cheesegrits
perl API client
Mon Mar 24, 2008 6:01 pm
[New version uploaded 3/26/2008. Fixed a bug which caused command output to hang sometimes, and added simple command line client]
Attached should be a ZIP with three files:
Mtik.pm - a simple perl client for the Mtik API. Pretty much a perl port of the python client from the Wiki, with an extra routine or two for formatting the returned data.
mtik_api_example.pl - an example of how to use the API. Provides some useful wireless ACL control routines. I've included enough comments so you should be able to work out how it all hangs together.
mtik_tty.pl - a simple command line client for testing API commands with. Use -h switch for usage info.
This code is very much a first cut. I intend to make the Mtik.pm stuff object oriented, so it can support more than one open Mtik connection at a time, but for now it is purely function driven. I needed it in a hurry!
Please feel free to feed back comments, suggestions, bug reports or light bulb jokes. Also feel free to modify, redistribute and generally do what you will with the code.
Share And Enjoy.
-- hugh
edit:
some other user added SSL functionality to this code. You can see it here (on this thread):
http://forum.mikrotik.com/viewtopic.php ... 84#p457584
cheesegrits
Re: perl API client
Tue Mar 25, 2008 8:46 pm
I think I've tracked down the reason it hangs occasionally on the socket recv. A misunderstanding on my part on how recv works with regards to specified read lengths.
I'm testing the new version, I'll post it when I'm sure it's fixed.
-- hugh
cheesegrits
Re: perl API client
Wed Mar 26, 2008 11:13 pm
New version uploaded. Bug described in previous post is fixed.
-- hugh
gacopl
Re: perl API client
Fri Apr 18, 2008 10:57 am
Hello
Thank you for doing this wrap for perl, however i cannot get it to run it gives me no socket: Connection refused :/
Please help
Michal
gacopl
Re: perl API client
Fri Apr 18, 2008 11:28 am
ok i solved i had to enable api service on MT
B/R
Michal
adamx
Re: perl API client
Thu May 01, 2008 12:54 pm
Much appreciated. I'll have some additional contributions to this soon.
cheesegrits
Re: perl API client
Fri May 09, 2008 10:23 pm
Glad it helps you out.
I've now built a fairly comprehensive provisioning system for our Mtik based wireless networks using it, and so far haven't had to update the main mtik_api.pl core.
If you feel adventurous, feel free to turn it into an actual package ... :)
-- hugh
ran_talbott
Re: perl API client and non-keyword operands
Tue May 20, 2008 2:54 pm
Hugh,
Thanks for making this available: it has been a big help.
One mistake I made that other people who want to use it should avoid is the assumption that you can use the "talk" function just like you would a telnet connection. E.g., I tried something like:
@cmd = ("/category/command", "keyword1=value1", "keyword2=value2");
($rc, @response) = Mtik::talk(\@cmd);
Mtik::talk works fine for commands with no operands, but, if you're sending a command with keyword-based operands, you need to use the "mtik_cmd" function, and supply the operands in a hash, like the main loop in the example does. I think this is because mtik_cmd is doing the special formatting (like adding a leading "=" to operands) that's different between the terminal interface and the API.
The problem I'm having right now, though, is that I'm using the API to fiddle the firewall tables to provide temporary access to certain servers for users who've logged in through a web interface. I can add entries okay, now that I'm using mtik_cmd. But, when I try to remove entries with:
    my @cmd = ("/ip/firewall/filter/remove", "$rowno");
    my($retval,@results) = Mtik::talk(\@cmd);
The debug output says that the code is sending the command and operand, and I get a "!done" response. But the command doesn't remove the entry.
I'd kinda like to find out why this doesn't work, for future reference. Has anyone worked out a general-purpose method for sending commands with positional parameters?
Meanwhile, I found a hint in another posting that enabled me to make it work. It was about another command that takes a "row number" as a positional parameter in the telnet interface. In the API, the row is identified using the ".id" value passed back when listing the table (notthe row number that you'd use in the telnet interface), and a keyword of "numbers".
I have a function that uses the "talk" function to build an array of hashes containing the current firewall table, and another that will find the entry to be deleted. So the code to remove an entry looks like this:
# Remove a camera/IPA pair from the firewall list.
# Returns 0 if it was removed, or a negative number if it wasn't.
# Inputs:
#		The camera resource name (which is also used as the name of
#			its chain in the firewall)
#		The source (i.e.,  user's) IP address
sub mtik_access_remove
    my($chain) = shift;
    my($ipa) = shift;
		# First see whether it's already in the list
    my($rc, @firewall) = mtik_get_firewall;
	if ($rc) {
		return $rc;
	my($rowno) = mtik_find_entry_in_firewall(\@firewall, $chain, $ipa);
	if ($rowno < 0) {
		print "IPA $ipa not found in chain $chain\n";
		return -1;
    	# It's there, so try to remove it
#	my @cmd = ("/ip", "firewall", "filter", "remove", "$rowno");
    my %operands;
	$operands{'numbers'} = $firewall[$rowno]{".id"};
	my($retval,@results) = Mtik::mtik_cmd("/ip/firewall/filter/remove", \%operands);
	if ($retval != 1) {
		print "removal of IPA $ipa from $chain failed. RC = $retval\n$Mtik::error_msg\n";
		return $retval;
	return 0;
[code]
Note the way I test $retval for a value of 1 (instead of 0) for "success".  I translate it to 0 for code calling my functions,  since I'm used to the convention of "0 for success,  non-zero for failure".
Thanks again for sharing.  I hope others find this record of my mistakes useful in avoiding repeating them.
Ran
janisk
Re: perl API client
Tue May 27, 2008 4:10 pm
use .id to remove entries, in this case, do print and get a list of rules with .id numbers, then parse the result and get what rules you want to remove.
also when you add a rule, you get the .id number of the rule, so if in the same session you want to remove the rule you can use returned .id number of the rule to remove it in the end
normis
Re: perl API client
Mon Jun 02, 2008 8:41 am
To cheesegrits: If you will add this info to the wiki, I will give you a free RouterOS license!
cfernandes_io
Re: perl API client
Tue Jun 03, 2008 12:30 am
is possible to get a queue simple rate ?
k3dt
Re: perl API client
Fri Jun 06, 2008 6:28 pm
Thank you very much for this scripts! Btw can somebody make php class for MT api?
lagosta
Re: perl API client
Wed Jul 09, 2008 1:02 am
Where should i put the pm file?
I'm running a kubuntu 7.10 distro.
gacopl
Re: perl API client
Tue Aug 26, 2008 1:56 am
yes try to filter out a table of 1000 firewall rules, another 1000 of queues and another one of mangles, 1st your MT must be really fast, same as the machine you're running this script. It takes ages otherwise.
