MUM Europe 2020
kolorasta
Max. Cache Size: none
Thu Mar 06, 2008 5:42 am
i have a RouterOS v3.x with a Celeron 2Ghz with 1GB RAM & 3GB IDE HD for system & 40GB IDE HD for web-cache.
i use a transparent web proxy
i set Max. Cache Size = unlimited OR Max. Cache Size = 25000000 (for example)
then i close winbox, open it again and Max. Cache Size is automatically setted to none
why this happens? what does Max. Cache Size = none means?
sorry for poor english
gmsmstr
Trainer
Trainer
Re: Max. Cache Size: none (tell me why tell me why tell me why)
Thu Mar 06, 2008 6:37 am
Did you check cache on disk?
Dennis Burgess, MCTCE, MTCNA, MCTCTE, MTCWE, MTCNIE, A+, N+, MCP, MTCSE Mikrotik Certified Consultant / Trainer
Need Mikrotik Support: http://www.linktechs.net -- Link Technologies, Inc.
-- Author of "Learn RouterOS: Second Edition"
sergejs
Fri Mar 07, 2008 3:55 pm
Are you able to reproduce the same issue at 3.4 version ?
kolorasta
Sun Mar 09, 2008 10:16 pm
yes.. it's checked
kolorasta
Sun Mar 09, 2008 10:22 pm
yes... look these are some screenshots... i replaced the hd. i used to have a 80gb ide hd, but suddenly webcache stopped working (i put this hd in another pc with windows and tested it and it works fine)... now i have a 40gb ide hd. the webcache seems to be working but Max. Cache Size is still auto setted to none.
screenshots follows
any ideas?
sergejs
Mon Mar 10, 2008 9:29 am
What did you change before cache-size was configured to values (like unlimited) and you get cache-size=none ?
Did you change hard-drive ?
kolorasta
Mon Mar 10, 2008 3:39 pm
either i set Max. Cache Size: to a value or to unlimmited, then it's automatically setted to none. i changed hd, and it happens the same. but "i think" the webcache is still working. see screenshots.
another strange thing is that when i installed a 80gb hd it was formatted to 30gb. then i installed a 40gb hd and it was formatted to 30gb too. is it normal?
LatinSuD
Tue Mar 11, 2008 12:29 pm
Have you tried stopping (disabling) the proxy before commiting any change, and then starting it again ?
kolorasta
Tue Mar 11, 2008 4:12 pm
That's the way i do it :(
Users browsing this forum: MSN [Bot] and 64 guests
