norocel
DHCP SERVER mikrotik 2.9.27
Sat Feb 09, 2008 11:11 pm
I need help
I have a 254 Ip-s 192.168.0.1/24
How can I configure a DHCP server with 32 subnets?
gmsmstr
Trainer
Trainer
Re: DHCP SERVER mikrotik 2.9.27
Sun Feb 10, 2008 2:23 am
Nope, can't do that with one DHCP server ...
Dennis Burgess, MCTCE, MTCNA, MCTCTE, MTCWE, MTCNIE, A+, N+, MCP, MTCSE Mikrotik Certified Consultant / Trainer
Need Mikrotik Support: http://www.linktechs.net -- Link Technologies, Inc.
-- Author of "Learn RouterOS: Second Edition"
aldalil
Sun Feb 10, 2008 7:20 am
I need help
All network users connected to the same NIC ?
If you have grouping rules and all the 254 users are on the same network, then how you are going to assign them with no physical grouping!
You have to divide your networks to multi DHCP servers .. but 32 subnets !!! what do you need that for ? only 6 hosts for each subnet ?
Well .. if it is not important to assign a specific subnet for specific group, then you can configure your router with multi DHCP servers.
Internet Via Satellite services & VSAT Data communication: http://www.InternetVSAT.com
Cobranded VoIP solutions for resellers and service providers: http://www.CrestCall.com
norocel
Sun Feb 10, 2008 10:19 pm
how i can setup multidhcp server ?
10x in advance
aldalil
Mon Feb 11, 2008 3:56 am
Use the command below every time you want to add a DHCP server to the same ROS:
/ip dhcp-server setup
You can configure it the way you want, use same Interface, different interfaces Or use multiple ROS if you have multiple networks.
Users browsing this forum: matiss, quackyo, txfz, yonesmit and 80 guests
