Is hAP ac2 still being manufactured? I understand the hardware revision might have happened at some point in the past, so all your points are valid regardless. They don't publish any end-of-life dates or even product release dates. The hardware page on the main website only has the archived section. Does it mean anything not there is still actively produced? Surely they don't make the original hEx'es now that refresh model is here?
I can't say for sure, but in my experience, anything that isn't under "Archived" is still actively produced. Their hardware products tend to have a very long market life. Perhaps they figure that, since the assembly line is already up and running, and as long as the needed components are still available, and as long as people are still buying it, why not. I'm not sure if this factors into their decision-making at all, but since I'm sure they sell to a lot of businesses, there are many organizations that prefer to stick with a specific product for as long as possible after they have committed to using it for a certain task (perhaps for reasons of consistency, perhaps for internal bureaucratic reasons, etc.), and for whom it would be a hardship if they constantly had to up-end their processes every 6 months or whatever because that's the rate at which the products they settle on tend to get EOL'd.
Now that RouterOS and RouterBOOT versions are kept in sync, one way to kind-of gauge the relative age of a device is to see what RouterBOOT version was flashed to the board as the backup bootloader. I did a quick search around our network, and found a handful of 'r3' hAP ac2 units. One of them shows "factory-firmware" of 6.49.15. ROS 6.49.15 was released just under a year ago. So this particular ac2 is at most less than a year old!
It is also a bit interesting that they are? were? continuing to flash the latest 6.49.x release to these models at the factory, even though 7.x had been out for quite a while by that point. In fact, even though this "r3" unit apparently came pre-loaded with 6.49.15, the "factory-software" (not firmware) shows as 6.46.8. This tells us that not only can "r3" devices technically be downgraded that far and still work, but also that MT is allowing for downgrades that low to happen. This probably also gives us some idea of who is still buying these things: unlike some models that straddled the line between 6 and 7 and even initially shipped with 6 (AHEM *cough*CCR2004*cough*) but which eventually switched to being pre-loaded with 7 at the factory, these haven't been...presumably because if somebody is continuing to purchase new units of a product of this age, they potentially have both a use-case for and a desire to run older software on it. And I'm sure MT knows this. If somebody has an existing fleet of ac2s that they need to add more to, and they want to stick with ac2 to keep things consistent, they are probably also going to want to standardize on using the same software load across all of them as well. Very common in large corporate / enterprise settings.
For the record, the small handful of "r3" units I have found all appear to be the international version, just like yours is. While the vast majority of them that we have are the U.S./FCC one. (As an aside, I'm a bit surprised that it's not possible to tell them apart in software other than looking at the countries list on the wlan interfaces. The reported "model" is identical between both versions.) I'm not sure how this happened to us, quite frankly. Best guess is that either we ordered the wrong thing one time, or our distributor shipped us the wrong thing & nobody noticed until now. But also: what are the odds? Makes you wonder if maybe ac2 buyers these days are few and far between within the U.S., and perhaps most (or all) ac2 manufacturing still taking place is primarily to appease markets outside of ours?