Also i checked, that id that you get returned when you add a rule, persist the same even after reboot, it only changes when you of course remove it ;). So if your doing some script for handling qos etc. It is good to keep those id's on some database such as Mysql then you just refer to id's you need, instead of parsing of hundreds of lines. besides that even if you have fast machines, such huge comunication (printing 5000 rules, and all ACKs in comunication) takes a lot of bandwidth. I'm doing such a database, and i always have at my hand script that when something goes wrong just does it in oldstyle way, removes all rules and add them again.
BTW. I saw that in ROUTEROS 3.13 something has changed becuase, usually my script worked but in this version the communication seems to be unregular, it looses some rules (in debug it shows "traped" instead of done). It runs smoothly on 3.10. There had to be some change. This what makes me always nervous at RouterOS, unpredictable changes.... that are not presented in changelog.
B/R
Michal
BTW thx a lot for this perl wrap!!!
janisk
Re: perl API client
Mon Sep 01, 2008 3:21 pm
would be nice if you wrote what exactly is failing, and how large outputs you are getting.
gacopl
Re: perl API client
Tue Dec 23, 2008 12:01 am
okay i've made an effort and debugged it, it seems that api dosen't accept src-port=445-65535, in fact it doesn't accept any range of ports for dst-port and src-port, this happens in ROS 3.11 and above... if I hashout directives with port-ranges my script works fine...
now it's your turn to fix or guide me how to overcome this ;)
B/R
Michal
gacopl
Re: perl API client
Tue Dec 23, 2008 12:13 am
okay i have to give you back your honor, the problem was that MT got smarter in newer versions and can accept port ranges only for tcp and udp as far as i recall, and not giving parameter of protocol=tcp was the cause... and as far as i recall you mentioned this new behavior in changelog, soo I APOLOGIZE.
you never know how much frustating administrating can be ... ;)
merry christmas
gacopl
Re: perl API client
Tue Dec 23, 2008 12:56 am
NO, unfortunately i was assuming things too quickly, i was right it itsn't accepting port ranges correctly:
root@ns1:/etc/lms# ./mtik_tty.pl -m 10.255.0.2 -u admin -p xxxxx
<<< /ip/firewall/mangle/add
<<< =chain=forward
<<< =protocol=tcp
<<< =src-port=445-460
>>> !trap
>>> =category=1
>>> =message=invalid value for argument range
like i said logging into 3.10 this works flawlessly, and in my script i have protocol=tcp directive so everything is fine from my side
B/R
Michal
gacopl
Re: perl API client
Fri Jan 30, 2009 4:55 pm
again it's not surprise to not get an answer here
shall i forward this to support?
dada
Re: perl API client
Mon Feb 23, 2009 1:32 pm
Share And Enjoy.
-- hugh
Thanks for the code - but I would like to write that the read_len() function in mtapi.pl is completely wrong. For one byte lengths it works (but only by accident - the initial IF statement is not correct).
- the bitwise negation operator is not "!" but "~". If you use ! all nonzero values are repleced by zero and zero is replaced by 1
- bitwise AND has lower precedence than comparation (==). In original code two constants were compared and the result (mostly zero) was anded with $len
- you have to read the subsequent bytes of block length using recv() not recursivelly calling read_len() again
This is the code which works for one and two byte lengths. I tried to correct others too but no checks/tests were made for them.
sub readbyte {
my $line;
$sock->recv($line,1);
if ($debug > 4)
printf "readbyte:received: %x\n",ord($line);
return ord($line);
sub read_len {
if ($debug > 4)
print "start read_len\n";
my $line;
my $len = readbyte();
if (($len & 0x80) == 0x00)
return $len;
elsif (($len & 0xC0) == 0x80)
$len &= ~0xC0;
$len <<= 8;
$len += readbyte();
elsif (($len & 0xE0) == 0xC0)
$len &= ~0xE0;
$len <<= 8;
$len += readbyte();
$len <<=8;
$len += readbyte();
elsif (($len & 0xF0) == 0xE0)
$len &= ~0xF0;
$len <<= 8;
$len += readbyte();
$len <<=8;
$len += readbyte();
$len <<=8;
$len += readbyte();
elsif (($len & 0xF8) == 0xF0)
$len = readbyte();
$len <<= 8;
$len += readbyte();
$len <<=8;
$len += readbyte();
$len <<=8;
$len += readbyte();
if ($debug > 4)
print "read_len got $len\n";
return $len;
Regards
Dalibor Toman
nodeny
Re: perl API client
Sun May 03, 2009 4:22 am
cheesegrits did you tested len>=0x200000?
I think
print $sock chr(($len >> 8) & 0xFF);
will print one value. Maybe you mean
print $sock chr(($len >> 24) & 0xFF);
print $sock chr(($len >> 16) & 0xFF);
yeah?
Then I read wiki.mikrotik.com/wiki/API:
len >= 0x10000000
0xF0 and len as four bytes
so your code is
 elsif ($len < 0x10000000)
        $len |= 0xE0000000;
0xE0000000 != 0xF000000000
and better elsif ($len < 0x10000000) -> else
The formula is seems simple. My code:
$bytes=$len < 0x80? 1 : $len < 0x4000? 2 : $len < 0x200000? 3 : $len < 0x10000000? 4 : 5;
$len|=(0x0F >> (5-$bytes)) << ($bytes*8-$bytes+1);
while ($bytes--)
    $str.=chr($len & 0xFF);
    $len>>=8;
$str - rezult
nodeny
Re: perl API client
Sun May 03, 2009 4:27 am
I mean
2 Identical conditions
nodeny
Re: perl API client
Sun May 03, 2009 11:38 am
sub read_len
 my ($len,$c,$bytes);
 $sock->recv($c,1);
 $c=ord($c);
 $bytes=$c<0x80? 0 : $c<0xC0? 1 : $c<0xE0? 2 : $c<0xF0? 3 : 4;
 $len=$c & (0xFF >> $bytes);
 $bytes or return $len;
 while ($bytes--)
    $sock->recv($c,1);
    $len=($len << 8) + ord($c);
 return $len;
nodeny
Re: perl API client
Wed May 06, 2009 12:03 pm
if ($word =~ /!done/)
    $retval = 1;
if ($word =~ /^!done/)
    $retval = 1;
imagine a reply like that:
=name=system!done
Chupaka
Re: perl API client
Wed May 27, 2009 12:21 am
in API, you can use shortened value names, like in CLI; e.g.
