As a follow-up, I’d like to report that my second RB5009 unit is showing the same issue as the first: visible moisture spots on the casing after just 9 days of minimal use.
Here are the relevant conditions:
The unit was placed freestanding on my desk, in a well-ventilated room at a constant 24°C.
No PoE was used, and it wasn’t connected to any other devices except occasionally my PC via Ethernet to capture configuration screenshots.
It was powered using the official 48V 2A MikroTik power adapter.
The unit remained idle most of the time, with no significant load or heat generation.
Given that this is the second device showing signs of internal condensation or leakage, I suspect a possible manufacturing defect – potentially a leaking capacitor or another component causing internal moisture accumulation.
My reseller has been informed again. I am now reaching out here to ask:
Has anyone else encountered similar symptoms with the RB5009?
Is there any known issue with a recent hardware batch?
Would MikroTik be willing to investigate this more closely?
I can provide photos and serial numbers of both affected units upon request.
Thanks in advance for any input or assistance.
Best regards,
