rpengineering
Moving licence
Thu Mar 20, 2008 9:18 pm
Hello!, i've purchased a level 5 x86 licence, and i've installed it on a vmware machine for testing.
now my testing are ended, then i need to move this licence on a phisical server machine.
what i can do ??
thanks
changeip
Re: Moving licence
Fri Mar 21, 2008 1:44 am
You can't, the license is bound to the hard drive it was generated for. You should read up on the license before you purchase the next one.
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
Chupaka
Re: Moving licence
Fri Mar 21, 2008 2:03 am
send you vmware virtual machine to support, so they can check that it was really vmware =)
maybe they will give you another chance... =)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
rpengineering
Re: Moving licence
Fri Mar 21, 2008 11:40 am
I Can Send you the vmware file, if you tell me where i can do it.
i also can give you remote access to this.
Thank You
Chupaka
Re: Moving licence
Fri Mar 21, 2008 5:38 pm
send supout file to support <at> mikrotik.com with description of the problem
rpengineering
Re: Moving licence
Thu Mar 27, 2008 12:33 am
mikrotik support had create me the replacement key
thank you!!
Users browsing this forum: cbpapi, hanzel619, m86895, shimo and 116 guests