/ip/route/print
=n=*1
=val=routing-mark
instead of
/ip/route/print
=numbers=*1
=value-name=routing-mark
isn't it a bit dangerous? maybe it should be forbidden, to avoid possible future problems? API is not CLI for humans...
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
janisk
Re: perl API client
Mon Jun 01, 2009 11:07 am
users have to use full command/attribute names when writing API command. Shortened names will not be allowed in 3.25+ versions
normis
Re: perl API client
Mon Jun 01, 2009 11:09 am
What's new in 3.25:
*) api - do not accept truncated property names;
Chupaka
Re: perl API client
Mon Jun 01, 2009 11:31 am
coool =)
normis
Re: perl API client
Mon Jun 01, 2009 11:33 am
yes, thank you very much for the report :) will you come to MUM in USA?
Chupaka
Re: perl API client
Mon Jun 01, 2009 11:46 am
unfortunately, no - it's too expensive for me =(
I'll wait for the next MUM in Europe, CZ MUM was the best ))
during your MUM in USA I'll be looking for such issues with API here, in Minsk :D
Pikoro
Re: perl API client
Sat Jul 11, 2009 6:47 am
When are you guys going to have a MUM in Japan?
ema
Re: perl API client
Wed Jul 15, 2009 11:58 am
This perl api need to be rewritten.
It has also errors in general getting answer where !done= !trap= !fatal,
-> sub talk and and sub read_sentence
I would like to thanks to the author.
All my networks works managed using API Perl + PHP.
api.perl gets statistics, signals, macs
ap.php manage users,queues
sub read_sentence {
    my ($word);
    my ($i) = 0;
    my (@reply);
    my($retval) = 0;
    my($done) = 0;
    # tu trzeba dopisać obsluga trap
    while ($word = &read_word())
                $retval = 1;
                $done=1;
            elsif ($word =~ /^!trap/)
                $retval = 2;
            elsif ($word =~ /^!fatal/)
                $retval = 3;
        $reply[$i++] = $word;
        if ($debug > 2)
            print STDERR "MT: $word\n"
    return ($done,$retval,@reply);
######## PUBLIC FUNCTIONS ############
sub talk
    #my(@sentence) = shift;
    my($sentence_ref) = shift;
    my(@sentence) = @$sentence_ref;
    &write_sentence(\@sentence);
    my(@reply);
    my(@attrs);
    my($i) = 0;
    my($retval) = 0;
    my($done) = 0;
    while (($done,$retval,@reply) = &read_sentence())
        foreach my $line (@reply)
            if ($line =~ /^=(\S+)=(.*)/)
                $attrs[$i]{$1} = $2;
        if ($retval > 0 && $done>0)
            last;
        $i++;
    return ($retval, @attrs);
gumis78
Re: perl API client
Thu Sep 17, 2009 2:30 pm
HELP ... i update all RB from 3.20 to 3.28 and some scripts in perl stops
settings parameters - OK
/interface/print - OK
/interface/wireless/accesslist/print - OK
but
/interface/wireless/registration-table/print - CRASH
what is wrong ??
help me ...
Krzys
ema
Re: perl API client
Sun Sep 20, 2009 11:02 pm
How many client stations is connected to this mikrotik?
There is a bug which losts data when you try to get more then 1KB data.
Try to change first doanloaded perl api and apply all canges on forum site in this thread.
janisk
Re: perl API client
Tue Sep 22, 2009 12:16 pm
if i remember correctly then first releases of Perl API lacked support for long responses. Do as ema said
gumis78
Re: perl API client
Tue Sep 22, 2009 2:48 pm
hmm .. many connected stations ... sometimes show 6 stations (maybe it is 1kB)
I try changed perl api but does't work fine - sometimes show 6 stations - sometimes crash
zlyZwierz
Re: perl API client
Tue Sep 22, 2009 5:00 pm
Maybe check mine perl API packege: http://zwierzu.zepsul.net/Mtik.pm.txt
sample code:
#!/usr/bin/perl
use strict;
use warnings;
use Mtik;
use Data::Dumper;
       my $mt = Mtik->new( host => 'host', user => 'admin', pass => 'pass');
        if ($mt->login()) {
            my $regtable_api = $mt->get_by_key('/interface/wireless/registration-table/print','=stats', 'mac-address');
            print Dumper $regtable_api;
Works for me..
localhost sbin # perl dupa.pl
$VAR1 = {
          '00:15:6D:D0:0F:F5' => {
                                   'rx-ccq' => '17',
                                   'hw-frame-bytes' => '42100172,7240063',
                                   'packets' => '49461,38274',
                                   'nstreme' => 'false',
                                   'ack-timeout' => '28',
                                   'uptime' => '08:03:54',
                                   'interface' => 'wlan3',
                                   'last-activity' => '00:00:03.350',
                                   'frame-bytes' => '40615897,6306238',
                                   'mac-address' => '00:15:6D:D0:0F:F5',
                                   'framing-mode' => 'none',
                                   '802.1x-port-enabled' => 'true',
                                   'routeros-version' => '3.2',
                                   'ap' => 'false',
                                   'bytes' => '40910305,6535882',
                                   'signal-to-noise' => '34',
                                   'tx-ccq' => '97',
                                   'radio-name' => 'Motozbyt',
                                   'frames' => '49461,38274',
                                   'hw-frames' => '49738,38665',
                                   'tx-frames-timed-out' => '0',
                                   'compression' => 'false',
                                   'wmm-enabled' => 'false',
                                   'p-throughput' => '18146',
                                   'tx-signal-strength' => '-67',
                                   'wds' => 'false',
                                   'signal-strength' => '-70dBm@6Mbps',
                                   'comment' => '',
                                   '.id' => '*4',
                                   'rx-rate' => '12Mbps',
                                   'strength-at-rates' => '-70dBm@6Mbps 1s350ms,-70dBm@9Mbps 18s380ms,-71dBm@12Mbps 3s350ms,-71dBm@18Mbps 3m39s750ms,-72dBm@24Mbps 3m43s620ms',
                                   'tx-rate' => '24Mbps'
grealish
Re: perl API client
Tue Sep 29, 2009 11:38 am
Hi I've been playing around allot with the perl API client, and have been testing a few commands on the TTY wrapper, however I'm having trouble trying to enable a defined queue in the simple queues table
/queue/simple-table/print
#lists queues
>>> !re
>>> =.id=*2
>>> =name=limit-vlan3-tc
>>> =target-addresses=192.168.192.0/22
>>> =dst-address=0.0.0.0/0
>>> =interface=vlan3-192.168.192.0/22 VM TC
>>> =parent=none
>>> =direction=both
>>> =priority=8
>>> =queue=default-small/default-small
>>> =limit-at=0/0
>>> =max-limit=2M/2M
>>> =burst-limit=0/0
>>> =burst-threshold=0/0
>>> =burst-time=0s/0s
>>> =total-queue=default-small
>>> =bytes=0/0
>>> =total-bytes=0
>>> =packets=0/0
>>> =total-packets=0
>>> =dropped=0/0
>>> =total-dropped=0
>>> =rate=0/0
>>> =total-rate=0
>>> =packet-rate=0/0
>>> =total-packet-rate=0
>>> =queued-packets=0/0
>>> =total-queued-packets=0
>>> =queued-bytes=0/0
>>> =total-queued-bytes=0
>>> =lends=0/0
>>> =total-lends=0
>>> =borrows=0/0
>>> =total-borrows=0
>>> =pcq-queues=0/0
>>> =total-pcq-queues=0
>>> =disabled=true
>>> =invalid=false
>>> =dynamic=false
>>> !done
When I specify the =.id=*2 and then =disable=false it returns
>>> !done
>>> !trap
>>> =message=no such command prefix
And i'm unsure if i'm specifying this right
Thanks in advance
Chupaka
Re: perl API client
Tue Sep 29, 2009 12:22 pm
/queue/simple-table ?..
