baumie
parameters for scripting
Sat Apr 05, 2008 2:22 pm
Hi
I want to know if there's a way of passing parameters to a MT script. For instance I want to change the rate-limits for centain user groups can I write one script and get the limits from parameters passed to the script or must I do a script for each rate limit and group
mrz
Re: parameters for scripting
Mon Apr 07, 2008 9:33 am
You can use global variables, for example,
simple script "myScript":
:global myVar;
:put &myVar;
Before calling "myScript" set "myVar" value:
:global myVar 999;
/system script run myScript;
baumie
Thu Apr 10, 2008 9:38 am
Thanks I never thought of that but it will solve my problem
Etz
Wed Feb 13, 2019 12:13 am
Sorry for necro posting, but how do you pass multiple parameters to script?
Would this work?:
:global myVar1 999;
:global myVar2 9999;
Considering that MyScript has global scope variables MyVar1 and MyVar2 present?
Jotne
Wed Feb 13, 2019 4:25 pm
Should work as long as you declare your global variables in the sub script like this:
:global myVar1
:global myVar2
PS, you do not need ut use ; at the end of the line, only to separate multiple commands at the same line.
So your script could be written:
:global myVar1 999
:global myVar2 9999
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
A9691
Thu Sep 12, 2019 4:24 pm
You can pass parameters to script files run with /import. For example:
Content of fact.rsc:
:if ($1 > 1) do={
	:global fact
	:set $result ([$fact ( $1 - 1 )]*($1))
} else={
	:set $result 1
Define fact function:
:global fact do={/import "fact.rsc"; return $result}
Testing:
[admin@bkeniko] > :put [$fact 3]
Script file loaded and executed successfully
6
[admin@bkeniko] >
Is there any documentation on this?
(tested on v6.40.8 )
SiB
Fri Sep 13, 2019 12:40 pm
Is there any documentation on this? (tested on v6.40.8 )
I think it's new, I cannot see about passing variable by global function.to /import feature. This is like recursion . Works in 6.45.3
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL | WebChat: Tokonda
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
Users browsing this forum: No registered users and 9 guests
