markwien
how can i get routes learned from a bgp peer to a file
Mon Jun 09, 2025 11:36 am
hi
how can i do ipv6/route/print where gateway=2001:7f8:XXXXXXXXXXX
and extract the learned prefixes to a file to compare?
i have a rootserver peering flapping and need to find out what peers are flapping over the rootserver so i can disable them ...
mrz
Re: how can i get routes learned from a bgp peer to a file
Mon Jun 09, 2025 11:44 am
use "file" parameter
markwien
Mon Jun 09, 2025 12:02 pm
/ipv6/route/print where gateway=2001:xxxx file=gw6939-routes
dosnt work it shows the data in print ...
i also tried
ssh admin@router '/routing/route/print detail without-paging where protocol=bgp and afi=ip6 and gateway=2001:7f8:XXX output=json' > ipv6_routes.json
ok this works:
/ipv6/route> print file=test.txt where gateway=2001:7f8:3XXXXX
but wired thing in the gateway of the routeserver it shows no output - when i test with other peers it gives output ....
i can see routes on rootserver peers ...
gateway of rootserver is pingable and reachable.