what exact command do you try to set 'disabled' to false?..
grealish
Re: perl API client
Tue Sep 29, 2009 12:31 pm
I have a list of simple queue's that I wish to be able to disable and enable from a perl script using the API,
/queue/simple-table/print will list the table of simple scripts, but my question is how do I enable the predefined scripts?
Chupaka
Re: perl API client
Tue Sep 29, 2009 12:45 pm
at first, '/queue/simple-table/print' gets
trap =) you should use '/queue/simple/print'
for enabling, use
/queue/simple/set
=.id=*2
=disabled=false
grealish
Re: perl API client
Tue Sep 29, 2009 3:36 pm
for enabling, use
/queue/simple/set
=.id=*2
=disabled=false
Cool Thanks, works now, however can I address the queue differently as in;
<<< /queue/simple/set
<<< =name=limit-vlan3-tc
<<< =disable=false
>>> !done
Basiclly i'm trying to setup a perl script that will enable a simple queue, then start the B/W server to create load on the link so I introduce latency on the link while I test an application communicating on a high latency link,
Is the API able to control the BW server settings as well?
Chupaka
Re: perl API client
Tue Sep 29, 2009 4:08 pm
<<< =disable=false
>>> !done
no, you should first find necessary item, then disable it by id. like this:
/queue/simple/print
=.proplist=.id
?name=limit-vlan3-tc
and then
/queue/simple/set
=.id=*here's_your_id
=disabled=false
basically, API can do anything you can do with CLI =) all exceptions you can get to know only after you try to do something unusual =)
grealish
Re: perl API client
Tue Sep 29, 2009 6:45 pm
thanks, so I do as is, however it returns idone?? is it not to return the .id? of the name I passed?
<<< /queue/simple/print
<<< =.proplist=.id
<<< ?name=limit-vlan3=tc
>>> !done
Chupaka
Re: perl API client
Tue Sep 29, 2009 9:09 pm
checked with 3.28: when that name exists, the request returns the following:
!re=
=.id=*1
grealish
Re: perl API client
Tue Sep 29, 2009 9:17 pm
!re=
=.id=*1
Got it :)
<<< =.proplist=.id
<<< ?name=limit-vlan3-tc
>>> !re
>>> =.id=*2
>>> !done
Will try now to implement this in a perl script
I believe you have to enter the tree structure with the /cancel followed by two CR/LF before it will reset the state of the API?
Chupaka
Re: perl API client
Tue Sep 29, 2009 9:31 pm
state? what state?..
janisk
Re: perl API client
Thu Oct 01, 2009 10:48 am
/cancel is for commands that are continuous, and other way would not end ever, like:
/ip/address/print
=interval=1
if you add .tag to continuous command then youcing /cancle with tag, you can cancel just this one command with the tag, and not all commands that are launched.
Also, API have no states, you send in commands and get responses. If you send more commands, you get more answers, if you run continuous command you will get answers all the time, but that does not mean you cannot send it more commands to get more responses.
Virtually speaking, if you want states then there are 2 that matter - you are either logged in (one state) or not (second state)
milanc
Re: perl API client
Sun Aug 21, 2011 4:58 pm
Hi, i have problem.
Is possible get via api UPS status? Command is /system ups monitor 0 once
This is ok...
my $ret = $mt->get_by_key('/system/ups/print');
print Dumper($ret);
$VAR1 = {
          '*3' => {
                    'nominal-battery-voltage' => '24',
                    'disabled' => 'false',
                    'manufacture-date' => '08/06/99',
                    'serial' => '************',
                    'version' => '50.11.I',
                    'model' => 'SMART-UPS 700',
                    'name' => 'ups1',
                    'alarm-setting' => 'immediate',
                    'port' => 'serial0',
                    'min-runtime' => '5m',
                    'on-line' => 'true',
                    '.id' => '*3',
                    'offline-time' => '00:05:00',
                    'load' => '5',
                    'invalid' => 'false'
my $ret = $mt->get_by_key('/system/ups/monitor','=0','=once');
print Dumper($ret);
$VAR1 = {};
what is wrong? Thanks for help.
Milan
Chupaka
Re: perl API client
Mon Aug 22, 2011 1:22 pm
try
my $ret = $mt->get_by_key('/system/ups/monitor','=.id=*3','=once=');
milanc
Re: perl API client
Tue Aug 23, 2011 3:43 am
It works, thank you very much. Just the following warning is written...
Use of uninitialized value in hash element at /usr/local/lib/perl5/site_perl/5.10.1/Mtik.pm line 414.
$VAR1 = {
                  'rtc-running' => 'false',
                  'battery-voltage' => '2760',
                  'smart-boost' => 'false',
                  'on-battery' => 'false',
                  'overload' => 'false',
                  'runtime-left' => '02:31:00',
                  'transfer-cause' => 'Line voltage notch or spike',
                  'smart-trim' => 'false',
                  'replace-battery' => 'false',
                  'frequency' => '50',
                  'line-voltage' => '24050',
                  'low-battery' => 'false',
                  'load' => '5',
                  'output-voltage' => '24050',
                  'temperature' => '5620',
                  'battery-charge' => '100'
Chupaka
Re: perl API client
Wed Aug 24, 2011 1:50 am
and what's on line 414? =)
milanc
Re: perl API client
Sun Aug 28, 2011 4:29 am
Hi, is in function get_by_key
    foreach (@results) {
        my $item = $_;
        foreach my $result_key (keys (%$item)) {
            if (exists($item->{$key})) {
                if ($key eq $result_key) {
                    $result_hash->{ $item->{$key} } = $item
            else {
                $result_hash->{ $item->{'.id'} } = $item  <--- HERE
Thanks.
nightsnake
Re: perl API client
Thu Jun 28, 2012 1:33 pm
Hello!
