Here is the kicker. I need Vlan 200 to have a PTPv2 master on it provided by the CRS326. The clock should only be “seen” by Vlan 200.
This doable? Any tips?
elbob2002
Re: Newbie. Need help with PTPv2/VLAN configuration on CRS326
Wed Mar 12, 2025 1:12 am
loloski
Wed Mar 12, 2025 1:18 am
# Create Bridge
/interface/bridge/add name=bridge1
# Add port on the bridge assign ether1 as vlan 100 and ether2 as vlan 200
/interface/bridge/port/add pvid=100 interface=ether1 frame-types=admit-only-untagged-and-priority-tagged
/interface/bridge/port/add pvid=200 interface=ether2 frame-types=admit-only-untagged-and-priority-tagged
# Define vlan id = 100 and 200
/interface/bridge/vlan add vlan-ids=100 tagged=br1,untagged=ether1 bridge=bridge1
## from MT documentation
/system ptp add name=ptp1 profile=802.1as
/system ptp port add interface=ether2 ptp=ptp1
/interface bridge vlan add bridge=bridge1 vlan-ids=200 untagged=bridge1,ether2
# Activate Bridge Vlan Filtering
/interface/bridge/set vlan-filtering=yes
Ihstewart
Wed Mar 12, 2025 2:05 am
Thank you. I will get that tested.
