commerce9659
Looking to add a guest vlan and iot vlan to my network setup which also requires vlan40 tagging for internet access
Sun Jun 08, 2025 9:53 pm
I have a Mikrotik hap ac3 router running routeros 7.19.1
I want to add an IoT vlan that would not be able to access my main trusted devices network, except for perhaps a raspberry pi or docker instance running on my NAS. I also want a seperate guest vlan which would only have internet access and no access to devices on my main network. How would i go about confguring this?
Here is my config file:
add admin-mac=[sanitized] auto-mac=no comment=defconf name=bridge port-cost-mode=short
/interface wifi
set [ find default-name=wifi1 ] configuration.country=Canada .hide-ssid=no .manager="(unknown)" .mode=ap .ssid=[sanitized] disabled=no \
    security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] configuration.country=Canada .mode=ap .ssid=[sanitized] disabled=no security.authentication-types=\
    wpa2-psk,wpa3-psk
add configuration.hide-ssid=yes .mode=ap .ssid=[sanitized]-work mac-address=[sanitized] master-interface=wifi2 name=wifi3 \
/interface vlan
add interface=wifi3 name=guest_vlan10 vlan-id=10
add interface=ether1 name=vlan40 vlan-id=40
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=dhcp_pool1 ranges=192.168.2.16
add name=dhcp_pool2 ranges=10.0.1.2-10.0.1.254
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
add address-pool=dhcp_pool2 interface=guest_vlan10 name=guestdhcp
/ip smb users
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan40 max-mru=1500 max-mtu=1500 name=pppoe-out1 profile=default-encryption user=\
    [sanitized]
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=wifi1 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=wifi2 internal-path-cost=10 path-cost=10
set udp-timeout=10s
/ipv6 settings
add comment="configured for [sanitized] which requires vlan 40 tag for internet" interface=vlan40 list=WAN
/interface ovpn-server server
add auth=sha1,md5 mac-address=[sanitized] name=ovpn-server1
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=10.10.10.1/24 interface=guest_vlan10 network=10.10.10.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1 use-peer-dns=no
/ip dhcp-server lease
add address=192.168.88.232 client-id=[sanitized] mac-address=[sanitized] server=defconf
add address=192.168.88.207 client-id=[sanitized] mac-address=[sanitized] server=defconf
add address=192.168.88.233 comment="sony bravia" mac-address=[sanitized] server=defconf
add address=10.10.10.0/24 gateway=10.10.10.1
set allow-remote-requests=yes servers=1.1.1.1
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new \
    in-interface-list=WAN
/ip ipsec profile
/ip smb shares
set [ find default=yes ] directory=/pub
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
set time-zone-name=America/Toronto
/system leds
set 0 interface=*1 leds=led1,led2,led3,led4,led5 type=wireless-signal-strength
set 1 leds=poe-led type=poe-out
/tool graphing interface
add
/tool mac-server
/tool mac-server mac-winbox
erlinden
Re: Looking to add a guest vlan and iot vlan to my network setup which also requires vlan40 tagging for internet access
Sun Jun 08, 2025 11:18 pm
In the beginning there was...the Bible of VLAN:
viewtopic.php?t=143620
anav
Mon Jun 09, 2025 1:29 am
One bridge, no dchp by bridge, if you have a house subnet, simply use a vlan for that as well. Do not use vlan-id=1
Now for best of luck and trouble free its best to take one port off the bridge and do all the configuration from there ( the last step being turning bridge vlan filtering on ).
How to:
Notes:
1. FIRST STEP add Offbridge settings, and do all vlan configuration from this safe spot. ( using port 9). Recommend this for all devices.....
2. added Management Interface List entity
3 Removed duplicate IP Pool
4. Assume 3 vlans, one is management vlan (all devices get IP address on this vlan) / Trusted VLAN (like home users) / Guest or IOT Vlan
5. Since RB4011 has two groupings of ports, put the first five ports together same bridge, moved WAN port to 6.
6. Normally for PPPOE one does NOT use ip dhcp client OR an ip address for WAN.
7. Changed ppoe peer dns server to NO. Reason it appears you want users to go via 1.1.1.1 and not ISP..
STEP1:
To work on vlans as it can get sticky when applying vlans or trying to change from default to your steup, its best to do so from a safe spot. Saves much grief!
So use an off bridge port for the configuration and also as an emerg access port on the device at any time..... or revert back to normal bridge port for any specific purpose using vlans.
Associated config entries ( remove ETHER5 from the bridge in /interface bridge port settings) :
set [ find default-name=ether5] name=OffBridge5
add address=192.168.77.1/30 interface=OffBridge5 network=192.168.77.0 comment="Offbridge and Emerg access"
add interface=OffBridge5=MGMT ( if you have a separate base or management vlan }
add interface=OffBridge5 list=LAN
Note: to access the router simply plug your device into port 5 and configure your PC/laptop with IPV4 settings of 192.168.77.2 and via username and password you should have access.
