JamesTUIAT
How connect to a Bridgged modem with a Hex ?
Sun Jun 08, 2025 10:21 pm
I can pass my ISP modem in a Bridgged mode, to do so I have to enter the MAC of the interface that is connected to the ISP modem.
/interface print
So far no problem, but when I do so, I loss the connect to the `WWW` The ISP do not explain more.. I suppose I have to use a PPPoE client ?
is the Hex are capable of such ?
Thanks.
erlinden
Re: How connect to a Bridgged modem with a Hex ?
Sun Jun 08, 2025 11:17 pm
What ISP do you have? Not any information on their site about running a modem in bridge mode?
In regards to PPPoE:
https://help.mikrotik.com/docs/spaces/R ... PPoEClient
JamesTUIAT
Mon Jun 09, 2025 7:49 am
Thank you @erlinden
no, I didn't find any info... I will write them today, but I have little hope..
My ISP is MoblieViking that actually use the Proximus infrastructure and end user hardware...
Thanks for the link , I'll check that.
sebastia
Mon Jun 09, 2025 7:39 pm
Have you tried their help ?
https://support.mobilevikings.be/hc/en- ... ridge-mode
Clearly stated: ppp needed (for bbox3)
you should probably copy your current ppp config before switching
might also be relevant: https://support.mobilevikings.be/hc/en- ... p-using-it
JamesTUIAT
Tue Jun 10, 2025 3:21 pm
Thank you @Sebastia !
I did a search in their help, but no result returned, but I guess It was a technical problem at the time.. they use a lot of external library to run their website...
So I've checked the two link you found ( again thanks )
So for the configuration of the PPPoE they seem to not give a lot of details... :/
But indeed on the post regarding the fritzboz they say ~"You can request the credentials by contact us"
So i'll try to reach them... (finger cross)
