gimmepatiencequickly
A problem between 2 AP, with a distance of less than 3km
Sun Mar 30, 2008 11:04 am
Hello all,
I have been having a problem for quite some time now, between 2 AP's.
I have AP1, and AP2.
The registration table on AP1 says that AP2 is connected with a signal strength of -62dBM Signal to Noise is at 42dB.
The registration table on AP2 says that AP1 is connected with a signal strength of -58dBM Signal to Noise is at 39dB.
When I do a ping between the 2 AP's, the majority of the ping replies are an average of 11ms, but occasionally, I get large amounts of timeouts, or extremely high latency for up to 10 minutes at a time.
The puzzling thing is this...
AP1: run winbox ---- clk wireless ---- clk registration ---- dbl clk "AP2 connection".
the part where it says 'last ip' I assume it is suppose to say the ip address of AP2, which it does. -- 10.4.0.253, and it never changes, whereas...
AP2: run winbox ---- clk wireless ---- clk registration ---- dbl clk "AP1 connection".
the part where it says 'last ip' occasionally -and that is when I get 0(zero) timeouts- it says the ip address of AP1 --- 10.4.0.254, but it changes constantly, and it changes to an ip address that a client is accessing on the internet, or if i do remote administration from home, it will change to an ip address on the network, like my server at the office.
Regardless of what it my change to, that is when I get a constant timeout.
Also, it seems to timeout allot when there is a burst in data, for instance if I try to access a pc at my office using explorer (\\10.254.0.6\e$) I get timeouts, but as I am typing this I am actually copying something from that same pc, and I get 0 timeouts. (I am using Copy Handler)
Just for interest sake, I am seeing all the info from home, at this moment sometimes from office, but the connection between home and AP2 never times out, with an average of 9ms.
I would like to put my configuration here, but it is a huge amount, so I exported my config, and saved it to a file, which I will attach. ok nevermind, I will post it here.... it says the extension is not allowed .txt, and it says the same thing when i do not use an extension.
AP1 CONFIG
[admin@VCOMP] > export
# jan/30/2000 03:52:46 by RouterOS 2.9.50
# software id = REMOVED FOR MY PARANOIA
/ interface ethernet
set ether1 name="ether1" mtu=1500 mac-address=00:0C:42:04:47:12 arp=enabled disable-running-check=yes auto-negotiation=yes full-duplex=yes \
    cable-settings=default mdix-enable=yes speed=100Mbps comment="" disabled=no
set ether2 name="ether2" mtu=1500 mac-address=00:0C:42:04:47:13 arp=enabled disable-running-check=yes auto-negotiation=yes full-duplex=yes \
    cable-settings=default speed=100Mbps comment="" disabled=no
set ether3 name="ether3" mtu=1500 mac-address=00:0C:42:04:47:14 arp=enabled disable-running-check=yes auto-negotiation=yes full-duplex=yes \
    cable-settings=default speed=100Mbps comment="" disabled=yes
/ interface wireless
set WOWCOMPCIVICGRID name="WOWCOMPCIVICGRID" mtu=1500 mac-address=00:0B:6B:37:1A:08 arp=enabled disable-running-check=no radio-name="WOWCOMPCIVICGRID" \
    mode=bridge ssid="WOWCOMPWDS" area="" frequency-mode=manual-txpower country="south africa" antenna-gain=0 frequency=2437 band=2.4ghz-onlyg \
    scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
    basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default \
    periodic-calibration=default periodic-calibration-interval=60 burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=static \
    wds-default-bridge=wdsjunkbridge wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled default-authentication=no \
    default-forwarding=no default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25 hide-ssid=no security-profile=default \
    disconnect-timeout=3s on-fail-retry-time=100ms hw-retries=15 preamble-mode=both compression=no allow-sharedkey=no comment="" disabled=no
set wlan2 name="wlan2" mtu=1500 mac-address=00:0B:6B:37:1B:44 arp=enabled disable-running-check=no radio-name="VCompSector2" mode=ap-bridge \
    ssid="VComp/Sector2" area="" frequency-mode=manual-txpower country="south africa" antenna-gain=0 frequency=2427 band=2.4ghz-b/g scan-list=default \
    periodic-calibration=default periodic-calibration-interval=60 burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled \
    wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled default-authentication=no \
set wlan3 name="wlan3" mtu=1500 mac-address=00:80:48:56:5F:41 arp=enabled disable-running-check=no radio-name="VCompSector3" mode=ap-bridge \
    ssid="VCOMP/Sector3" area="" frequency-mode=manual-txpower country="south africa" antenna-gain=0 frequency=2447 band=2.4ghz-b/g scan-list=default \
