[ISP Modem connected to Mikrotik Router]
For the MT router, ether1 is WAN. ether2 and ether3 form a bridge. The remaining ports are unused.
[ether2] 192.168.86.0/24
This interface connects to ASUS ROG router where devices are accessing internet via WiFi.
[ether3] 192.168.88.0/24
This interface is where main desktop PC is situated at, together with a simple mikrotik RB260GS switch.
I use the switch as a plug-and-play and no further configuration is made on the switch and it simply works.
Desktop PC and Synology NAS are connected to switch and back to ether3.
I have been trying to configure my NAS and setting things up but I encountered a few problems:
1. I have issue with NAT Hairpin
I have set up DDNS on my Synology NAS successfully, with a wildcard certificate.
Using the domain name, it can resolve to my ISP public IP address assigned to my MT router.
From my mobile line, I could access my Synology DSM Login Portal page after setting up DNAT on MT router.
But when i try to access it from my desktop PC via the domain name, the connection was refused.
I then read that for local users to access an internal resource using external domain name, NAT hairpin needs to be setup.
I tried setting it up but it didn't work.
2. Wireguard connected but not able to access the apps
I wanted to setup Wireguard so that me and my family members could just connect via Wireguard to use the Synology applications.
Right now, we are connecting back via QuickConnect. While it works, it might not be the most ideal in terms of security.
I setup Wireguard client on my android mobile and added wireguard interface and wireguard peer on my MT router.
The Wireguard tunnel seem to be established successfully. I checked my mobile phone and it was assigned the IP address for the Wireguard subnet.
To allow wireguard connected peer to access the NAS resources, I added a firewall rule to allow that.
However, I was not able to connect. From the logging, i was able to see the SYN packets but the connection failed.
I even tried disabling firewall on Synology NAS and it didn't work as well.
I am out of ideas of what could be the issue and I need some guidance.
Please have a look at the configuration export below.
Code: Select all
# 2025-06-01 17:08:04 by RouterOS 7.15.3
# software id = 7YZP-38T4
# model = C53UiG+5HPaxD2HPaxD
# serial number = <removed>
add admin-mac=<removed> auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether2 ] comment="TV Port"
set [ find default-name=ether3 ] comment="Study Room Port"
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
configuration.country=Singapore .mode=ap .ssid=MikroTik-62F531 disabled=\
no security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=\
yes
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
yes
/interface wireguard
add listen-port=18281 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
/interface wireguard peers
add allowed-address=192.168.100.7/32 comment=GPix7 interface=wireguard1 name=\
GPix7 public-key="<removed>"
192.168.88.0
add address=192.168.86.1/24 comment=asus interface=bridge network=\
192.168.86.0
add address=192.168.100.1 comment="IP of Wireguard Interface" interface=\
wireguard1 network=192.168.100.0
/ip dhcp-client
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="For wireguard" dst-port=18281 \
protocol=udp
established,related,untracked
invalid
in-interface-list=!LAN
add action=accept chain=forward comment="Wireguard To NAS" dst-address=\
192.168.88.250 in-interface=wireguard1 log=yes out-interface-list=LAN
add action=accept chain=forward comment="From Asus ROG WiFi LAN to NAS" \
dst-address=192.168.88.250 src-address=192.168.86.0/24
add action=accept chain=forward comment="To Asus ROG mgmt" dst-address=\
192.168.86.1 dst-address-type="" layer7-protocol="" src-address=\
192.168.88.0/24 src-address-type=""
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat comment="DNAT Port Forwarding to NAS HTTP" \
dst-port=80 in-interface=ether1 protocol=tcp to-addresses=192.168.88.250 \
to-ports=80
add action=dst-nat chain=dstnat comment="DNAT Port Forwarding to NAS HTTPS" \
dst-port=443 in-interface=ether1 protocol=tcp to-addresses=192.168.88.250 \
to-ports=443
add action=dst-nat chain=dstnat comment="DNAT Port Forwarding to NAS PORTAL" \
dst-port=18888 in-interface=ether1 protocol=tcp to-addresses=\
192.168.88.250 to-ports=5001
add action=masquerade chain=srcnat dst-address=192.168.88.250 out-interface=\
bridge protocol=tcp src-address=192.168.88.0/24
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Asia/Singapore
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-dst-ip-address=192.168.88.250/32 filter-operator-between-entries=\
and filter-port=5001
