svasseur
iphone and the dude
Thu Apr 03, 2008 10:58 am
juste for fun ( and work of course ) theDude work on iphone
sergejs
Re: iphone and the dude
Thu Apr 03, 2008 1:36 pm
Nice !
Thank you for sharing.
keith
Fri Apr 04, 2008 7:33 pm
What version of the dude are you using. It looks way different from mine.
Tsiera
Mon Apr 07, 2008 12:22 pm
i think its the webinterface
huri
Mon Apr 07, 2008 6:24 pm
yes this is the web interface opened trought iPhone Safari Browser.
I use iPhone from September, and the view of the web interface is cool :) thanks to all developers ;)
ojos626
Mon Apr 14, 2008 4:59 pm
Hi I havent had my iPhone that long and was wondering how I get the dude on to it, as it would be realy handy for monotoring my network out and about
P.s. My iphone is completeley unblocked
Jake :D
talon63
Mon Apr 14, 2008 6:28 pm
You should be able to access The Dude by it's IP address through your web browser, if the IP is a public one.
"Technology is dominated by two types of people: those who understand what they do not manage, and those who manage what they do not understand." - Putt's Law
miles
Tue Aug 24, 2010 1:06 am
Hi svasseur
I have setup Dude Server on Win 2003 and works just fine. I have installed I Dude in iphone and i wanted to monitor my network on iphone. My server in local but i have port forwad on the public ip address to local ip addres which is win 2003 ip .
But on the iphone tell me to type XML URL and password.
XML URL means public ip address and password means dude password.
If you can help on this.
thx
Selim
abdonetwork
Thu Sep 02, 2010 1:56 pm
hi ...
Yes i'm looking to know how i can config the iphone dude ???
any one can tell us plz ?
lebowski
Thu Sep 02, 2010 5:30 pm
All they are doing is pulling up the web page of the dude.
Connect your phone to your company wifi and then browse to the server...
abdonetwork
Thu Sep 02, 2010 8:54 pm
ok i mean when dude built to be compatibility for Apple Iphone that mean theres must be Clarify and explain how to correct installation
anyway i got it from "App Store" in my Iphone
then it's installed
BUT ......
:shock: HOW I CAN CONFIG IT TO MY IPHONE :shock: PLZ
normis
Fri Sep 03, 2010 7:50 am
We didn't make this program, I have never heard about it.
abdonetwork
Fri Sep 03, 2010 12:57 pm
Well, nice words
So this site for technical support and exchange of experiences and ideas must be put on each of the poses the idea illustrated
And if the idea is supposed to complete the team based on this site that have a role either in the application of the idea that illustrated or revoke participation in order not to take time and effort members
normis
Fri Sep 03, 2010 1:04 pm
yes
abdonetwork
Fri Sep 03, 2010 1:20 pm
thank you :)
lebowski
Fri Sep 03, 2010 5:10 pm
I stand corrected... that looks like a real app. I don't have an iphone to test with.
I will check it out as soon as I can borrow a phone :)
lebowski
Fri Sep 03, 2010 6:07 pm
The app some basic description of its functions, I installed it on a co-workers phone. After seeing the instructions and the low rating I decided to uninstall it.
I found the app listed as it should be at the iphone store.
http://itunes.apple.com/us/app/i-dude/id368416112?mt=8
Description
This application allows you to connect to different servers Mikrotik Dude to keep eyes on your network.
The Dude network monitor is a great new application by MikroTik which can successfully improve the way you manage your network environment. With iDude, you can automatically discover the network to monitor the status of your services and server. You can now connect you from anywhere on the application Dude. And then view the different states of servers and services and directly consult the MAP of your network.
You also have the ability to easily add a xml file hosted on your server, add test sites accessible directly from your iPhone.
Note the use of this application requires php to put on the server that hosts Dude. Please don’t hesitate to contact us for more information.
To configure the tests links, information pages or connection information for Dude. You need to set up the XML file in format "Apple plist" on your server.
I didn't want to add php to my server or change the XML format...
The support page http://www.axianet.ch/iphone_idude.htm
abdonetwork
Fri Sep 03, 2010 8:57 pm
Ok sir
my mikrotik rauter ip is 10.0.0.139 and user is:123 the password:123
just tell my step by step as we need like any program
or I'm going to be stubed :) ... If you acttch some pics that will be more nice from you
thank you
normis
Mon Sep 06, 2010 10:47 am
we didn't make this program, and we don't know how to use it. please contact the developer for help.
axianetch
Sat Feb 05, 2011 9:41 pm
I finally released the 2.0 version of iDude.
It’s a Full update of the program, a lot of new feature :
- Direct connection to the Web service of Mikrotik Dude, no more need PHP script.
- Easy to add and delete Dude connections directly from the application
- Added icons and images in HD for iPhone 4 with Retina display
- Added a adapted version for the iPad
- Added multi-tasking, now the application stay open
- Now it is possible to display several maps network automatically according to the config of Mikrotik Dude.
The update is free for all user of the iDude 1.0 !
Don’t hesitate to contact me for any question or remark.
The app store link : http://itunes.apple.com/app/i-dude/id368416112?mt=8
axianetch
Thu Mar 24, 2011 11:49 am
A new update for iDude :
- Change status icons adapted to screens Retina
- Added devices in unknown or Acked status
- The devices is now sort by Maps
- Added Edit button to edit items
- Added a filter by status for devices (all, up, down, down partiallay, ACKed, unknown)
mohdhizami
Sat Jul 30, 2011 12:31 pm
hi ...
1. Open the dude on your pc--> open setting --> server --> web server -- and tip enable <--- ok and close the dude
2 open idude on your iphone or ipad
Example how to add
URL: Http://172.27.1.1:81
User: admin
Password: xxxx
Done...
Now you can Monitor your idude...
pjulian
Thu May 31, 2012 4:45 pm
This really is crap, the application doesn't see to work, the support link AND website link for the developer which are listed in iTunes don't work either.
This app should be reported to iTunes as a DUD as there is NO support, what a ripoff
Paetur
iphone and the dude
Thu May 31, 2012 10:58 pm
Don't know about the support or webpage. But I have it installed on my iPad and iPhone, and it works.
If you can reach TheDude server from a browser, you can use this app.
/Paetur
Sent from my iPhone using Tapatalk
chenczl
Thu Sep 13, 2012 12:05 pm
Hello, may I ask if someone provides a free iphone client.Would like to test the effect of what
Thank you!
Fadeluc
Wed Jul 29, 2015 11:51 am
Hello
Try the idude and not work, may be the new version of iOS, now running 8.02. Some body had experience or know a version that work?
That you
Users browsing this forum: No registered users and 9 guests
