trottolino1970
how to block dhcp from my client to me!!
Thu Mar 13, 2008 10:58 am
how to block dhcp from my client to me and Sharing files and folders?
sandov63
Re: how to block dhcp from my client to me!!
Fri Mar 14, 2008 10:52 pm
built this rule under ip -> firewall -->> filter rules
add chain=forward action=drop dst-port=68 protocol=udp comment="DROP DHCP \
SERVERS" disabled=no
add chain=input action=drop dst-port=68 protocol=udp comment="" disabled=no
this way you are blocking broadcasting from port 68 of users whose wake up a dhcp server
Cuando la ignorancia se impone, la razon cordialmente cede el paso.
Chupaka
Sat Mar 15, 2008 2:00 am
are broadcast packets affected by forward chain? :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
trottolino1970
Sat Mar 15, 2008 9:05 am
And how to block them?
nickb
Thu Mar 20, 2008 10:35 pm
Turn off "forwarding" on the wireless side; such as disable "default forward" if you have are using "default authenticate", or uncheck "Forwarding" in the access list entry for a MAC address. This will prevent DHCP from broadcasting to other wireless clients.
tenis
Fri Mar 21, 2008 1:09 am
What exactly turning off default-forwarding do? It just stops broadcasting all broadcasts from clients? This would be great, cause I had quite a few issues related to this (private DHCP server on client side, providing incorrect leases, etc.)
But I still would like to have clients able to speak between each other. How the arp who-has will be responded if it will not be broadcasted to all clients. Would AP be able to make this working?
gmeyer
Fri Mar 21, 2008 4:28 am
Add filters in the bridge on the wireless interface
add chain=input mac-protocol=ip src-port=67 ip-protocol=udp action=drop comment="Drop DHCP" disabled=no in-interface=wireless
add chain=forward mac-protocol=ip src-port=67 ip-protocol=udp action=drop comment="Drop DHCP" disabled=no in-interface=wireless
Remember that broadcast working on layer 2
Gabriel J. M. Meyer
CCNA, Red Hat Linux Administrator
totalnett
Tue Mar 25, 2008 2:18 pm
Can't get this to work.
I have routeros 3.4 on a RB192...
Do i have to mark packets in Mangle first? How should i do this?
Users browsing this forum: ananthlucky, Baidu [Spider], Bing [Bot], buraglio, fredcom, Google [Bot], sindy, Trackboy and 193 guests
