paisapipe
Webbox and ASCII art
Tue Mar 11, 2008 8:07 pm
Hi, how can i change the Webbox appareance and the initial ASCII art of a terminal sesion?? I've bought a coupple of RB's to a reseller and they have a different initial configuration (Webbox, ASCII art of terminal, Identity and go on..) to the default RB config.
Thanks for the Help.
Best Regards.
normis
Re: Webbox and ASCII art
Wed Mar 12, 2008 9:02 am
reinstalling the software will reset it. if you are a reseller yourself, you can customize it. contact mikrotik in that case
paisapipe
Wed Mar 12, 2008 4:19 pm
Thanks!, one more question: i have to contact you at: support_at_mikrotik_dot_com
Thanks again.
(now i'm posting a How to on wiki in spanish, i hope it makes me a L6 winner... you'll can see it on http://wiki.mikrotik.com/wiki/Enlaces_I ... n_RouterOS)