    periodic-calibration=default periodic-calibration-interval=60 burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=static wds-default-bridge=none \
    wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled default-authentication=no default-forwarding=no \
    default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25 hide-ssid=no security-profile=default disconnect-timeout=3s \
/ interface wireless nstreme
set WOWCOMPCIVICGRID enable-nstreme=no enable-polling=yes framer-policy=none framer-limit=3200
set wlan2 enable-nstreme=no enable-polling=yes framer-policy=none framer-limit=3200
set wlan3 enable-nstreme=no enable-polling=yes framer-policy=none framer-limit=3200
/ interface wireless manual-tx-power-table
set WOWCOMPCIVICGRID manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17
set wlan2 manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17
set wlan3 manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17
/ interface wireless security-profiles
set default name="default" mode=none authentication-types="" unicast-ciphers="" group-ciphers="" wpa-pre-shared-key="" wpa2-pre-shared-key="" \
    tls-mode=no-certificates tls-certificate=none static-algo-0=none static-key-0="" static-algo-1=none static-key-1="" static-algo-2=none static-key-2="" \
    static-algo-3=none static-key-3="" static-transmit-key=key-0 static-sta-private-algo=none static-sta-private-key="" radius-mac-authentication=no \
    group-key-update=5m
/ interface wireless wds
add name="junkwds" mtu=1500 arp=enabled disable-running-check=no master-interface=WOWCOMPCIVICGRID wds-address=00:80:48:55:A7:51 comment="" disabled=no
/ interface wireless align
set frame-size=300 active-mode=yes receive-all=no audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 ssid-all=no frames-per-second=25 audio-min=-100 \
    audio-max=-20
/ interface wireless connect-list
add interface=WOWCOMPCIVICGRID connect=yes mac-address=00:80:48:55:A7:51 ssid="WOWCOMPWDS" min-signal-strength=-120 area-prefix="" security-profile=default \
/ interface wireless access-list
add mac-address=00:02:6F:40:C7:29 interface=wlan3 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none private-key="" \
    comment="004008 Smit" disabled=no
add mac-address=00:80:48:7E:B1:83 interface=wlan3 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none private-key="" \
    comment="004014 Strydom" disabled=no
add mac-address=00:80:48:47:6F:25 interface=wlan3 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none private-key="" \
    comment="004004 Fouche" disabled=no
add mac-address=00:80:48:55:A7:7B interface=wlan3 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none private-key="" \
    comment="004007 Oosthuizen" disabled=no
add mac-address=00:80:48:7E:B1:B9 interface=wlan3 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none private-key="" \
    comment="004016 Pand" disabled=no
add mac-address=00:80:48:55:A7:78 interface=wlan3 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none private-key="" \
    comment="Ruth" disabled=no
add mac-address=00:02:6F:43:38:E4 interface=wlan3 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none private-key="" \
    comment="004011 Bosch" disabled=no
add mac-address=00:02:6F:40:C9:BD interface=wlan3 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none private-key="" \
    comment="004001 Afriscapes" disabled=no
add mac-address=00:80:48:55:AC:79 interface=wlan3 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none private-key="" \
    comment="OWNER BOYD" disabled=no
add mac-address=00:19:F6:00:03:F6 interface=wlan3 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none private-key="" \
    comment="004012 Jones" disabled=no
add mac-address=00:80:48:55:A7:51 interface=WOWCOMPCIVICGRID authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none \
    private-key="" comment="JUNK RELAY" disabled=no
add mac-address=00:80:48:55:A6:59 interface=wlan3 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none private-key="" \
    comment="OWNER FOURIE" disabled=no
add mac-address=00:19:F6:00:04:50 interface=wlan3 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none private-key="" \
    comment="004015 Quick" disabled=no
add mac-address=00:80:48:55:AE:33 interface=wlan3 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none private-key="" \
    comment="Chen" disabled=no
add mac-address=00:0B:6B:37:1B:4F interface=wlan3 authentication=no forwarding=no ap-tx-limit=0 client-tx-limit=0 private-algo=none private-key="" comment="" \
    disabled=no
add mac-address=00:19:F6:00:04:50 interface=wlan2 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none private-key="" \
/ interface wireless snooper
set multiple-channels=yes channel-time=200ms receive-errors=no
