SWISSSNOW
Starlink - >1 Antenna
Sun Jun 08, 2025 1:25 pm
Hello!
We've been working with Starlink for some time and have gained some experience with the hardware and software since generation 1.
I have these questions for the community:
1) If you use more than one Starlink antenna, do you use the internal IP assignment or do you work with bypass mode?
2) If you assign an IP address directly to the router from the 100.64.0.0/10 network, do you use these IP addresses for the same (!) default gateway with suitable source-based routing? Is this working for you? Who uses which routing configuration?
3) Starlink routers can now also offer private IP addresses locally to 192.168.1.0/24 or 192.168.4.0/24. Routing to up to four different default gateways is easy to use from the Mikrotik router. Does anyone use it this way? Is that practical? Double Routing NAT problems?
4) Do you also use L2 tunnels via various Starlink antennas to a point (e.g., a data center) through which you then assign fixed IP addresses? Have you ever replicated the path and tunnel aggregation of "Peplink" with Mikrotik?
I would be happy to hear about all of these points...
