lagosta
Chains
Mon Jul 07, 2008 7:57 pm
Is it possible to create a chain with a wanted name?
I can't seem to find any of this documentation, in the manual says that it is possible, but it doesn't say how.
andrewluck
Forum Veteran
Forum Veteran
Re: Chains
Mon Jul 07, 2008 11:16 pm
Just specify the new chain name when you create the new rule.
Kind regards
Andrew
lagosta
Re: Chains
Tue Jul 08, 2008 7:54 pm
Ok, when i use the Filter-Id tag on the RADIUS server I supose that the MT would recognise this tag and create a dynamic chain, so i could control the trafic from diferent types of users.
Filter-Id:
firewall filter chain name. It is used to make dynamic firewall rule that will jump to specified chain, if a packet is came to or from the client. Firewall chain name can have suffix .in or .out, that will install rule only for incoming or outgoing traffic. Multiple filter-id can be provided, but only last ones for incoming and outgoing is used
(From the MT 2.7 manual)
I can do this with an hotspot, but with 802.1x authentication the dynamic chain is not created.
Does the MT implement this?
How?
Users browsing this forum: Baidu [Spider], Google [Bot], Kindis and 212 guests