/ interface wireless sniffer
set multiple-channels=no channel-time=200ms only-headers=no receive-errors=no memory-limit=10 file-name="" file-limit=10 streaming-enabled=no \
    streaming-server=0.0.0.0 streaming-max-rate=0
/ interface l2tp-server server
set enabled=no max-mtu=1460 max-mru=1460 authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption
/ interface pptp-server server
set enabled=no max-mtu=1460 max-mru=1460 authentication=mschap1,mschap2 keepalive-timeout=30 default-profile=default-encryption
/ interface bridge
add name="wdsjunkbridge" mtu=1500 arp=enabled stp=no priority=32768 ageing-time=5m forward-delay=15s garbage-collection-interval=5s hello-time=2s \
    max-message-age=20s comment="" disabled=no
/ interface bridge port
add interface=junkwds bridge=wdsjunkbridge priority=128 path-cost=10 comment="" disabled=no
add interface=WOWCOMPCIVICGRID bridge=wdsjunkbridge priority=128 path-cost=10 comment="" disabled=no
/ ip pool
add name="dhcp_pool2" ranges=10.254.0.21-10.254.0.30
/ ip ipsec proposal
add name="default" auth-algorithms=sha1 enc-algorithms=3des lifetime=30m lifebytes=0 pfs-group=modp1024 disabled=no
/ ip proxy
set enabled=no src-address=0.0.0.0 port=8080 parent-proxy=0.0.0.0:0 cache-administrator="webmaster" max-disk-cache-size=none max-ram-cache-size=unlimited \
    cache-only-on-disk=no maximal-client-connections=1000 maximal-server-connections=1000 max-object-size=4096KiB max-fresh-time=3d
/ ip proxy access
add dst-port=23-25 action=deny comment="block telnet & spam e-mail relaying" disabled=no
/ ip hotspot service-port
set ftp ports=21 disabled=no
/ ip hotspot profile
set default name="default" hotspot-address=0.0.0.0 dns-name="" html-directory=hotspot rate-limit="" http-proxy=0.0.0.0:0 smtp-server=0.0.0.0 \
    login-by=cookie,http-chap http-cookie-lifetime=3d split-user-domain=no use-radius=no
/ ip hotspot user profile
set default name="default" idle-timeout=none keepalive-timeout=2m status-autorefresh=1m shared-users=1 transparent-proxy=yes open-status-page=always \
    advertise=no
/ ip dhcp-server
add name="dhcp1" interface=ether2 lease-time=3d address-pool=dhcp_pool2 bootp-support=static authoritative=after-2sec-delay disabled=no
/ ip dhcp-server config
set store-leases-disk=5m
/ ip dhcp-server lease
/ ip dhcp-server network
add address=10.254.0.0/16 gateway=10.254.0.254 dns-server=10.0.0.1 comment=""
/ ip route
add dst-address=0.0.0.0/0 gateway=10.0.0.1 distance=1 scope=255 target-scope=10 comment="" disabled=no
add dst-address=10.5.0.0/16 gateway=10.4.0.253 distance=1 scope=255 target-scope=10 comment="" disabled=no
add dst-address=192.168.0.239/32 gateway=10.4.0.253 distance=1 scope=255 target-scope=10 comment="" disabled=no
/ ip service
set telnet port=23 address=0.0.0.0/0 disabled=no
set ftp port=21 address=0.0.0.0/0 disabled=no
set www port=80 address=0.0.0.0/0 disabled=no
set ssh port=22 address=0.0.0.0/0 disabled=no
set www-ssl port=443 address=0.0.0.0/0 certificate=none disabled=yes
/ ip upnp
set enabled=no allow-disable-external-interface=yes show-dummy-rule=yes
/ ip arp
/ ip socks
set enabled=no port=1080 connection-idle-timeout=2m max-connections=200
/ ip dns
set primary-dns=10.0.0.1 secondary-dns=196.43.1.11 allow-remote-requests=yes cache-size=2048KiB cache-max-ttl=1w
/ ip traffic-flow
set enabled=no interfaces=all cache-entries=4k active-flow-timeout=30m inactive-flow-timeout=15s
/ ip address
add address=10.2.0.254/16 network=10.2.0.0 broadcast=10.2.255.255 interface=wlan2 comment="" disabled=no
add address=10.3.0.254/16 network=10.3.0.0 broadcast=10.3.255.255 interface=wlan3 comment="" disabled=no
add address=10.0.0.254/16 network=10.0.0.0 broadcast=10.0.255.255 interface=ether1 comment="" disabled=no
add address=10.4.0.254/16 network=10.4.0.0 broadcast=10.4.255.255 interface=wdsjunkbridge comment="" disabled=no
add address=10.254.0.254/16 network=10.254.0.0 broadcast=10.254.255.255 interface=ether2 comment="" disabled=no
/ ip accounting
set enabled=no account-local-traffic=no threshold=256
/ ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
/ ip neighbor discovery
set ether1 discover=yes
set ether2 discover=yes
set ether3 discover=yes
set WOWCOMPCIVICGRID discover=yes
set wlan2 discover=yes
set wlan3 discover=yes
set junkwds discover=yes
set wdsjunkbridge discover=yes
/ ip firewall nat
add chain=srcnat action=masquerade comment="" disabled=no
/ ip firewall filter
add chain=forward action=drop comment="Drop all connections" disabled=yes
add chain=forward action=drop p2p=all-p2p in-interface=wlan3 comment="Drop P2P" disabled=no
add chain=forward action=drop p2p=all-p2p in-interface=ether1 comment="Drop all P2P" disabled=no
