MUM Europe 2020
tjohnson
Wireless Linktest
Thu Feb 14, 2008 7:21 pm
I have a suggestion for a feature that would be very helpful with wireless networks. I would like to see a "linktest" option available when you right-click on a wireless entry in the registration table. This option would send 100 packets (1600 byte size) to and from the connected radio, 10 times. It would then report the following information:
Distance (based on time calculation)
Error rate from AP to client (shown in %)
Error rate from client to AP (shown in %)
Calculated throughput based on the results
Here is an example of another wireless radio that does this exact thing:
[pkt len] 1600 bytes [# of pkts per cycle] 100 [cycle] 10
0 [AP Tx] 100 [AP Rx] 95 [AP RxErr] 0 [SU Tx] 100 [SU Rx] 100 [SU RxErr] 0 500 ms 4992 Kbps
1 [AP Tx] 100 [AP Rx] 96 [AP RxErr] 0 [SU Tx] 100 [SU Rx] 100 [SU RxErr] 0 501 ms 5007 Kbps
2 [AP Tx] 100 [AP Rx] 95 [AP RxErr] 0 [SU Tx] 100 [SU Rx] 98 [SU RxErr] 0 501 ms 4982 Kbps
3 [AP Tx] 100 [AP Rx] 98 [AP RxErr] 0 [SU Tx] 100 [SU Rx] 100 [SU RxErr] 0 500 ms 5068 Kbps
4 [AP Tx] 100 [AP Rx] 95 [AP RxErr] 0 [SU Tx] 100 [SU Rx] 99 [SU RxErr] 0 501 ms 4982 Kbps
5 [AP Tx] 100 [AP Rx] 97 [AP RxErr] 0 [SU Tx] 100 [SU Rx] 100 [SU RxErr] 0 500 ms 5043 Kbps
6 [AP Tx] 100 [AP Rx] 96 [AP RxErr] 0 [SU Tx] 100 [SU Rx] 100 [SU RxErr] 0 501 ms 5007 Kbps
7 [AP Tx] 100 [AP Rx] 95 [AP RxErr] 0 [SU Tx] 100 [SU Rx] 100 [SU RxErr] 0 500 ms 4992 Kbps
8 [AP Tx] 100 [AP Rx] 97 [AP RxErr] 0 [SU Tx] 100 [SU Rx] 100 [SU RxErr] 0 501 ms 5033 Kbps
9 [AP Tx] 100 [AP Rx] 94 [AP RxErr] 0 [SU Tx] 100 [SU Rx] 99 [SU RxErr] 0 500 ms 4966 Kbps
[AP Total nTx] 1000 pkts
[AP Total nRx] 958 pkts
[AP Total nRxErr] 0 pkts
[SU Total nTx] 1000 pkts
[SU Total nRx] 996 pkts
[SU Total nRxErr] 0 pkts
[AP to SU Error Rate] 0.40 %
[SU to AP Error Rate] 4.20 %
[Avg of Throughput] 5007 Kbps
Thanks.
Travis
jordantrx
Long time Member
Long time Member
Re: Wireless Linktest
Thu Feb 14, 2008 8:10 pm
Thanks.
I like it also. But can it be done!!! :?
~Agricultural WISP "ZONE"~ Beware of oncoming cattle and dont hit the farmer!!! I need to ask him about using his silo for an AP first"~
*Automated Billing Installer* http://wiki.mikrotik.com/wiki/AutomatedBilling Built by Krige ;-)
Equis
Forum Veteran
Forum Veteran
Fri Feb 15, 2008 1:41 am
That is a great Idea!
shoffmann
Sat Feb 16, 2008 8:35 am
I think that this would be a tremendous help to our installers cutting down on truck rolls to diagnose problems that should have been seen at the time of install.
I can't see why it would be a problem to get done. We just need to get the attention of the right person.
While it would probably be more efficient to have this tool embedded in the code I'm sure someone out there could write a script that would accomplish it also.
stephenpatrick
Forum Veteran
Forum Veteran
Sat Feb 16, 2008 1:33 pm
Excellent idea, however it's implemented (code or script), hope this makes it into the real world
CableFree - Wireless Excellence - Microwave, E-band Radios, Free Space Optics, High performance Radios & Routers
http://www.cablefree.net
normis
Mon Feb 18, 2008 2:00 pm
so your idea is to get the link quality for non mikrotik clients in an easy right-click kind of way? for mikrotik clients the CCQ is the best way to get accurate link quality info. we will think about this, thanks for the suggestion
kevin@safelink.net
Sat Mar 08, 2008 1:53 am
We would love to see this option as well. We use these same tools in another vendors radio as well.
Normis, the problem with CCQ though is that if you don't have much data crossing the link then it will give you an inaccurate value. Sure we could setup and use the bandwidth test but we would have to take extra time to do that as well as watch the CCQ value as it is running the bandwidth test. Giving us a linktest utility would make it easy to test the quality of that link quickly and accurately.
Another option in that vendors radio is an ability to do a quick test (20 packets) to each radio to help us assess the health of the entire tower. If we have only two people out of thirty having problems then more than likely it's not a problem with the AP or any equipment at the tower.
-Kevin
tjohnson
Sun Mar 09, 2008 2:17 am
Normis,
The linktest feature could be for only MT to MT wireless links, if this would make it easier? The problem with CCQ is it does not give you any real information. We have links that have 80/80 CCQ readings that are working fine and we also have links with 25/25 CCQ readings that are working fine. This CCQ number (in a percentage value??) does not really tell you anything.
Even if it would be possible to have a "packet loss" reading (in percentage) listed right below the CCQ value?
There has to be some way to make it easy to test a client's link without getting into their radio and running tests from there. I need to be able to do everything directly from the AP side... and many other radio companies are doing this exact thing (and have been for 5+ years).
Travis
jp
Long time Member
Long time Member
Sun Mar 09, 2008 4:12 am
The trango linktest is indeed handy. I would be fine with it working with just MT-MT radio links. It's a one-step test that makes troubleshooting much easier and tells a lot about a link.
jordantrx
Long time Member
Long time Member
Sun Mar 09, 2008 4:03 pm
i agree, However not everyone usues MK to MK, so this would be also great if you could do it to other units other than MK... I use airbridge and tranzeo for CPE's and it would be nice to use this tool even with them. -Jordan
Users browsing this forum: septads and 21 guests
