In this case comment can be used to identify such scheduler, or simply adjust code in scheduler when renaming it. When changing something one must be aware on what some change is affecting.
- I know that a final line can be added that remove the schedule, but what if the schedule name is changed later before execution?
The last thing that helps OP's cause is cross-posting, which is not allowed on the forum.And it can be related to this viewtopic.php?t=217111![]()
