chrone
how to connect 192.168.0.1 and 192.168.1.1 (file sharing)
Fri Mar 28, 2008 7:20 am
dear all,
just tried routeros 2.9.27, how to set the router so this block of ip address 192.168.0.x and 192.168.1.x can connect eachother such as file sharing and so on?
thanks in advance! :)
aldalil
Re: how to connect 192.168.0.1 and 192.168.1.1 (file sharing)
Fri Mar 28, 2008 11:59 am
Hi chrone,
use a bridge-interface or bigger network subnet /16 (255.255.0.0.)
Regards,
Alaa
gmsmstr
Trainer
Trainer
Mon Mar 31, 2008 4:10 am
If you are doing, NetBios File sharing, usually, you will need to define a WINS server. Thats the simplest way. Else a Domain Controller etc. . . . But it will work across networks just have to have the windows components working. If you don't have a WINS or DNS server, then you can just use your IP address's directly. DON"T BRIDGE IT!
normis
Mon Mar 31, 2008 11:46 am
please use latest 3.6, upgrade is free of charge
