Long story short, I have set up an L2TP/IPSEC server on my router using my Linux PC as a client. While I'm connected to my home network using Winbox through my VPN I can see my list of neighbours, however when I'm connected to another network with my VPN on I can access the internet fine but Winbox loads no neighbours.
Here's the instructional I followed https://youtu.be/FZpJGFaoFmk?si=Kxg71nqRFuyfuIFt
I have disabled all but ssh & winbox under services.
Below are a couple of screenshots which prove the VPN tunnel is working and the VPN config on my PC.
I've included the PPP config below and I'm picking my problem might be related to the PPP profile where it says "set *FFFFFFFE", this doesn't seem normal? How would I fix this?
I'm hoping someone can help me sort out the final piece of the puzzle. Cheers.
EDIT: I can confirm that I get different public IP addresses using https://whatismyipaddress.com/ when connecting from a cafe WiFi, VPN on and then off. So, further confirmation the tunnel is working, but not enough for Winbox 3 or 4 to display my router in neighbours.
Code: Select all
[itechadmin@Home Router AX] > ppp/export
# 2025-06-04 16:30:10 by RouterOS 7.19.1
# software id = xxxx-xxxx
# model = C52iG-5HaxD2HaxD
# serial number = xxxxx
/ppp profile
set *FFFFFFFE use-encryption=default
/ppp secret
add local-address=10.10.30.1 name=vpn profile=default-encryption remote-address=10.10.30.2 \
service=l2tp
