LinuxLoader
FreeRadius+Mikrotik+Option 82
Fri May 16, 2008 11:09 am
The idea is to use Mikrotik to asign ip addresses only when mac is just on specifik port on the network device. The siwtches will do the rest . In other way said is , dhcp snooping + ip source guard and ip arp inspection to be linked with mikrotik and freeradius
rnbguy
Re: FreeRadius+Mikrotik+Option 82
Fri Apr 10, 2009 2:19 pm
any luck with option 82?
Chupaka
Fri Apr 10, 2009 3:17 pm
not with FreeRadius, but - we use it =)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
nik247
Fri Aug 14, 2009 9:52 pm
To Chupaka: Can you share this configuration?
Chupaka
Fri Aug 14, 2009 11:28 pm
I use my own RADIUS for DHCP - it's linked to our user database
written in Delphi7 =)
shade
Wed Jan 26, 2011 4:22 pm
which attributes DHCP-server sends to RADIUS?
which attributes DHCP-server accept from RADIUS?
May you give dictionary?
Нерешаемых проблем нет — есть проблемы, которые никто не решает
martini
Thu Jan 27, 2011 10:59 am
working without problem with freeradius and option82, but need some triggers in mysql to convert asci and other binary characters.
butche
Trainer
Trainer
Thu Jan 27, 2011 8:43 pm
So you have a RouterOS DHCP relay sending option82? I'd be interested to see that config (on the MT side).
Butch Evans
Mikrotik Certified Trainer
Mikrotik Certified Consultant
BLOG: blog.butchevans.com
http://store.wispgear.net/
iDen
Mon Jan 31, 2011 11:44 am
i have Mikrotik+option 82+freeradius+dhcp snooping working fine, (+ arp inspection and ip source guard).
the same problem with characters in Remote Agent/Circuit ID.
i think problem is in libpcap, but cant test it right now (lazy) waiting for new centos.
but other radius on perl RADIATOR can see everything as it should be without unknown characters.
dictionary for radius is RedBack used for MT agent/circuit id
MTCNA
omidkosari
Trainer
Trainer
Tue Feb 01, 2011 9:58 am
I have filled a long time feature request to implement Option 82 for PPPoE server and it confirmed by mikrotik staff . but no news yet . it is very useful .
the feature request located at http://wiki.mikrotik.com/wiki/MikroTik_ ... e_Requests just search for "PPPoE Options just like DHCP Options" to find it .
To staff : this feature is a must for big ISPs based on pppoe .
Chupaka
Wed Feb 09, 2011 1:33 am
not Relay, but DHCP Server sending Option82 to RADIUS. no special config, simple RADIUS settings - Redback-Agent-Remote-Id and Redback-Agent-Circuit-Id attributes will be sent automatically
Freddyx
Mon Feb 14, 2011 3:20 pm
the install from university ICEL on Chilean
freeradius+daloradius+CentOS 5.5 > Mikrotik Hotspot Is very Good
Howto install on Centos
http://infodotnet.blogspot.com/2007/11/ ... adius.html
Freddy Rodriguez S.
RHCT Certified Technican
CCNA 1 Certified
frodriguezsaez@yahoo.com
Users browsing this forum: No registered users and 121 guests
