jarekbachanek
I Get logged out from Winbox and lose connection whenever I try to browse websites or download things
Sat Jun 07, 2025 2:29 am
So I managed to setup the mikrotik, antenna, I get the signal, connection is working fine. I still need to setup antenna in best direction to get best signal possible but it's working at least. Or so I thought.
When I setup antena and plugged everything in I noticed I get logged out for no reason. It went on like this for about 10 minutes logging in & out, then suddenly everything was working. I spend about 10 hours using it and testing speed until night. Then issue started showing up again.
I noticed when I open site, play stream, do anything, like download, it leads to logging out from Winbox and losing the connection for about 30 seconds to few minutes when its working again. But I also noticed that if I'm not doing anything, it's working just fine. Weirdly enough when I use discord it work's fine too. I can even watch streams on youtube as long its from discord. But when I use youtube on browser I get logged out.
Here is config:
# 2025-06-07 01:11:20 by RouterOS 7.19.1
# software id = C8IQ-9CKJ
# model = LHGGM
# serial number =
/interface lte
set [ find default-name=lte1 ] allow-roaming=yes band=1,3,7,8,20,38 \
    network-mode=lte
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] ip-type=ipv4 name="Play Internet" use-network-apn=no
add name=default-dhcp ranges=192.168.188.10-192.168.188.254
add address-pool=default-dhcp interface=ether1 name=defconf
/port
set 0 name=serial0
/queue type
add fq-codel-ecn=no kind=fq-codel name=fq-codel-ethernet-default
/queue interface
set ether1 queue=fq-codel-ethernet-default
add comment=defconf interface=ether1 list=LAN
add comment=defconf interface=lte1 list=WAN
/interface ovpn-server server
add mac-address=FE:92:AF:02:E1:70 name=ovpn-server1
add address=192.168.188.1/24 comment=defconf interface=ether1 network=\
    192.168.188.0
add address=192.168.188.0/24 comment=defconf dns-server=192.168.188.1 \
    gateway=192.168.188.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.188.1 comment=defconf name=router.lan type=A
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Warsaw
/tool mac-server
/tool mac-server mac-winbox
Any ideas?
McGremlin
Re: I Get logged out from Winbox and lose connection whenever I try to browse websites or download things
Mon Jun 09, 2025 2:22 pm
Hello.
What do you mean by "lose connection"? Only to your router via Winbox or the whole internet?
Maybe Mikrotik logs something at that time which could be usefull?
EDIT: And "where are you"? Directly connected to ether1 or there's a switch there and you are "behind" that switch?