Download this module, but it's don't connect to my RB:
>>> /login
start read_len
read_len got 5
recv 5
<<< !done
start read_len
read_len got 37
recv 37
<<< =ret=5d6f57de5c78f9305a19e17e11ff47cf
start read_len
read_len got 0
Use of uninitialized value in pack at Mtik.pm line 292.
>>> /login
>>> =name=admin
>>> =response=0088d75a26cd50e9304521a8b0bba09a85
start read_len
read_len got 5
recv 5
<<< !trap
start read_len
read_len got 22
recv 22
<<< =message=cannot log in
start read_len
read_len got 0
janisk
Re: perl API client
Mon Jul 02, 2012 11:50 am
Hello!
is API service enabled?
Chupaka
Re: perl API client
Tue Jul 03, 2012 1:54 am
seems like it is:
mmino7
Re: perl API client
Wed Sep 12, 2012 8:51 pm
Hi all,
where can I find last release of perl API.
janisk
Re: perl API client
Fri Sep 14, 2012 4:19 pm
check the first post of this thread. Also, if you check
http://wiki.mikrotik.com/wiki/Manual:API
it has link where the code/binaries can be found
savage
Re: perl API client
Fri May 10, 2013 4:15 pm
I currently use telnet to (rather frequently) fetch /ip firewall connection print count-only where src-address~"x.x.x.x:" assured
How would I be sending this via the API? I'm not having much success... :?
Regards,
Chris
Chupaka
Re: perl API client
Thu May 16, 2013 4:33 pm
unfortunately, there's no 'regexp' query in API, so you cannot do this
MT Staff, a little feature request: split that 'src-address' to 'src-address' and 'src-port', so it be possible to make queries to /ip firewall connections via API :) or maybe some additional query operators to match '*-address' not only by address part but also by IP subnet.
noyo
Re: perl API client
Wed Aug 14, 2013 11:40 pm
how to incorporate timeout? / how to set timeout? in script api mt perl
Chupaka
Re: perl API client
Thu Aug 15, 2013 11:44 am
what timeout?
noyo
Re: perl API client
Thu Aug 15, 2013 11:49 am
Timeout when no response from mikrotik.
I worked it out.
edit Mtik.pm end:
my $sock = new IO::Socket::INET(
PeerAddr => $host,
PeerPort => $port,
Proto => 'tcp',
Timeout => 3);
it works
efaden
Re: perl API client
Tue Aug 27, 2013 4:05 pm
Trying to get source from a script hangs... Anyone help? I am trying to get/set script source content from the API. Not sure if it is possible.
This Hangs:
perl code
my (%attrs);
$attrs{'.proplist'} = ".id,name,source";
my (%queries);
$queries{'name'} = "MyScript";
my($retval,@results) = Mtik::mtik_query('/system/script/print',\%attrs,\%queries);
print Dumper(\@results);
This Doesn't:
perl code
my (%attrs);
$attrs{'.proplist'} = ".id,name";
my (%queries);
Added to Mtik.pm:
perl code
sub mtik_query
    my($cmd) = shift;
    my(%attrs) = %{(shift)};
	my(%queries) = %{(shift)};
    $error_msg = '';
    my(@command);
    push(@command,$cmd);
    foreach my $attr (keys (%attrs))
        push(@command,'=' . $attr . '=' . $attrs{$attr});
    foreach my $query (keys (%queries))
        push(@command,'?' . $query . '=' . $queries{$query});
    my($retval,@results) = talk(\@command);
    if ($retval > 1)
        $error_msg = $results[0]{'message'};
    return ($retval,@results);
janisk
Re: perl API client
Tue Aug 27, 2013 4:15 pm
using python (3) client:
<<< /system/script/print
>>> !re
>>> =.id=*1
>>> =name=script1
>>> =owner=admin
>>> =policy=ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api
>>> =run-count=0
>>> =source=asdfasdfasdfsadf
>>> =invalid=false
>>> !done
source is just fast example of error:
asdfasdfasdfsadf
so this is language specific.
efaden
Re: perl API client
Tue Aug 27, 2013 4:24 pm
>>> !re
>>> =.id=*1
>>> =name=script1
>>> =owner=admin
>>> =run-count=0
>>> =invalid=false
>>> !done
asdfasdfasdfsadf
Yeah... I think I narrowed it down. I am pretty sure there is an error in the reading of the line length somewhere.... So yes.. it is library specific. Now if I could find the bug.
boen_robot
Re: perl API client
Tue Aug 27, 2013 4:36 pm
Given that most words are read fine, and only the last one is the problem, length decoding is probably not the issue.
It appers the real culprit may be the lack of socket buffering, which most API clients don't do. In the vast majority of cases, this is a problem only when you have large words, but if the speed of your connection to the router is low enough, you can experience it even with just a few bytes, as the case here. I think other than my client, there was only one other which did such buffering, but I don't remember which one it was... I think maybe Ruby, or ActionScript.
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
efaden
Re: perl API client
Tue Aug 27, 2013 4:42 pm
Interesting.... I wonder the best way to fix it. It is getting to the last word... reading part of it... reading "!do" then reads the length of the next word as "ne" and is trying to read 111 bytes... only finds 2 and fails.
boen_robot
Re: perl API client
Tue Aug 27, 2013 4:44 pm
It needs to be fixed in a generic fashion - the procedure that reads words needs to try read some data, then check out how much data it ACTUALLY received, and substract THAT from the length, and retry the remaining bytes.
What most clients do instead is that they read the length as, say "5 bytes", then they ask for 5 bytes, and assume they got what they asked for, when in fact, they got just 3 bytes.
efaden
Re: perl API client
Tue Aug 27, 2013 4:47 pm
It is theoretically doing that....
janisk
Re: perl API client
Tue Aug 27, 2013 4:51 pm
i really doubt that he is running out of TCP buffers set by OS. Unless perl uses something different. And usually TCP buffer is enough.
boen_robot
Re: perl API client
Tue Aug 27, 2013 5:01 pm
It's not about "runinng out" per se, but about not addressing how OS socket functions work - i.e. them being unreliable in terms of fetching what you ask for. People look at receivers like "give me N bytes", when in fact, they work as "give me all you've got, even if it's just 1 byte... just don't give me more than N bytes".
