i'm trying to open dude db exported from two different router on 7.16, but unfortunately when i try to using sqlite3, it returns that this file is not a database.
I want to open it since in the past i made some shrinking and cleaning of DB thanks to guide posted which tells that deleting historical data will reduce the size of DB.
I have also some problem regarding dude, when i remove a dependencies, it crashes.
Thanks a lot for your support.
