CinderBDT907
multi-WAN, one dst always through one WAN
Sun Mar 16, 2025 11:13 pm
I read and tried to modify and implement this solution, which is about source address.
But it isn't working, and I am not sure if it is because a different solution is needed when the restriction is to destination address instead.
I have two WAN connections, which is working well. Only one of the WAN connections has a static IP from the ISP. In order to connect to the destination, I have to be listed in the firewall in front of the destination, so I want to always use the static IP WAN when I send traffic to that destination.
The traffic does not seem to be going out the static IP WAN, because it is not hitting the firewall in front of the destination.
Thank you for any suggestion.
Here are what I think are relevant lines in config:
#RouterOS 7.19beta5
add comment="all LAN ports bridged" disabled=no interface=bridge list=LAN
add comment="dual WAN configuration" disabled=no interface=WAN_ether1 list=\
    WAN
add disabled=no interface=WAN_ether2 list=WAN
/routing table
add disabled=no fib name=to_WAN1
add disabled=no fib name=to_WAN2
add comment="For traffic that is only going out on static IP." \
    disabled=no fib name=useWAN1only
/ip firewall mangle
add action=accept chain=prerouting comment=\
    "https://www.youtube.com/watch\?v=GeuuNE3EPBA" dst-address=192.168.1.0/24 \
    in-interface=bridge
    "https://www.youtube.com/watch\?v=GeuuNE3EPBA" dst-address=192.168.2.0/24 \
    in-interface=bridge
add action=mark-connection chain=prerouting comment=\
    "https://www.youtube.com/watch\?v=GeuuNE3EPBA" connection-mark=no-mark \
    in-interface=WAN_ether1 new-connection-mark=WAN1_conn passthrough=yes
    in-interface=WAN_ether2 new-connection-mark=WAN2_conn passthrough=yes
    "https://www.youtube.com/watch\?v=GeuuNE3EPBA" !connection-bytes \
    !connection-limit connection-mark=no-mark !connection-nat-state \
    !connection-rate !connection-state !connection-type !content disabled=no \
    !dscp !dst-address !dst-address-list dst-address-type=!local !dst-limit \
    !dst-port !fragment !hotspot !icmp-options !in-bridge-port \
    !in-bridge-port-list in-interface=bridge !in-interface-list \
    !ingress-priority !ipsec-policy !ipv4-options !layer7-protocol !limit \
    log=no log-prefix="" new-connection-mark=WAN1_conn !nth !out-bridge-port \
    !out-bridge-port-list !out-interface !out-interface-list !packet-mark \
    !packet-size passthrough=yes per-connection-classifier=both-addresses:2/0 \
    !port !priority !protocol !psd !random !routing-mark !src-address \
    !src-address-list !src-address-type !src-mac-address !src-port !tcp-flags \
    !tcp-mss !time !tls-host !ttl
    log=no log-prefix="" new-connection-mark=WAN2_conn !nth !out-bridge-port \
    !packet-size passthrough=yes per-connection-classifier=both-addresses:2/1 \
add action=mark-routing chain=prerouting comment=\
    "https://www.youtube.com/watch\?v=GeuuNE3EPBA" connection-mark=WAN1_conn \
    in-interface=bridge new-routing-mark=to_WAN1 passthrough=yes
    "https://www.youtube.com/watch\?v=GeuuNE3EPBA" connection-mark=WAN2_conn \
    in-interface=bridge new-routing-mark=to_WAN2 passthrough=yes
add action=mark-routing chain=output comment=\
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
    192.168.1.1 pref-src="" routing-table=to_WAN1 scope=30 \
    suppress-hw-offload=no target-scope=10
    192.168.2.1 pref-src="" routing-table=to_WAN2 scope=30 \
add comment=\
    https://help.mikrotik.com/docs/display/ROS/Per+connection+classifier \
    distance=1 dst-address=0.0.0.0/0 gateway=192.168.1.1
add comment=\
    disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.1 \
    pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
add comment="to force traffic out static IP WAN1 https://forum.mikrotik.com/\
    viewtopic.php\?t=188388#p951507" disabled=no distance=1 dst-address=\
    206.81.93.160/32 gateway=WAN_ether1 routing-table=useWAN1only scope=30 \
/routing rule
add action=lookup-only-in-table comment="to send traffic bound for specific endpoint\
    only through static IP WAN https://forum.mikrotik.com/viewtopic.php\?\
    t=188388#p951507" disabled=no dst-address=198.51.100.1/32 table=\
    useWAN1only
anav
Re: multi-WAN, one dst always through one WAN
Mon Mar 17, 2025 12:11 am
Since you don't know the problem, why do you think you know the relevent parts of the config. :-)
Seems illogical.
