hasan020
Showing Total Transferred or Total Download in Status Page?
Tue Mar 25, 2025 6:44 am
I'm using Hotspot with User Manager, configured with Radius.
Users have several plans, with limited Transfer amount of data.
I need to show them on "Status" page their limit, and usage till the moment.
I've tried many variables, but I'm not getting there yet.
User Manager: 6.49.18
Router: RB1100, OS: 6.49.18
Help is more than appreciated, and thanks in advance.
abbio90
Re: Showing Total Transferred or Total Download in Status Page?
Wed Mar 26, 2025 7:03 am
I follow the discussion, listen, but once the traffic is finished does a captive portal page appear? or is the user connected without navigation?
hasan020
Wed Mar 26, 2025 2:21 pm
He get logged out, and once he tries to log in again.. he gets a note about his data is fully consumed.
abbio90
Wed Mar 26, 2025 2:34 pm
possible to see your usermanager configuration? note which page would be usermanager or hotspot
hasan020
Thu Mar 27, 2025 2:49 am
What router model you are using? which OS version?
hasan020
Mon Mar 31, 2025 2:36 am
Any insights on how to read data from Raius?
Help is more than appreciated..
LawrencePatterson
Thu Apr 03, 2025 11:32 am
Sounds like a firmware issue or bad config. Try reverting to a stable ROS version and inspect NAT rules closely. Also, check if FastTrack is interfering with performance.
I also want answer to that.
Last edited by LawrencePatterson on Wed May 07, 2025 9:27 am, edited 2 times in total.
hasan020
Wed Apr 09, 2025 9:11 pm
We will find help, I'm pretty sure.
I google too much about it with no hope!
hasan020
Tue Apr 22, 2025 12:03 am
Any tips or hints, where I can get paid service for such thing?
TonyJr
Tue Apr 22, 2025 12:24 am
Hopefully this will help: https://help.mikrotik.com/docs/spaces/R ... tomisation
About ¼ to ¼ down it begins to describe variables that can be used on hotspot pages.
Tony
