Ejcej
Doesn't work script
Mon May 19, 2008 7:56 pm
This script doesn't work in mikrotik V3. Tested in 3,7 and 3,9 version. It is BUG?
/queue simple
set [find queue=wireless-default/wireless-default] disable=yes
Giepie
Re: Doesn't work script
Sun Jul 06, 2008 4:40 pm
Hi
I tried this which worked:
set [find name="queue1"] disabled=no
Then I tried this which didn't work:
set [find queue=default-small/default-small ] disabled=yes
It could be a bug...
I used ROS 3.10
The only thing Mikrotik lack, is to send power to your High Sites wirelessly.....
mrz
Mon Jul 07, 2008 10:47 am
It is not a bug.
/queue simple
set [find queue="wireless-default/wireless-default"] disable=yes
janisk
Mon Jul 07, 2008 11:07 am
in other words - use quotation
Users browsing this forum: Bing [Bot] and 37 guests
