mag
telnet, ssh to RouterOS 3.10 from MacOS X 10.5.3
Fri Jun 13, 2008 1:31 pm
After upgrading the Mikrotik OS to 3.10 and MacOS to 10.5.3 (i don't know wchich one caused the change) the build in terminal is no longer working correctly. All output is in one line and unreadable. I tried to change some parameters in the MacOS X terminal but didn't have success.
Has anyone solved this problem, or found parameters to change within Router OS?
TIA
normis
Re: telnet, ssh to RouterOS 3.10 from MacOS X 10.5.3
Fri Jun 13, 2008 2:08 pm
the trick to make this work, is to resize the terminal window to be a little bigger (after connecting). this issue is there for a while already since v3. it's a mac issue.
mag
Fri Jun 13, 2008 2:36 pm
arghh! thx - you saved my life, at least ;-)
Users browsing this forum: Ahrefs [Bot] and 11 guests