But after looking at the source, it appears efaden is right, and the Perl client is actually THE very other client which does such buffering, and I failed to remember (I'm terrible... I apologize).
The problem then seems to be in the recursive read_len calls - if you have a two byte length such as "10000001 100000000", instead of being decoded as "00000001 100000000" (384), it will be read as a three byte length, with the start of the second byte indicating a third length byte, which can become even more problematic if the next byte also starts with "1". Eventually, the client will start demanding more bytes then actually exist, and will hang because it will keep retrying for bytes that ultimately will never come. The problem would occur if ANY word in the stream has such sort of a length, which in this case is likely one of the scripts' source.
Within read_len, replace all read_len calls with a simple ord($sock->recv($line,1)), and things should be back to normal.
P.S. It's times like this that make me ask why aren't projects like this on GitHub. I would've made a pull request about this already by now.
efaden
Re: perl API client
Tue Aug 27, 2013 5:40 pm
There was a bug in read_len... I thought I fixed it, but there is still a bug. Fixing it... or trying to.
boen_robot
Re: perl API client
Tue Aug 27, 2013 5:45 pm
I saw the source for the brief time you posted it - do the "<<= 8" first, and THEN "+=" the new byte, not the other way around.
efaden
Re: perl API client
Tue Aug 27, 2013 6:23 pm
FIXED, Any length > 128 was reading incorrectly. Basically I modified it to mirror the Python code. There were several issues. It works now.
See the next post for the updated PM file.
efaden
Re: perl API client
Tue Aug 27, 2013 9:31 pm
Updated a few things....
Added the timeout parameter, fixed write_len for lengths > 0x80, fixed read_len for lengths > 0x80, and fixed allowing of newlines in the read_sentence.
I am now able to read and write scripts... woot!
I think I got all of my debugging out of the pm file. Let me know if you see anything else.
-Eric
farnsworth78
Re: perl API client
Fri Oct 18, 2013 7:36 am
-Eric
Can you add $sock->autoflush(0) ?
I wrote test program (it add 250 ips to address-list "using Mtik::mtik_cmd('/ip/firewall/address-list/add',\%attr);")
with $sock->autoflush(1) it takes ~60 sec .
with $sock->autoflush(0) it takes ~27 sec .
==== some changes
sub mtik_connect
my($host) = shift;
my($port) = shift || 8728;
if (!($host))
print "no host!\n";
return 0;
my($sock) = new IO::Socket::INET(
PeerAddr => $host,
PeerPort => $port,
Proto => 'tcp');
if (!($sock))
print "no socket :$!\n";
return 0;
$sock->autoflush(0); #<---- ADD THIS LINE
return $sock;
sub write_sentence {
foreach my $word (@sentence)
write_word($word);
if ($debug > 2)
print ">>> $word\n";
write_word('');
$sock->flush(); #<---- ADD THIS LINE
How to add ips to address list at once (like "enable/disable/remove" do )?
efaden
Re: perl API client
Fri Oct 18, 2013 1:18 pm
-Eric
==== some changes
sub mtik_connect
my($host) = shift;
if (!($host))
print "no host!\n";
return 0;
PeerAddr => $host,
PeerPort => $port,
Proto => 'tcp');
if (!($sock))
return 0;
return $sock;
write_word($word);
if ($debug > 2)
write_word('');
Feel free to add it. I don't actually maintain the thing. I just went to use it and found a bunch of errors in it, so I fixed them.
As for adding multiple IPs.... I'm not sure you can.
dahili
Re: perl API client
Sun Nov 10, 2013 10:21 pm
To normis: Dear friend i am looking some one who able to make perl or php basic gui for few commands for me i will pay works! my email : atilla.o.ersoz [at] gmail.com please get in touch with me
dahili
Re: perl API client
Sun Nov 10, 2013 10:43 pm
/ip/route/print
=n=*1
=val=routing-mark
instead of
/ip/route/print
=numbers=*1
To forum guru i am looking some one who are able to do it perl or php little gui for me only few commands please recomend me some one my email is atilla.o.erso [at] gmail.com i am sorry for this message hire
boen_robot
Re: perl API client
Sun Nov 10, 2013 11:41 pm
Really? Since which version? Last I checked (right now, with 6.5), that's not the case, protocol wise at least.
The next version of my client (in PHP, from my signature) will provide an interactive command line utility that you can type raw commands in. You can get the current state from its develop branch on GitHub if you can't wait for a tagged release (which is held up for a few reasons, one of which is that for the console, you need to also get the current untagged PEAR2_Console_CommandLine for it to work...).
Chupaka
Re: perl API client
Wed Nov 20, 2013 4:10 pm
it was 4,5 years ago ;) read the next message: "Shortened names will not be allowed in 3.25+ versions"
akschu
Re: perl API client
Sat Nov 22, 2014 12:54 am
This is a bit of a hack, but I needed something in perl so I extended this code to use ssl. Attached is the module.
noyo
Re: perl API client
Sat Jan 10, 2015 2:11 pm
Why if you accidentally give ssh port is a connection. Do not hang up just waiting for something.
Contribution to IO::Socket::INET Timeout but it does not work.
davestahr
Re: perl API client
Sun Feb 15, 2015 7:26 pm
Thanks! This fixed a problem I've been having with perl API for years.
camlost
Re: perl API client
Thu May 07, 2015 10:31 am
Finally found this repo on github
Unfortunately, it's based on original cheesegrits module, withoud efaden modifications, so I created pull-request.
Maybe, we finally can maintain and download fresh and bug-free module from github.
davestahr
Re: perl API client
Thu May 07, 2015 2:48 pm
I know there's sometimes a financial nudge that can be given to people developing and maintaining open-source software. I'd like to offer that nudge to an individual or group who might be interested in further developing and refining this perl API. Anyone interested? I'm a perl programmer, but some of the API stuff is a bit beyond the scope of my talents.
efaden
Mon May 25, 2015 12:54 pm
What needs fixing? I'm still around. I'm happy to try to fix some bugs, especially if there is money involved.
davestahr
Re: perl API client
Mon May 25, 2015 6:08 pm
Thanks for the reply, I'm glad to hear someone with more skills than me is around on here! It might not be anything more than poor implementation of code on my part, or perhaps the the information simply isn't available from the API, but I'm having difficulty getting some of the hardware stats from system->resources, such as uptime. I don't have time at the moment to go dig up what I can't see, but I'll look into it and post back here when I've got the time.
efaden
Re: perl API client
Mon May 25, 2015 7:11 pm
Let's set up a repository somewhere... Then make sure we get the latest code on there (that I fixed)... then I can start to work on it again.
boen_robot
Re: perl API client
Mon May 25, 2015 7:13 pm
As camlost said above, there is a repo on GitHub, but without your modifications.
