r2rs
about SXT LTE6 kit and LMT eSIM
Tue Jun 10, 2025 3:23 pm
Has anyone managed to get an LMT eSIM working on the MikroTik SXT LTE6 kit?
ortazebra
Re: about SXT LTE6 kit and LMT eSIM
Tue Jun 10, 2025 4:07 pm
You can buy 9esim adapter.
r2rs
Tue Jun 10, 2025 4:19 pm
Will the eSIM not work without this adapter?
Amm0
Tue Jun 10, 2025 4:47 pm
No. You need some "hardware" to enable eSIM. The older devices do not have the need things on the "motherboard" or modem module, so only choice is to use a special physical/hard SIM card that will allow RouterOS eSIM commands to work.
If you're not planing on switching carriers, you can just a physical SIM from LMT - this avoid needing any special "physical eSIM" like the 9esim SIM card – but you're going to need SOME SIM card installed for the modem to work.
There is longer discussion about this topic here:
viewtopic.php?t=217140
