I see that port forwarding on the Mikrotik is part of the NAT configuration. Currently I have my ZTE modem doing NAT because I cannot whatever I try get bridge mode to work. So the ZTE is my gateway router, I have a couple of static routes and no double-NAT and it basically works fine. My ISP is not helpful in getting bridge most to work or replacing the ISP modem with my own GPON.
Now I want to add port forwarding rules to the Mikrotik to expose some ports to the outside world (I cannot do this entirely on the ZTE either as it will only port-forward onto what it thinks its local LAN is and all my machines are on internal VLANs with different IP ranges). Can I add port forwarding rules to the routerboard without it also being the primary NAT device for the network or does port forwarding expect/require that the WAN connection is fully NATed by the routerboard?
