sk0003
Mikrotik hAP LTE6 as a travel router setup?
Sat Mar 22, 2025 1:01 pm
I have a Mikrotik hAP LTE6 setup as a travel router and I power it via a power bank on the go.
I am not sure if something changed with the new updates but it seems I can no longer have a slave WiFi2 interface in AP mode while WiFi1 is the master in station mode and it connects to a WiFi network as a client, for example a hotel WiFi.
As soon as I enable the slave WiFi, the master disconnects and connects constantly and the slave also never comes up. If I disable the slave WiFi, master WiFi immediately connects to the WiFi network and I have internet via ethernet ports.
I could swear it was working before. Any ideas or advice if I am doing something wrong?
sk0003
Re: Mikrotik hAP LTE6 as a travel router setup?
Sat Mar 22, 2025 7:55 pm
Just discovered this must be a bug introduced in one of the later versions, this is happening in v7.18.2
Just rolled back to 7.15.2 and it works fine.
Reported to Mikrotik via support@mikrotik.com
xrlls
Sun Mar 23, 2025 12:33 pm
I had a similar issue on a L009UiGS-2HaxD where the Wi-Fi uplink was also flapping. I think it was on 7.17.something, but for me it went away with 7.18.
Anyway, a work around that helped me was to set channel.band manually:
/interface/wifi/set [find configuration.mode=station] channel.band=2ghz-n
The downside being that you need to know what the infrastructure is, in order to set it correctly.
xrlls
Sun Mar 23, 2025 1:17 pm
Coming to think of it, the device where I saw the issue is currently on 7.19beta6, so it might have been on 7.18 I had the issue as well. But if you feel adventurous, you can try 7.19beta :)
sk0003
Sun Mar 23, 2025 3:14 pm
Thanks for the input but for now I think I'll stay with 7.15.2 to avoid any issues with my upcoming travel until I receive positive confirmation the issue has been fixed.
By the way, do you know what happened to the Connect List function in WiFi?
xrlls
Sun Mar 23, 2025 6:17 pm
AFAIK connect-list is available on the wireless package for older devices, while when using the wifi packages it is not. It has been discussed earlier in other threads.
If/when this feature is brought to the wifi package, I’d love to hear about it <3
robmaltsystems
Forum Veteran
Forum Veteran
Sat Mar 29, 2025 2:24 pm
Nothing to do with this post but the hAP ax lite LTE6 powered off a power bank is just awesome. Can any other vendor's kit do this? AS long as it's not hammered, the power bank I've got can last nearly a day.
maigonis
Sun Mar 30, 2025 2:52 am
Yeah, I also use it whit powerbank. Whit 20000mAh capacity I also can use it about a day. Will depend on usage,and conditions. Also latest lte fixes, changes have improved stability.
sk0003
Sun Mar 30, 2025 4:42 am
I also use it with a power bank, no problems there. The problem is with connecting to a Wi-Fi as a client and then using that as a WAN. In the latest 7.18.2, the virtual Wi-Fi keeps causing the primary to disconnect as soon as enabled.
anav
Sun Mar 30, 2025 11:52 pm
More importantly can some one wifi expertise please help the OP. Geez!!
phascogale
Mon Mar 31, 2025 1:33 am
Well, no configuration has been posted, so not much to do but chat amongst ourselves.
I have a not-hAP (a map lite) running master and slave interfaces on 7.18, 7.18.2 as of yesterday, without a hitch, and had it also on an ax2 until I reconfigured it to 2.4 up 5 down a month ago.
@sk0003, please post your
export file=randomfilename
configuration. There is little anyone can do otherwise.
