vingjfg
IOT Lora traffic - show CRC?
Sun Mar 30, 2025 12:36 pm
Hi all,
In IOT Lora Traffic, there is an option (Configuration -> Traffic Options) to "Show CRC errors"
Regardless of that setting, the frames with CRC errors are displayed in IOT Lora -> Traffic
Router is a KNOT R running 7.18.2.
Has anyone else seen the same behvaior?
denissMT
Re: IOT Lora traffic - show CRC?
Mon Apr 07, 2025 5:05 pm
Thank you for bringing it to our attention.
It is bugged. Will be fixed!
Please follow our testing and development version changelog for the fix information:
https://mikrotik.com/download/changelogs
vingjfg
Tue Apr 08, 2025 7:47 pm
Ha! Thanks.
I wanted to make sure it wasn't something specific to my setup before opening a ticket, but you were faster.
Thank you and the devs at mikrotik for the hard work!
