foffa
blocking some websites how to
Fri Jun 06, 2008 10:10 pm
i am using hotspot
how to block smoe websites from being opend ?????
also how to loog all webpages opend by users if possible i can make that work with proxy
but how with hotspot ?
boyke
Re: blocking some websites how to
Sat Jun 07, 2008 2:22 am
first, find out what ip address (the website that you want to blok), using "TORCH", and put ip on firewall filter, drop forward action for this ip address. :D
mushmx
Sat Jun 07, 2008 6:59 am
Use the hotspot with webproxy, first enable the proxy and after in the NAT section put the next rule to redirect all TCP Traffic from port 80 to 8080 "webproxy"
/ ip firewall nat
add chain=dstnat protocol=tcp dst-port=80 action=redirect to-port=8080
Something very import is select the option TRANSPARENT PROXY into the user profile hotspot. Finally add the rule to block the website into the webproxy section.
Users browsing this forum: No registered users and 112 guests
