ddlan
Console Bug in 3.x
Thu Mar 13, 2008 3:56 pm
i have found the Problem with console crash:
after Copy and Paste from Microsoft Excel to Winbox come the Bug. Only downgrade to 2.9.x and Reset Configuration fix the Problem. Copy and Paste from Notepad works fine.
Problem is on many PC's with Excel 2003 and 2007 under Windows XP german.
mfg
THomas Böttcher
normis
Re: Console Bug in 3.x
Fri Mar 14, 2008 9:04 am
what and why do you want to copy from excel to winbox ???
ddlan
Fri Mar 14, 2008 10:25 am
i have all IP-adresses and Routernames in Excel. Copy in Router OS 2.9.x works. After Copy one Item (Routername !!!) in fresh installed 3.x then Console Crash.
mfg
Thomas Böttcher
normis
Fri Mar 14, 2008 11:44 am
well, as you already found out - it can only work with paste of plaintext strings. it's made to do that.
ddlan
Fri Mar 14, 2008 3:59 pm
why ist works in 2.9.xx not in 3.x ?
mfg
Thomas Böttcher
normis
Fri Mar 14, 2008 4:03 pm
because v3 console has more features, and probably interprets your additional characters as some instructions. I recommend you saving this to a plaintext file with extension RSC and then using the RouterOS standard "IMPORT" command. This is the recommended method of configurating
ddlan
Fri Mar 14, 2008 4:53 pm
Its not a Bug, its a Feature :lol:
Users browsing this forum: alidamji, dpsguard, eworm, justarankamateur, jvanhambelgium, pcunite, tdw and 161 guests
