elderado
Compatible: Mikrotik With Chipset P35 Motherboard??
Wed Mar 19, 2008 9:34 pm
hello..
i just bought a new abit ip35 mobo, but when i try to install mikrotik v3.4 into the harddrive (IDE / SATA), it said something like this "Fatal Error: cannot found any harddrive".
even when i put a DOM that already contain mikrotik level-4 with v3.4, i got a result something like this:
"uncompressing linux.... OK booting kernel
ERROR could not find disk!
Please attach it somewhere else."
i thought that mikrotik cannot support abit ip35 motherboard, then i bought another one, gigabyte ga-p35-ds3l motherboard, but it came out with the same result (both of them using P35 Chipset)
does mikrotik compatible with motherboard using P35 chipset? because then i try to install windows xp using the same hardware (mobo & harddrive), everything works perfectly.
thanks
elderado
Re: Compatible: Mikrotik With Chipset P35 Motherboard??
Wed Mar 19, 2008 9:46 pm
i just found this thread has a same problem with me:
http://forum.mikrotik.com/viewtopic.php ... rd#p107192
but still no solution.
CarulloS
Thu Mar 20, 2008 3:54 am
if its a sata controller change the bios options (ahci on off ect) There are usually several modes to choose from, maybe one will work.
elderado
Thu Mar 20, 2008 8:30 am
already tried it, and no luck for me
elderado
Thu Mar 20, 2008 2:59 pm
anyone?
marko_bg
Thu Mar 20, 2008 9:11 pm
same MB ...
use netinstall, work for me
acim
Fri Mar 21, 2008 4:06 am
same MB ...
This make me hard to believe, are you sure? The problem is MT can't see IDE disk at all, I don't see any difference if you boot from network or CD.
elderado
Fri Mar 21, 2008 7:58 am
i think mikrotik did see a drive:
"uncompressing linux.... OK booting kernel <- this is mikrotik
ERROR could not find disk! <- suddenly like this
"mikrotik bugs maybe??"
@marko_bg
thanks.. i will try netinstall
elderado
Sun Apr 13, 2008 7:34 pm
i found this problem solved after using v3.7 release (not sure this bug fixed on v3.6 or 3.7 version), but only for SATA / IDE Drive, just like normal installation.
but i still found this problem when i try to install mikrotik into DOM (Disk On Module), could someone help me?
or may be could admin fix this bug in the next release?
thanks
elderado
Mon Apr 14, 2008 11:47 pm
still no respond
viktorc
Thu Apr 17, 2008 4:16 pm
I had the same problem. Solution I found is:
install MikroTik on USB flash drive via NetInstall (3.7).
Kernel used in 3.7 doesn't support PATA controller used on P35 chipset.
My MB is ASUS P5KC
gmsmstr
Trainer
Trainer
Thu Apr 17, 2008 7:37 pm
Just in case you don't see it.. http://wiki.mikrotik.com/wiki/Supported_Hardware is the support hardware link.
Dennis Burgess, MCTCE, MTCNA, MCTCTE, MTCWE, MTCNIE, A+, N+, MCP, MTCSE Mikrotik Certified Consultant / Trainer
Need Mikrotik Support: http://www.linktechs.net -- Link Technologies, Inc.
-- Author of "Learn RouterOS: Second Edition"
elderado
Thu Apr 17, 2008 11:58 pm
My MB is ASUS P5KC
no solution except netinstall??
cause i already bought DOM with level 4 license (the license already put into the DOM by the reseller), is it ok to perform netinstall? i'm affraid that i will lose the license number.
elderado
Fri Apr 18, 2008 12:01 am
the v3.7 already fixed sata drive running on P35 chipset motherboard.
lots of motherboard right now are using P35 chipset, hopefully the admin will make mikrotik capable to run on P35 chipset motherboard using DOM / CF in the next release.
Users browsing this forum: maxsaf, sutrus and 75 guests
