MUM Europe 2020
antonioff
value Port-limit from radius ignored
Tue Mar 18, 2008 1:56 pm
Hi all,
I have problem with server pppoe and radius.
User authentication via radius works properly with limitation of Banda.
The problem in reply is specified radius of the port-limit not to authenticate multiple users with the same username.
But is ignored, how can we do?
karo84
Re: value Port-limit from radius ignored
Fri Mar 21, 2008 12:14 pm
Hi
Port-Limit will not work for PPP users.
You have to enable such option on RADIUS server, that will disallow duplicate
sessions.
FreeRADIUS server supports feature that is called 'Simultaneous-Use'. You need
to enable this.
Regards Karapet Aznavuryan
savage
Tue Mar 25, 2008 9:57 am
Yuppers. Port-Limit is a check item, not a reply item. i.e. it's checked on the radius server (from accounting data which needs to be kept current), and not on the router.
Regards,
Chris
maxfava
Thu May 15, 2008 1:00 am
same problem using windows server 2003 and IAS.
enabling log (go to system logging and create e memory log that filter radius/debug.
it receive port limit from radius but ROS does not apply it
ciao
Max
Users browsing this forum: MSN [Bot] and 94 guests