add chain=forward action=accept connection-state=established comment="allow established connections" disabled=no
add chain=forward action=accept connection-state=related comment="allow related connections" disabled=no
add chain=forward action=drop connection-state=invalid comment="drop invalid connections" disabled=no
add chain=virus action=drop dst-port=81 protocol=tcp comment="Drop Bagle az bb bd" disabled=no
add chain=virus action=drop dst-port=82 protocol=tcp comment="Drop Netsky x" disabled=no
add chain=virus action=drop dst-port=135-139 protocol=tcp comment="Drop Blaster Worm" disabled=no
add chain=virus action=drop dst-port=135-139 protocol=udp comment="Drop Messenger Worm" disabled=no
add chain=virus action=drop dst-port=445 protocol=tcp comment="Drop Blaster Worm" disabled=yes
add chain=virus action=drop dst-port=445 protocol=udp comment="Drop Blaster Worm" disabled=no
add chain=virus action=drop dst-port=593 protocol=tcp comment="________" disabled=no
add chain=virus action=drop dst-port=665 protocol=tcp comment="Drop Netsky z" disabled=no
add chain=virus action=drop dst-port=1024-1030 protocol=tcp comment="________" disabled=no
add chain=virus action=drop dst-port=1034 protocol=tcp comment="Drop MyDoom o bb" disabled=no
add chain=virus action=drop dst-port=1042 protocol=tcp comment="Drop Mydoom n" disabled=no
add chain=virus action=drop dst-port=1080 protocol=tcp comment="Drop MyDoom b f g h, Bugbear b, Bagle af ag ai" disabled=no
add chain=virus action=drop dst-port=1214 protocol=tcp comment="________" disabled=no
add chain=virus action=drop dst-port=1234 protocol=tcp comment="Drop Bagle ad" disabled=no
add chain=virus action=drop dst-port=1363 protocol=tcp comment="ndm requester" disabled=no
add chain=virus action=drop dst-port=1364 protocol=tcp comment="ndm server" disabled=no
add chain=virus action=drop dst-port=1368 protocol=tcp comment="screen cast" disabled=no
add chain=virus action=drop dst-port=1373 protocol=tcp comment="hromgrafx" disabled=no
add chain=virus action=drop dst-port=1377 protocol=tcp comment="cichlid" disabled=no
add chain=virus action=drop dst-port=1433-1434 protocol=tcp comment="Worm" disabled=no
add chain=virus action=drop dst-port=1549 protocol=tcp comment="Netsky y" disabled=no
add chain=virus action=drop dst-port=1639 protocol=tcp comment="MyDoom ah" disabled=no
add chain=virus action=drop dst-port=2283 protocol=tcp comment="Drop Dumaru.Y" disabled=no
add chain=virus action=drop dst-port=2339 protocol=tcp comment="Drop   Bagle bj bk" disabled=no
add chain=virus action=drop dst-port=2745 protocol=tcp comment="Bagle Virus" disabled=no
add chain=virus action=drop dst-port=2535 protocol=tcp comment="Drop Beagle" disabled=no
add chain=virus action=drop dst-port=2745 protocol=tcp comment="Drop Beagle.C-K" disabled=no
add chain=virus action=drop dst-port=3127-3128 protocol=tcp comment="Drop MyDoom" disabled=no
add chain=virus action=drop dst-port=3332 protocol=tcp comment="Drop   Cycle a" disabled=no
add chain=virus action=drop dst-port=3410 protocol=tcp comment="Drop Backdoor OptixPro" disabled=no
add chain=virus action=drop dst-port=4444 protocol=tcp comment="Worm" disabled=no
add chain=virus action=drop dst-port=4444 protocol=udp comment="Worm" disabled=no
add chain=virus action=drop dst-port=4751 protocol=tcp comment="Drop Bagle v" disabled=no
add chain=virus action=drop dst-port=5503 protocol=tcp comment="Drop Rst a" disabled=no
add chain=virus action=drop dst-port=5554 protocol=tcp comment="Drop Sasser" disabled=no
add chain=virus action=drop dst-port=6000 protocol=tcp comment="Drop Lovgate v" disabled=no
add chain=virus action=drop dst-port=6777 protocol=tcp comment="Drop Bagle a" disabled=no
add chain=virus action=drop dst-port=6789 protocol=tcp comment="Drop Netsky s t u" disabled=no
add chain=virus action=drop dst-port=7094 protocol=tcp comment="Drop Mutbo a" disabled=no
add chain=virus action=drop dst-port=8181 protocol=tcp comment="Drop Zafi d" disabled=no
add chain=virus action=drop dst-port=8594 protocol=tcp comment="Drop IRCbot.worm!MS05-039" disabled=no
add chain=virus action=drop dst-port=8866 protocol=tcp comment="Drop Beagle.B" disabled=no
add chain=virus action=drop dst-port=9030 protocol=tcp comment="Drop Bagle cb" disabled=no
add chain=virus action=drop dst-port=9898 protocol=tcp comment="Drop Dabber.A-B" disabled=no
add chain=virus action=drop dst-port=9995 protocol=tcp comment="Drop Sasser d" disabled=no
add chain=virus action=drop dst-port=9996 protocol=tcp comment="Drop Sasser a b c f" disabled=no
add chain=virus action=drop dst-port=10000 protocol=tcp comment="Drop Dumaru.Y" disabled=no
add chain=virus action=drop dst-port=10080 protocol=tcp comment="Drop MyDoom.B" disabled=no
