foffa
there is must be a solution (arp spoofers)
Tue Mar 04, 2008 1:41 pm
hi all
programs like mac spoofing and others driving all network admins crazy i am sure
normally spoofing are blocked by hotspot when enabling mac login
by default if mac spoofing is active the customer logged out throw http and try to loging using mac
and will fail now it is done
BUT NETCUT
it use bad arp reply
and how to block programs like that ?!!!!???!!!!!
i have tried to use the local lan as reply arp only > no success
tried to block icmp also no success
may be disabling scanners work also not
may be blocking mac discovery will work but HOW
this is the urgent question ideas people
hulk-bd
Re: there is must be a solution (arp spoofers)
Tue Mar 04, 2008 2:16 pm
This problem making me just crazy as hell from few days. What to do? arp reply only not working also. :(
Help us out.
ayufan
Tue Mar 04, 2008 2:25 pm
Block forwarding between users on this same network.
hAP AC, TP-Link Archer C7 v2, RB951G, RB450G, RPI2, RPI zero
hulk-bd
Tue Mar 04, 2008 2:57 pm
Dear ayufan,
Can you please explain it briefly, I mean any example.
Don't worry, be happy :) .......
normis
Tue Mar 04, 2008 3:15 pm
use a smart switch with this function, also maybe VLAN?
foffa
Sat Mar 08, 2008 8:01 pm
exampels please
i like the idea about blocking forwarding inside lan between users
exampels plz
navibaghdad
Sun Mar 09, 2008 3:25 am
any example for disable forwarding between users ??? I ask for that in another topic before 6 month but no one give me any solution for disabling forwarding between user
abab_rafiq
Sun Mar 09, 2008 1:35 pm
Dangerous situation can happened from 8v8.biz which use ARP spoofing. For all kinds of network engineer, system admin please read out to block 8v8.biz
http://www.aub5thcse.com/forum/viewtopic.php?t=322
Rafiq...
raktim
Sun Mar 16, 2008 5:41 am
when i realised someone is using my ip:XXXXXXX . then i static the ip from ARP list & made the lan to reply only. But i really shocked :( he is still using this ip. he has changed his mac address to same as mine. maybe by using MAC scanner & changer software. Any one have any idea to save from this Culprit???
Thnxs,
raktim
yancho
Sun Mar 16, 2008 1:37 pm
In Ethernet network (wired network using switches) all users are in the same physical layer and using Media Access Control is is hard (almost impossible) to make hierarchy - who is main router and who client. There is no security.
As normis mentioned before way to disable forwarding between Ethernet users is manageable switch.
There is many articles about arp spoofing how to detect and prevent it, like http://www.watchguard.com/infocenter/ed ... 135324.asp
ahmedsaffar76
Mon Apr 14, 2008 8:08 pm
hi ;
i in this moment add a new rule to the forward chain to check if it will stop netcut program ?
add action=jump chain=forward comment="" disabled=no dst-address-list=local-addr in-interface=bridge1 \
    jump-target=drop out-interface=bridge1 src-address-list=local-addr
i am using bridge1 to connect the users to the internet and i define the local-addr for my lan network ip .
so in this rule i am dropping any thing is initiated from local-addr and coming from bridge1 and going to local-addr through bridge1 .
comments on this rule will be welcomed .
also pppoe solve the case of netcut but i faced problems with the pppoe , where the clients face stop in the service from time to time and they have to disconnect the connection and reconnect again .
with best regards .
fatonk
Mon Apr 14, 2008 11:00 pm
PPPoE Implementation has solved these kind of issues in our network.
Regards.
Faton
alternativi_boy
Mon Apr 14, 2008 11:05 pm
fatonk if you can add me in last reply that i wrote...With Respect alternativi
fatonk
Mon Apr 14, 2008 11:14 pm
to alternativi: fatonkurteshi@yahoo.com
ahmedsaffar76
Tue Apr 15, 2008 1:41 am
Hi again ;
i am currently using the following firewall rules but the counters still zero , i don't know if they are wrong or no one trying to do bad things to the network .
Normis , please explain how the VLAN solve this case ? .
add action=jump chain=input comment="" disabled=no dst-address-type=local \
    in-interface=bridge1 jump-target=drop src-address=192.168.190.0/24 \
    src-address-list=local-addr src-address-type=broadcast
add action=jump chain=forward comment="" disabled=no dst-address-type=local \
    in-interface=bridge1 jump-target=drop out-interface=bridge1 \
    src-address=192.168.190.0/24 src-address-list=local-addr \
with best regards .
Users browsing this forum: Google [Bot], Uddterri and 151 guests