In any case
/export file=anynameyouwish ( minus router serial number, any public WANIP information, keys, long dhcp leases etc.)
and for the love of god, dont use VERBOSE export!!!
Please draw a diagram to show the equipment involved here as your explanation is not making sense.
It would seem as though either you or the ISP has their own firewall device besides their modem and your MT
I just cannot figure if its between the two or on the far side the ISPs modem..........
Also, did you want the LAN users to access both WANS at the same time, so the full availability of your paid throughput is being used, with the exception of when traffic is headed to one destination IP.
or did you have in mind A primary WAN for all traffic and then a secondary as backup and the single destination should use the backup.
Also, you have a whole bunch of other mangles on the go.
Please detail why you have each mangle, what use case are they addressing.
CinderBDT907
Mon Mar 17, 2025 2:35 am
Seems illogical.
That's a good point. I post here the config and a diagram.
Thank you for looking over the situation.
You are correct. There is a device that is filtering packets in front of the far endpoint to allow only the connections with the static IP assigned by my ISP.
I have entered that into the diagram.
The setup works perfectly when I have the LTE modem unplugged (when there is only one functional route).
Yes. The traffic is supposed to go out 50/50 on the two WAN links, except for this traffic to the one particular remote endpoint, which should only go out WAN1.
Thank you; I will attempt to explain the mangles in a later reply.
# 2025-03-16 15:54:26 by RouterOS 7.19beta5
# software id = 8QA2-FE62
# model = RBD25G-5HPacQD2HPnD
add admin-mac=C4:AD:34:xx:xx:xx auto-mac=no comment="bridge all wlan ports" \
    name=bridge port-cost-mode=short
set [ find default-name=ether1 ] comment="fiber link" name=WAN_ether1
set [ find default-name=ether2 ] comment="hotspot router" name=WAN_ether2
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country="united states" \
    disabled=no mode=ap-bridge ssid=ourhouse wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac country="united states" \
/caps-man security
add authentication-types=wpa2-psk comment=defconf disable-pmkid=yes \
    encryption=aes-ccm group-encryption=aes-ccm name=capSec
/caps-man configuration
add channel.band=2ghz-b/g/n .control-channel-width=20mhz .extension-channel=\
    XX comment=defconf datapath.client-to-client-forwarding=yes \
    .local-forwarding=yes distance=indoors installation=indoor name=cfg-2ghz \
    security=capSec ssid=MikroTikxxxxxx-2
add channel.band=5ghz-a/n/ac .control-channel-width=20mhz .extension-channel=\
    XXXX comment=defconf datapath.client-to-client-forwarding=yes \
    .local-forwarding=yes distance=indoors installation=indoor name=\
    cfg-5ghz-ac security=capSec ssid=MikroTikxxxxxx-5
add channel.band=5ghz-a/n .control-channel-width=20mhz .extension-channel=XX \
    cfg-5ghz-an security=capSec ssid=MikroTikxxxxxx-5
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
add authentication-types=wpa2-psk comment=defconf disable-pmkid=yes mode=\
    dynamic-keys name=wpsSync supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan3 ] antenna-gain=4 band=5ghz-a/n/ac \
    channel-width=20/40mhz-XX country="united states" disabled=no mode=\
    ap-bridge security-profile=wpsSync ssid=SYNC-xxxxxx wireless-protocol=\
    802.11
add add-arp=yes address-pool=default-dhcp bootp-support=none interface=bridge \
    lease-time=2d name=defconf server-address=192.168.88.1
/ip smb users
/routing table
add comment="for traffic that is on static IP" disabled=no fib name=to_WAN1
add comment="for traffic that is going out LTE" disabled=no fib \
    name=to_WAN2
add comment=\
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add comment=defconf disabled=no interface=bridge
/caps-man provisioning
add action=create-dynamic-enabled comment=defconf hw-supported-modes=gn \
    master-configuration=cfg-2ghz name-format=prefix-identity name-prefix=\
    2ghz
add action=create-dynamic-enabled comment=defconf hw-supported-modes=ac \