Maybe you could fork it, apply your mod, and keep maintaining it from that point (no PRs to the "original")?
efaden
Re: perl API client
Mon May 25, 2015 8:35 pm
Set up a new repository with my changes in it... https://github.com/efaden/MikroTikPerl
Let me know if you want access.
akschu
Re: perl API client
Thu Aug 27, 2015 9:54 pm
I think the code that Efaden put on github is probably the best bet since it fixes the length issue, as well as gives us a place to track change, but it didn't have port or ssl support. I forked his code and added those featuers:
https://github.com/akschu/MikroTikPerl
Efaden, please consider merging my pull request.
noyo
Re: perl API client
Thu Aug 27, 2015 10:01 pm
I modified it because some things were missing. Also, I added ssl. This can be done simply by reviewing client @akschu.
efaden
Re: perl API client
Thu Aug 27, 2015 11:25 pm
Merged. And added you as a collaborator.
camlost
Re: perl API client
Mon Sep 28, 2015 4:27 pm
I have plans and time to add object-oriented interface to module and publish it in CPAN.
2 efaden:
Will you accept PR which implelents it?
marting
Re: perl API client
Mon Dec 07, 2015 4:02 pm
Hi camlost,
did you make any progress and are you willing to share it?
I will have to do the same, the current version is nearly unusable in larger projects.
Regards
Martin
marting
Re: perl API client
Wed Dec 09, 2015 8:07 pm
I reworked it to OO and published it at github. See http://forum.mikrotik.com/viewtopic.php?f=9&t=102923 for more details.
hknet
Re: perl API client
Fri Aug 05, 2016 11:46 pm
well, I'm a bit lost, anyone knowing which perl API might be maintained?
it seems the later "MikroTik.pm" is no more working for scripts originally based on the "Mtik.pm" by Hugh.
our nagios checks use the older lib.
now I ran into a problem - I'm trying to implement something like:
/ip/route/print count where routing-mark=VRF
so we could alert if we loose routes or get a lot more than planned for :)
the printing works with our old-style Mtik.pm programming, but options like count and where?
any lead appreciated.
regards,
hk
efaden
Re: perl API client
Sat Aug 06, 2016 12:07 am
I haven't updated it in a while.... but
was working last time I looked.
bbs2web
Re: perl API client
Mon Jan 29, 2018 2:47 pm
Many thanks to all that have contributed to the MikroTik Perl API.
We previously used the ported OO version, as it had the nicest interface and was in CPAN (Comprehensive Perl Archive Network). We however needed to reduce overheads as the OO version utilises the Perl Moose library and subsequently retrieved the version the efaden posted and applied minimal changes from the OO ported version.
Perl OO version, in CPAN: https://metacpan.org/release/MikroTik-API
Latest patched version (efaden): https://github.com/efaden/MikroTikPerl
Herewith our version, which essentially makes minor changes to efaden's version:
API2.zip
Changes:
  • 3 second timeout on connections
  • specify whether or not you want SSL (efaden's would switch to SSL when port was 8729)
  • custom port specification (efaden's version couldn't use any port other than 8729 for SSL)
  • return '$retval' when not '!done', '!trap' or '!fatal'
Performance comparison:
  • OO version from CPAN (primarily due to it including the 'Moose' library):
    Total Elapsed Time = 2.998272 Seconds
      User+System Time = 0.508272 Seconds
  • efaden's version:
    Total Elapsed Time = 0.077465 Seconds
      User+System Time = 0.077465 Seconds
To install, create a directory such as '/usr/local/share/perl5/MikroTik' and place API2.pm in that directory. Then simply include 'use MikroTik::API2;' in your script.
For those converting from the OO version of the MikroTik API on CPAN to efaden's one, herewith a sample diff:
--- /usr/lib/zabbix/externalscripts/mikrotik-api-bgp_status_old.pl      2017-04-04 05:53:43.547467546 +0200
+++ /usr/lib/zabbix/externalscripts/mikrotik-api-bgp_status.pl  2018-01-28 08:50:56.437834735 +0200
@@ -1,10 +1,11 @@
 #!/usr/bin/perl
 use strict;
 use warnings;
-use MikroTik::API;     # http://search.cpan.org/~martingo/MikroTik-API/lib/MikroTik/API/Examples.pm
+use MikroTik::API2;    # https://github.com/efaden/MikroTikPerl/blob/master/MikroTik.pm
 use Fcntl qw(:flock);
 use Storable qw(lock_store lock_nstore lock_retrieve);
+my $use_ssl = 1;
 my ($router, $api_user, $api_passwd, $command, $peer, $key) = @ARGV;
 if (not defined $router) { print STDERR "Need router FQDN or IP, as first parameter.\n"; exit 3 };
 if (not defined $api_user) { print STDERR "Need MikroTik API username, as second parameter.\n"; exit 4 };
@@ -25,16 +26,6 @@
   return ($years*31536000)+($weeks*604800)+($days*86400)+($hours*3600)+($minutes*60)+$seconds;
-my $api = MikroTik::API->new (
-    host        => $router,
-    username    => $api_user,
-    password    => $api_passwd,
-    use_ssl     => 1,
-    autoconnect => 0,
 my %bgp_peer;
 my $cached = 0;
 my $modified = (stat($cachefile))[9];
@@ -46,10 +37,9 @@
 if ($cached == 0) {
   if (!flock $lockfile, LOCK_EX | LOCK_NB) { print STDERR "Another process is already using MikroTik API.\n"; exit 6 };
-  $api->connect();
-  $api->login();
-  %bgp_peer = $api->get_by_key('/routing/bgp/peer/print', 'name');
-  $api->logout();
+  MikroTik::login($router, $api_user, $api_passwd, $use_ssl);
+  %bgp_peer = MikroTik::get_by_key('/routing/bgp/peer/print', 'name');
+  MikroTik::logout;
   lock_nstore \%bgp_peer, $cachefile;
   chmod 0660, $cachefile;
   flock $lockfile, LOCK_UN;
bbs2web
Re: perl API client
Tue Jan 30, 2018 10:29 pm
The following is however again much faster:
real    0m0.003s
user    0m0.003s
sys     0m0.001s
An improvement of over 7700%.
We work around Perl's compilation overheads:
  • Convert script to TCP server which compiles once, listens on port 7890 and then forks children
  • Replace existing script with simple netcat wrapper:
    [root@zabbix ~]# /usr/lib/zabbix/externalscripts/mikrotik-api-bgp_status_client.sh 10.0.0.1 syrexnms 'FakeP@ssw0rd' -d; echo $?
