daveleger
RB150 v3.9 100% CPU
Fri May 16, 2008 4:13 pm
I have a miniRouter with basic firewall setup and PPPOE client configured to connected to the internet. ether2-5 are bridged together. Just about no traffic on the router, however I am at 100% CPU all the time. Not just a spike!
The router seams to be working properly. No slow down, etc. But I have little traffic on it.
I have the following firmware:
[admin@MikroTik] > /sys rou print
       routerboard: yes
             model: "miniROUTER"
     serial-number: "10CF01CF0A82"
  current-firmware: "2.9"
  upgrade-firmware: "2.14"
[admin@MikroTik] >
I am wondering if I should downgrade to v3.7?
Any ideas?
Thanks,
Dave Leger
jwcn
Re: RB150 v3.9 100% CPU
Fri May 16, 2008 4:53 pm
If you are seeing no other indication of 100% cpu utilization I would say it isn't accurate.
daveleger
Fri May 16, 2008 5:08 pm
I would agree, but how can I properly monitor the CPU is I don't have an accurate reading?
Should I upgrade the firmware?
Or Should I downgrade the OS?
Thanks,
Dave
Schnulch
Fri May 16, 2008 5:11 pm
Perhaps you should do a "system routerboard upgrade" and reboot.
daveleger
Re: RB150 v3.9 100% CPU [resolved]
Tue May 20, 2008 5:44 pm
Upgrading the firmware from 2.9 to 2.14 did the trick. It is no longer showing 100% CPU load.
I don't believe the CPU was actually at 100%, rather is was showing it as being at 100%.
Thanks,
Dave Leger
Users browsing this forum: No registered users and 137 guests
