JazzMaster
NetINstall will not work
Wed Mar 19, 2025 5:46 am
I have a hardware issue that is driving me crazy. I have a Mikrotik CRS317-1G-16S+. It refuses to accept a NetInstall reinstall of any ROS File.
I can get NetInstall to start and the CRS is listed in the equipment list. The ros is shown below. As soon as I select the CRS the ROS file is removed. No mattrer what I do the same thing happens.
Help Please.
gigabyte091
Re: NetINstall will not work
Wed Mar 19, 2025 5:52 am
Are you trying to do Netinstall from the Windows or Linux machine ? This happened to me few times and there were two reasons, either I downloaded .npk file for the wrong architecture or there was special character in username.
spippan
Long time Member
Long time Member
Wed Mar 19, 2025 9:19 am
also always remember to set the client firewall (windows or linux) to allow netinstall to access the network correctly and just for sake keeping, if possible, only have you ethernet interface active on which the MT device is connected. i often have fallen to that pit in the past (:
mkx
Re: NetINstall will not work  [SOLVED]
Wed Mar 19, 2025 11:24 am
This sounds as mismatch in device architecture (the one reported by device to netinstall and the one of the npk file). CRS317-1G-16S+ is arm (the 32-bit one, not arm64).
JazzMaster
Thu Mar 20, 2025 2:06 pm
Thank you forthe information. I am going to try the ideas that you sugest. I will be backn here with the results today.
JazzMaster
Sat Mar 22, 2025 7:27 pm
I am sorry for the delay in my results. I had a medical issue that prevented me from answering.
MY RESULTS WERE ........SUCCESSFUL!
All that had to be done was to use the 32bit version of ROS on the fiber switch.