add chain=virus action=drop dst-port=11768 protocol=tcp comment="Drop DipNet b" disabled=no
add chain=virus action=drop dst-port=12345 protocol=tcp comment="Drop NetBus" disabled=no
add chain=virus action=drop dst-port=17300 protocol=tcp comment="Drop Kuang2" disabled=no
add chain=virus action=drop dst-port=27374 protocol=tcp comment="Drop SubSeven" disabled=no
add chain=virus action=drop dst-port=33333 protocol=tcp comment="Drop Zotob a b c" disabled=no
add chain=virus action=drop dst-port=65506 protocol=tcp comment="Drop PhatBot, Agobot, Gaobot" disabled=no
add chain=forward action=jump jump-target=virus comment="jump to the virus chain" disabled=no
add chain=forward action=accept dst-port=80 protocol=tcp comment="Allow HTTP" disabled=no
add chain=forward action=accept dst-port=25 protocol=tcp comment="Allow SMTP" disabled=no
add chain=forward action=accept protocol=tcp comment="allow TCP" disabled=no
add chain=forward action=accept protocol=icmp comment="allow ping" disabled=no
add chain=forward action=accept protocol=udp comment="allow udp" disabled=no
add chain=forward action=drop comment="drop everything else" disabled=no
/ ip firewall service-port
set tftp ports=69 disabled=no
set irc ports=6667 disabled=no
set h323 disabled=no
set quake3 disabled=no
set gre disabled=no
set pptp disabled=no
/ ip firewall connection tracking
set enabled=yes tcp-syn-sent-timeout=5s tcp-syn-received-timeout=5s tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-close-wait-timeout=10s \
    tcp-last-ack-timeout=10s tcp-time-wait-timeout=10s tcp-close-timeout=10s udp-timeout=10s udp-stream-timeout=3m icmp-timeout=10s generic-timeout=10m \
    tcp-syncookie=no
/ system ntp server
set enabled=no broadcast=no multicast=no manycast=yes
/ system ntp client
set enabled=yes mode=unicast primary-ntp=143.128.82.200 secondary-ntp=146.64.241.229
/ system routerboard settings
set baud-rate=115200 boot-delay=1s boot-device=nand-if-fail-then-ethernet enter-setup-on=any-key cpu-mode=power-save memory-test=no cpu-frequency=264MHz \
    boot-protocol=bootp enable-jumper-reset=yes
/ system logging
add topics=info prefix="" action=disk disabled=no
add topics=critical,error,warning,firewall prefix="" action=disk disabled=no
/ system logging action
set memory name="memory" target=memory memory-lines=100 memory-stop-on-full=no
set disk name="disk" target=disk disk-lines=10000 disk-stop-on-full=no
set echo name="echo" target=echo remember=yes
set remote name="remote" target=remote remote=10.0.0.206:514
/ system upgrade mirror
set enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0 check-interval=1d user=""
/ system clock manual
set time-zone=+00:02 dst-delta=+01:00 dst-start="jan/01/1970 00:00:00" dst-end="jan/01/1970 00:00:00"
/ system watchdog
set reboot-on-failure=yes watch-address=none watchdog-timer=yes no-ping-delay=5m automatic-supout=yes auto-send-supout=no
/ system console
add port=serial0 term="vt102" disabled=no
/ system identity
set name="VCOMP"
/ system note
set show-at-login=yes note=""
/ port
set serial0 name="serial0" baud-rate=auto data-bits=8 parity=none stop-bits=1 flow-control=hardware
/ ppp profile
set default name="default" use-compression=default use-vj-compression=default use-encryption=default only-one=default change-tcp-mss=default comment=""
set default-encryption name="default-encryption" use-compression=default use-vj-compression=default use-encryption=yes only-one=default change-tcp-mss=default \
    comment=""
/ ppp aaa
set use-radius=no accounting=yes interim-update=0s
/ queue type
set default name="default" kind=pfifo pfifo-limit=50
set ethernet-default name="ethernet-default" kind=pfifo pfifo-limit=50
set wireless-default name="wireless-default" kind=sfq sfq-perturb=5 sfq-allot=1514
set synchronous-default name="synchronous-default" kind=red red-limit=60 red-min-threshold=10 red-max-threshold=50 red-burst=20 red-avg-packet=1000
set hotspot-default name="hotspot-default" kind=sfq sfq-perturb=5 sfq-allot=1514
add name="default-small" kind=pfifo pfifo-limit=10
/ queue interface
set ether1 queue=ethernet-default
set ether2 queue=ethernet-default
set ether3 queue=ethernet-default
set WOWCOMPCIVICGRID queue=wireless-default
set wlan2 queue=wireless-default
set wlan3 queue=wireless-default
set junkwds queue=wireless-default
set wdsjunkbridge queue=default
/ queue simple
add name="Boyd_ANT" target-addresses=10.3.0.2/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 queue=default-small/default-small \
    limit-at=0/0 max-limit=0/0 total-queue=default-small disabled=no
add name="MICROSOFT LIMIT" dst-address=65.52.0.0/14 interface=all parent=none direction=both priority=8 queue=default-small/default-small limit-at=0/0 \
    max-limit=0/0 total-queue=default-small disabled=yes