            "data": [
                    { "{#BGPPEER}": "iOnline" }
    0
    [root@zabbix ~]# cat /usr/lib/zabbix/externalscripts/mikrotik-api-bgp_status_client.sh
    #!/bin/sh
    echo "'$1'" "'$2'" "'$3'" "'$4'" "'$5'" "'$6'" | /usr/bin/nc -w 3 127.0.0.1 7890;
    exit $?;
Changes to convert script itself to a standalone tcp server:
  • Alter all print statements (eg 'print', 'print STDERR', and 'printf') to output to '$client'
    -print STDERR "Another ...
    +print $client "Another ...
    -printf ("%-25.25s ...
    +printf $client ("%-25.25s ...
  • Encapsulate script's previous main section by starting with the following subroutine definition and appending '}'. These changes result in the tcp server reading up to 250 characters worth of commands, instead of them being supplied directly as script arguments:
    sub handle_client {
      my $client = shift;
      my $msg;
      $client->recv($msg, 250);
      my ($router, $api_user, $api_passwd, $command, $peer, $key) = quotewords('\s+', 0, $msg);
      #my ($router, $api_user, $api_passwd, $command, $peer, $key) = @ARGV;
  • New main body listens for tcp connections on port 7890 on the loopback adapter and forks child for each connection:
    use IO::Socket::INET;
    use Text::ParseWords;
    $SIG{CHLD} = 'IGNORE';
    STDOUT->autoflush(1);
    my $server = IO::Socket::INET->new(
      LocalAddr => '127.0.0.1',
      LocalPort => '7890',
      Listen    => SOMAXCONN,
      Type      => SOCK_STREAM,
      Reuse     => 1) or die "could not open port: $!";
    while (my $client = $server->accept) {
      next if my $pid = fork;
      die "fork: $!" unless defined $pid;
      $client->autoflush(1);
      close $server;
      handle_client($client);
    } continue {
      close $client;
mikrotik-api-bgp-status.zip
Contains:
  • init.d launch script for tcp server
  • perl tcp server which listens on port 7890 and connects to MikroTik using API to retrieve BGP peer status information. Information is cached for 55 seconds so speed up subsequent queries
  • client app which is really simply a netcat wrapper
Available commands:
Missing or invalid command. Usage /usr/lib/zabbix/externalscripts/mikrotik-api-bgp_status_client.sh <router> <api username> <api password> <command> [<peer>] :
  -d|--discover         Zabbix LLD (low level discovery). In JSON format.
  -c|--croak            Dumps all available data. Usable as $bgp_peer{'$peer'}->{'key'}
  -t|--table            Displays tabled overview
  -g|--get <peer> <key> example: -g "Syrex - Primary" state
  Examples:
    Discovery   : /usr/lib/zabbix/externalscripts/mikrotik-api-bgp_status_client.sh 10.0.0.1 syrexnms "FakeP@ssw0rd" -d
    Sample      : {
                    "data": [
                      { "{#BGPPEER}": "Syrex - Primary" },
                      { "{#BGPPEER}": "Syrex - Secondary" }
    Get item    : /usr/lib/zabbix/externalscripts/mikrotik-api-bgp_status_client.sh 10.0.0.1 syrexnms "FakeP@ssw0rd" "Syrex - Primary" state
    Sample      : established
Zabbix low level item discovery:
        "data": [
Tabled output:
[root@zabbix ~]# /usr/lib/zabbix/externalscripts/mikrotik-api-bgp_status_client.sh 10.0.0.1 syrexnms 'FakeP@ssw0rd' -t
Peer                      Active   Prefixes       Remote IP Remote AS             Uptime State
iOnline                   yes             2     172.18.0.17    327909       4w1d12h20m3s established
Dump all values (croak):
[root@zabbix ~]# /usr/lib/zabbix/externalscripts/mikrotik-api-bgp_status_client.sh 10.0.0.1 syrexnms 'FakeP@ssw0rd' -c
peer: iOnline
  .id=*0
  address-families=ip
  as-override=false
  as4-capability=true
  default-originate=if-installed
  disabled=false
  established=true
  hold-time=3m
  in-filter=ionline-in
  instance=mpls
  local-address=172.18.0.20
  multihop=false
  name=iOnline
  nexthop-choice=default
  out-filter=ionline-out
  passive=false
  prefix-count=2
  refresh-capability=true
  remote-address=172.18.0.17
  remote-as=329709
  remote-hold-time=3m
  remote-id=145.23.110.26
  remove-private-as=false
  route-reflect=false
  state=established
  tcp-md5-key=secret123
  ttl=default
  updates-received=6
  updates-sent=1
  uptime=4w1d12h21m3s
  use-bfd=false
  used-hold-time=3m
  used-keepalive-time=1m
  withdrawn-received=0
  withdrawn-sent=0
Retrieve specific item value (uptime in MikroTik format is converted to uptime seconds):
[root@zabbix ~]# /usr/lib/zabbix/externalscripts/mikrotik-api-bgp_status_client.sh 10.0.0.1 syrexnms 'FakeP@ssw0rd' -g iOnline uptime
2550183
Sample BGP peer uptime graph:
Sample BGP prefix activity graph:
Sample BGP status graph:
rafaelbarboza
Re: perl API client
Thu Apr 12, 2018 3:14 pm
@bbs2web, thank you!
It's possible to share this Zabbix Template for use?
savage
Re: perl API client
Thu Oct 31, 2019 10:16 am
Can we get these libs updated please?
They no longer work after the recent changes made by Mikrotik.
Regards,
Chris
useopenid
Re: perl API client
Thu Mar 05, 2020 12:49 am
According to the docs, the challenge/response login mechanism is no longer available after 6.45.1, however, 6.45.8 returns a challenge after sending the new username/password style parameters, and sending the md5 response results in "invalid username or password". Given that the connection is not encrypted, deprecating the challenge/response login is unfortunate.
Longsdale
Re: perl API client
Thu Mar 05, 2020 3:08 am
The legacy challenge-response authentication is not a measure of good protection. You can set the router to encrypt the connection.
Up to date C++ API connector https://github.com/zx2512/MikrotikPlus
useopenid
Re: perl API client
Thu Mar 05, 2020 3:18 am
OK, that's good to hear, now if the plain login actually worked...
abatie
Re: perl API client
Fri Mar 06, 2020 2:36 am
Never mind, I found a bug in the parameters I was passing...
Users browsing this forum: No registered users and 22 guests
