adaheem
changing profiles in pppoe according to schedule
Tue Mar 18, 2008 1:17 am
hi all
i need to change the profile in pppoe according to a schedule time i choose.
can MT do it?
10x in advance
Chupaka
Re: changing profiles in pppoe according to schedule
Tue Mar 18, 2008 3:07 am
you may use scheduler and scripting
adaheem
Tue Mar 18, 2008 10:46 pm
any more help please
raktim
Wed Mar 19, 2008 8:46 am
to change profile ---system script, add /ppp profile set "tester" rate-limit=128k/128k
i think there will be a problem. Coz...
if 200 pppoe customer logged in as a profile name "silver" speed 64k/64k.
when profile will be changed to "Gold" speed 128k/128k as a scheduled time.
client's will not get new profiles speed. first they will have to log off and login again. Now they will get new profiles speed.
For too many client's it's not possible to write a script to remove client from active connection.
Chupaka
Thu Mar 20, 2008 12:42 am
ppp active remove [find ppp active find]?..
raktim
Fri Mar 21, 2008 12:41 pm
i know that script. Questions was changing profiles for pppoe clients . i just said, i have 200 clients it's not possible to write 200 scripts to remove clients from active connection.
//if profile is change it will not effect on clients if the clients will not re log in again..
Thnxs....
raktim
Chupaka
Fri Mar 21, 2008 10:46 pm
well, you can mark all clients on old profile with some comment, then change profile, and then remove commented clients
adaheem
Sun Mar 23, 2008 6:45 pm
please more details Chupaka didn't get your idea well.
Chupaka
Mon Mar 24, 2008 12:21 am
well, you first write, please, why does 'ppp active remove [find ppp active find]' not fit your needs?