add name="P2P" dst-address=0.0.0.0/0 interface=ether1 parent=none direction=both priority=8 queue=default-small/default-small limit-at=0/0 \
    max-limit=33000/33000 total-queue=default-small p2p=all-p2p disabled=yes
add name="DHCP 28" target-addresses=10.254.0.28/32 dst-address=0.0.0.0/0 interface=ether2 parent=none direction=both priority=8 \
    queue=default-small/default-small limit-at=0/0 max-limit=0/0 total-queue=default-small disabled=no
add name="004011 Jacques Bosch" target-addresses=10.3.0.20/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 \
    queue=default-small/default-small limit-at=0/0 max-limit=20000/96000 total-queue=default-small disabled=no
add name="004013 Lodewikus Conradie I" target-addresses=10.3.0.42/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 \
    queue=default-small/default-small limit-at=0/0 max-limit=20000/128000 total-queue=default-small disabled=no
add name="004012 Chris Jones_PC" target-addresses=10.3.0.101/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 \
add name="004016 Ons Pand_ANT" target-addresses=10.3.0.10/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 \
add name="004004 Heidi Fouch _ANT" target-addresses=10.2.0.2/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 \
add name="004015 Anthony Quick_ANT" target-addresses=10.3.0.30/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 \
add name="004001 Afriscapes_I" target-addresses=10.3.0.19/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 \
add name="004001 Afriscapes_II" target-addresses=10.3.0.3/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 \
add name="004001 Afriscapes_ANT" target-addresses=10.3.0.18/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 \
add name="004012 Chris Jones_ANT" target-addresses=10.3.0.100/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 \
add name="004007 Sarel Oosthuizen" target-addresses=10.3.0.15/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 \
add name="004008 Johan J Smit_ANT" target-addresses=10.3.0.8/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 \
add name="004011 Jacques Bosch_PC" target-addresses=10.3.0.21/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 \
add name="004014 Jaco Strydom" target-addresses=10.3.0.200/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 \
add name="004013 Lodewikus Conradie II" target-addresses=10.3.0.43/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 \
add name="004005" dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 queue=default-small/default-small limit-at=0/0 max-limit=0/0 \
add name="004006" dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 queue=default-small/default-small limit-at=0/0 max-limit=0/0 \
add name="004009" dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 queue=default-small/default-small limit-at=0/0 max-limit=0/0 \
add name="004010" dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 queue=default-small/default-small limit-at=0/0 max-limit=0/0 \
add name="004017" dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 queue=default-small/default-small limit-at=0/0 max-limit=0/0 \
add name="004017 RUTH" target-addresses=10.3.0.1/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 \
add name="INET4" target-addresses=10.254.0.4/32 dst-address=0.0.0.0/0 interface=ether2 parent=none direction=both priority=8 queue=default-small/default-small \
add name="INET3" target-addresses=10.254.0.3/32 dst-address=0.0.0.0/0 interface=ether2 parent=none direction=both priority=8 queue=default-small/default-small \
add name="DHCP 22" target-addresses=10.254.0.22/32 dst-address=0.0.0.0/0 interface=ether2 parent=none direction=both priority=8 \
add name="DHCP 24" target-addresses=10.254.0.24/32 dst-address=0.0.0.0/0 interface=ether2 parent=none direction=both priority=8 \
/ tool user-manager customer
add subscriber=vcomp login="vcomp" password="pa2Sp0rt7" time-zone=+00:00 permissions=owner parent=vcomp comment="" disabled=no
/ tool bandwidth-server
set enabled=yes authenticate=yes allocate-udp-ports-from=2000 max-sessions=10
/ tool e-mail
set server=0.0.0.0 from="<>"
/ tool mac-server ping
set enabled=yes
/ tool sniffer
set interface=all only-headers=no memory-limit=10 file-name="" file-limit=10 streaming-enabled=no streaming-server=0.0.0.0 filter-stream=yes \
    filter-protocol=ip-only filter-address1=0.0.0.0/0:0-65535 filter-address2=0.0.0.0/0:0-65535
/ tool graphing
set store-every=5min
/ tool graphing interface
add interface=all allow-address=0.0.0.0/0 store-on-disk=yes disabled=no
/ user
add name="admin" group=full address=0.0.0.0/0 comment="system default user" disabled=no
/ user group
add name="read" policy=local,telnet,ssh,reboot,read,test,winbox,password,web,sniff,!ftp,!write,!policy
