What's new in v3.42:
*) added support for the Files menu in future RouterOS versions;
*) added some widget features for future RouterOS versions;
*) fixed crash when dragging the "#" column by disabling its movement;
*) fixed date fields to support year up to 2106;
*) terminal: ignore legacy shift-out (SO) character;
If you experience version related issues, then please report them to support@mikrotik.com.
Both Winbox 32-bit and 64-bit versions are available here:
https://www.mikrotik.com/download
