MUM Europe 2020
trizcocho
Pentium quad core
Sat Apr 19, 2008 11:25 am
Hello all... sorry for my english
I have a P IV 3200 Mhz witch routeros 2.9.51 level 4, in firewall conection say max entries 2.027.520 ,and i have a new router P IV quad core 2400*4 witch routeros 3.6 level 6 and firewall conection max entries say 524.288.
I put support for multiprocessor in 3.6, and resources say cpu count 4, 2400Mhz
is this normal ?
best regards.
sergejs
Re: Pentium quad core
Wed Apr 23, 2008 3:25 pm
Connection tracking number depends on RAM capacity, not CPU.
Cyra-Orin
Thu Apr 24, 2008 5:00 pm
Should we used conntrack ? Is these conntrack had an issue even on Linux ??
Rgds,
~Lst
sergejs
Fri Apr 25, 2008 8:29 am
Connection Tracking should be enabled, when you have firewall rules [filter, NAT, mangle].
Do you have any problems with that ?
trizcocho
Fri Apr 25, 2008 11:05 am
Dear Sergejs, look this images, i don´t understand
sergejs
Fri Apr 25, 2008 11:51 am
I suggest you to run 3.7 version on both routers, then compare value.
In case there are any similar problems, contact MikroTik support [support@mikrotik.com].
mangust
Fri Apr 25, 2008 2:56 pm
It's 100% bug. Not sure how many conntracks are supported , but the number really depend of amount of RAM.
In MT case it' s always (I have it starting from 3.3) "Max Entries: 524288" in case if RAM equal or more then 512 MB.
In real life 512MB = 524288KB, exactly what we have.
If we are talking about max contrack then it should be 65536 in case if you have 1Gb and something around 131072 in case of 2G RAM
Like example Linux with 1G Ram show:
ip_conntrack version 2.4 (8192 buckets, 65536 max)
hulk-bd
Mon Apr 28, 2008 12:05 am
No matter how much RAM u have it always shows that max entries: 524288 in ver 3.X. I'm using 3.7 with 1 GB RAM and it's showing the exact max entries.
Don't worry, be happy :) .......
Cyra-Orin
Mon Apr 28, 2008 12:03 pm
I don't think so...
mangust
Mon Apr 28, 2008 1:30 pm
I don't think so...
Looks like this is starting from 3.3.
The question is Does Max Entry mean Max Contrack or it’s just show amount of memory?
Because if Max Entry mean memory , then we have bug that do not show memory more then 512 M (once again 524288 (kb) equal 512M ), But if Max Entry mean Max Contrack then we have completely wrong information.
However I think this is just informational bug , and hope somebody from MT already fix it.
Users browsing this forum: dirman, jabberd, zandhaas and 163 guests