add name="write" policy=local,telnet,ssh,reboot,read,write,test,winbox,password,web,sniff,!ftp,!policy
add name="full" policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff
/ user aaa
set use-radius=no accounting=yes interim-update=0s default-group=read
/ routing ospf
set router-id=0.0.0.0 distribute-default=never redistribute-connected=no redistribute-static=no redistribute-rip=no redistribute-bgp=no metric-default=1 \
    metric-connected=20 metric-static=20 metric-rip=20 metric-bgp=20
/ routing ospf area
set backbone area-id=0.0.0.0 type=default translator-role=translate-candidate authentication=none disabled=no
/ routing bgp instance
set default name="default" as=1 router-id=0.0.0.0 redistribute-connected=no redistribute-static=no redistribute-rip=no redistribute-ospf=no \
    redistribute-other-bgp=no out-filter="" client-to-client-reflection=yes ignore-as-path-len=no comment="" disabled=no
/ routing rip
set distribute-default=never redistribute-static=no redistribute-connected=no redistribute-ospf=no redistribute-bgp=no metric-default=1 metric-static=1 \
    metric-connected=1 metric-ospf=1 metric-bgp=1 update-timer=30s timeout-timer=3m garbage-timer=2m
/ routing rip interface
add interface=all receive=v2 send=v2 authentication=none authentication-key="" key-chain="" in-filter="" out-filter="" disabled=no
/ radius incoming
set accept=no port=1700
/ snmp
set enabled=yes contact="" location=""
/ snmp community
set public name="public" address=0.0.0.0/0 read-access=yes
[admin@VCOMP] >
AP2 CONFIG
[admin@WOWCOMPJUNK] > export
# jan/12/2000 23:08:21 by RouterOS 2.9.50
set ether1 name="ether1" mtu=1500 mac-address=00:0C:42:22:54:09 arp=enabled disable-running-check=yes auto-negotiation=yes full-duplex=yes \
set ether2 name="ether2" mtu=1500 mac-address=00:0C:42:22:54:0A arp=enabled disable-running-check=yes auto-negotiation=yes full-duplex=yes \
set ether3 name="ether3" mtu=1500 mac-address=00:0C:42:22:54:0B arp=enabled disable-running-check=yes auto-negotiation=yes full-duplex=yes \
set WOWCOMPJUNKSECTOR1 name="WOWCOMPJUNKSECTOR1" mtu=1500 mac-address=00:80:48:56:5F:65 arp=enabled disable-running-check=no radio-name="WOWCOMPJUNKSECTOR1" \
    mode=ap-bridge ssid="WOWCOMPJUNKSECTOR1" area="" frequency-mode=manual-txpower country="south africa" antenna-gain=0 frequency=2472 band=2.4ghz-onlyg \
set WOWCOMPJUNKGRID name="WOWCOMPJUNKGRID" mtu=1500 mac-address=00:80:48:55:A7:51 arp=enabled disable-running-check=no radio-name="WOWCOMPJUNKGRID" \
    mode=ap-bridge ssid="WOWCOMPWDS" area="" frequency-mode=manual-txpower country="south africa" antenna-gain=0 frequency=2437 band=2.4ghz-onlyg \
set WOWCOMPJUNKSECTOR1 enable-nstreme=no enable-polling=yes framer-policy=none framer-limit=3200
set WOWCOMPJUNKGRID enable-nstreme=no enable-polling=yes framer-policy=none framer-limit=3200
set WOWCOMPJUNKSECTOR1 manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17
set WOWCOMPJUNKGRID manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17
    eap-methods=passthrough tls-mode=no-certificates tls-certificate=none static-algo-0=none static-key-0="" static-algo-1=none static-key-1="" \
    static-algo-2=none static-key-2="" static-algo-3=none static-key-3="" static-transmit-key=key-0 static-sta-private-algo=none static-sta-private-key="" \
    radius-mac-authentication=no group-key-update=5m
add name="junkwds" mtu=1500 arp=enabled disable-running-check=no master-interface=WOWCOMPJUNKGRID wds-address=00:0B:6B:37:1A:08 comment="" disabled=no
    audio-max=-20
add interface=WOWCOMPJUNKGRID connect=yes mac-address=00:0B:6B:37:1A:08 ssid="WOWCOMPWDS" min-signal-strength=-120 area-prefix="" security-profile=default \
add mac-address=00:80:48:55:A6:59 interface=WOWCOMPJUNKSECTOR1 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none \
    private-key="" comment="Fourie_owner" disabled=no
add mac-address=00:80:48:55:AE:33 interface=WOWCOMPJUNKSECTOR1 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none \
    private-key="" comment="Tony Chen" disabled=no
add mac-address=00:80:48:47:6F:25 interface=WOWCOMPJUNKSECTOR1 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none \
    private-key="" comment="Martie" disabled=no
/ interface bridge
add interface=WOWCOMPJUNKGRID bridge=wdsjunkbridge priority=128 path-cost=10 comment="" disabled=no
/ ip pool
add name="dhcp_pool1" ranges=192.168.0.2-192.168.0.254
/ ip ipsec proposal
/ ip route
add dst-address=0.0.0.0/0 gateway=10.4.0.254 distance=1 scope=255 target-scope=10 comment="" disabled=no
add dst-address=192.168.0.239/32 gateway=10.5.0.253 distance=1 scope=255 target-scope=10 comment="" disabled=yes
/ ip dhcp-server
add name="dhcp1" interface=ether1 lease-time=3d address-pool=dhcp_pool1 bootp-support=static authoritative=after-2sec-delay disabled=no