    master-configuration=cfg-5ghz-ac name-format=prefix-identity name-prefix=\
    5ghz-ac
add action=create-dynamic-enabled comment=defconf hw-supported-modes=an \
    master-configuration=cfg-5ghz-an name-format=prefix-identity name-prefix=\
    5ghz-an
add bridge=bridge ingress-filtering=no interface=wlan2 internal-path-cost=10 \
    path-cost=10
add bridge=bridge ingress-filtering=no interface=wlan3 internal-path-cost=10 \
    path-cost=10
add bridge=bridge ingress-filtering=no interface=wlan1 internal-path-cost=10 \
    path-cost=10
set udp-timeout=10s
add comment="all LAN ports bridged" interface=bridge list=LAN
add comment="dual WAN configuration" interface=WAN_ether1 list=WAN
add interface=WAN_ether2 list=WAN
/interface ovpn-server server
add mac-address=FE:7E:CF:xx:xx:xx name=ovpn-server1
/interface wireless cap
set bridge=bridge caps-man-addresses=127.0.0.1 interfaces=wlan1,wlan2
    192.168.88.0
/ip dhcp-client
add add-default-route=no comment="fiber link" interface=WAN_ether1 \
    use-peer-dns=no use-peer-ntp=no
# Interface not active
add add-default-route=no comment="hotspot router" interface=WAN_ether2 \
add address=192.168.88.0/24 comment=defconf dns-server=\
    9.9.9.10,149.112.112.10 gateway=192.168.88.1
set allow-remote-requests=yes servers=9.9.9.10,149.112.112.10
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add address=159.148.147.204 disabled=yes name=upgrade.mikrotik.com type=A
add address=159.148.172.226 disabled=yes name=upgrade.mikrotik.com type=A
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack disa\
    bled because TTL rewrite conflicts https://forum.mikrotik.com/viewtopic.ph\
    p\?p=838949" connection-state=established,related disabled=yes \
    hw-offload=yes
    connection-state=invalid
/ip firewall mangle
    in-interface=bridge
    in-interface=bridge
    dst-address-type=!local in-interface=bridge new-connection-mark=WAN1_conn \
    dst-address-type=!local in-interface=bridge new-connection-mark=WAN2_conn \
add action=change-ttl chain=postrouting comment="https://forum.mikrotik.com/vi\
    ewtopic.php\?p=838949#p840621\r\
    \nhttps://wiki.mikrotik.com/wiki/Manual:Interface/LTE" new-ttl=set:64 \
    out-interface=WAN_ether2
add action=masquerade chain=srcnat out-interface=WAN_ether1 to-addresses=\
    206.81.93.71
add action=masquerade chain=srcnat out-interface=WAN_ether2
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip ipsec profile
add comment=\
add comment=\
    target-scope=10
/ip service
set ssh disabled=yes
set telnet disabled=yes
/ip smb shares
set [ find default=yes ] directory=/pub
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/routing rule
add action=lookup-only-in-table comment="to send traffic bound for endpoint only through static IP WAN link https://forum.mikrotik.com/viewtopic.php\?\
    useWAN1only
/system clock
set time-zone-autodetect=no time-zone-name=UTC
/system identity
set name=MyMikroTikAudience
/system leds settings
set all-leds-off=immediate
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set broadcast-addresses=192.168.88.1 enabled=yes
/system ntp client servers
add address=0.pool.ntp.org
add address=1.pool.ntp.org
add address=2.pool.ntp.org
add address=3.pool.ntp.org
/system package update
set channel=testing
/system watchdog
set automatic-supout=no watchdog-timer=no
/tool graphing interface
add allow-address=192.168.88.0/24 interface=WAN_ether1
add allow-address=192.168.88.0/24 interface=WAN_ether2
/tool graphing resource
/tool mac-server
/tool mac-server mac-winbox
CinderBDT907
Mon Mar 17, 2025 4:30 am
Here are some notes regarding the mangle rules:
Regarding the TTL rewrite for the LTE hotspot and fasttrack disable:
viewtopic.php?p=838949#p839136
viewtopic.php?p=838949#p840458
The prerouting chain mark connection mangles are from:
MikroTik Tutorial 36 - Load balancing and failover with multiple gateways (2 WAN Links) by TKSJa and the website http://tksja.com/load-balancing-over-multiple-gateways
https://help.mikrotik.com/docs/display/ ... classifier is about sending traffic out and in from the same endpoint to the same endpoint once one is picked, I believe.