add address=192.168.0.0/24 gateway=192.168.0.1 dns-server=192.168.0.1 comment=""
    advertise=no
/ ip proxy
/ ip service
/ ip upnp
/ ip arp
/ ip socks
/ ip dns
set primary-dns=10.0.0.1 secondary-dns=10.3.0.254 allow-remote-requests=yes cache-size=2048KiB cache-max-ttl=1w
/ ip traffic-flow
/ ip address
add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=ether1 comment="" disabled=no
add address=10.5.0.254/16 network=10.5.0.0 broadcast=10.5.255.255 interface=WOWCOMPJUNKSECTOR1 comment="" disabled=no
add address=10.4.0.253/16 network=10.4.0.0 broadcast=10.4.255.255 interface=wdsjunkbridge comment="" disabled=no
/ ip accounting
set WOWCOMPJUNKSECTOR1 discover=yes
set WOWCOMPJUNKGRID discover=yes
/ ip firewall nat
add chain=forward action=accept p2p=all-p2p comment="P2P Connection Stats" disabled=no
add chain=forward action=accept dst-port=3724 protocol=tcp comment="WOW STATS" disabled=no
set h323 disabled=yes
set gre disabled=yes
set pptp disabled=yes
    tcp-syncookie=no
/ system ntp server
/ system ntp client
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet enter-setup-on=any-key cpu-mode=power-save memory-test=no cpu-frequency=175MHz \
/ system logging
add topics=error prefix="" action=disk disabled=no
add topics=warning prefix="" action=disk disabled=no
add topics=critical prefix="" action=disk disabled=no
add topics=firewall prefix="" action=disk disabled=no
add topics=wireless prefix="" action=disk disabled=no
set disk name="disk" target=disk disk-lines=100 disk-stop-on-full=no
set remote name="remote" target=remote remote=0.0.0.0:514
set time-zone=+02:00 dst-delta=+00:00 dst-start="jan/01/1970 00:00:00" dst-end="jan/01/1970 00:00:00"
/ system watchdog
/ system console
add port=serial0 term="" disabled=no
/ system identity
set name="WOWCOMPJUNK"
/ system note
/ port
set serial0 name="serial0" baud-rate=115200 data-bits=8 parity=none stop-bits=1 flow-control=none
/ ppp profile
set default name="default" use-compression=default use-vj-compression=default use-encryption=default only-one=default change-tcp-mss=yes comment=""
set default-encryption name="default-encryption" use-compression=default use-vj-compression=default use-encryption=yes only-one=default change-tcp-mss=yes \
    comment=""
/ ppp aaa
/ queue type
/ queue interface
set WOWCOMPJUNKSECTOR1 queue=wireless-default
set WOWCOMPJUNKGRID queue=wireless-default
/ queue simple
add name="MICROSOFT LIMIT" dst-address=65.52.0.0/14 interface=all parent=none direction=both priority=8 queue=default-small/default-small limit-at=33000/33000 \
    max-limit=33000/33000 total-queue=default-small disabled=yes
add name="ETHER" dst-address=0.0.0.0/0 interface=ether1 parent=none direction=both priority=8 queue=default-small/default-small limit-at=0/0 \
    max-limit=20000/56000 total-queue=default-small disabled=no
/ user
/ user group
/ user aaa
/ tool e-mail
set enabled=yes
/ tool sniffer
/ tool graphing
/ routing ospf
/ routing ospf area
/ routing ospf interface
set FIXME interface=WOWCOMPJUNKGRID cost=10 priority=1 authentication-key="" network-type=point-to-point retransmit-interval=5s transmit-delay=1s \
    hello-interval=10s dead-interval=40s
set default name="default" as=65530 router-id=0.0.0.0 redistribute-connected=no redistribute-static=no redistribute-rip=no redistribute-ospf=no \
/ routing rip
/ radius incoming
/ snmp
set enabled=no contact="" location=""
/ snmp community
As you can see in the config, I even tried routing.
I would appreciate any help.
Thank you
Ibersystems
Re: A problem between 2 AP, with a distance of less than 3km
Mon Apr 07, 2008 11:59 pm
I have the same problem in a tower with a lot of interferences. Signal and registration were very good but problems with pings. Try to put less power in TX power. Menu wireless. It works for me.
Regards,
Martín.
Tue Apr 08, 2008 4:58 pm
Thank you for your reply, Ibersystems
I would appreciate it if you tell me your power settings, I have never set them before, so they are on default, which I assume is 17dBm
Thank you
Defer not till tomorrow to be wise, tomorrow's sun to thee may never
rise.
--- William Congreve
Ibersystems
Tue Apr 08, 2008 5:22 pm
you have to try. You can put 16, 14, 12, 10... 0 of TX power. It changes fast.
If you have 100 mW the top is 17. A 600 mw card is 28.
Martín
Wed Apr 09, 2008 4:20 pm
ok, thank you...
Have you also noticed, that the timeouts are also more prominent and frequent during the day?
My Grid antennae are East and West facing, so in the Morning at about 6:30, is when the timeouts start and pretty bad during the day.
It still happens at night, but not as bad.
Thank you
rise.
Users browsing this forum: pe1chl and 35 guests
