MUM Europe 2020
rednetwifi
Port 80 redirect to standalone Squid Proxy server
Wed Jul 09, 2008 12:31 pm
Please can some one give me a bit of info.. I have looked at this link
http://www.mikrotik.com/testdocs/ros/2. ... bproxy.php and confused the hell out of me.. :? :? :?
And i am well still confused.. We run a 2.6 Squid server on a standalone machine. I dont want the ROUTEROS to handle the cache, all i want is it to forward all the webpage requests to the SQUID Server.
Ok this is our network layout
192.168.0.x/24 Customers -----> 192.168.0.251 (RouterOS Gatway) ----> 192.168.0.2 DNS Server -----> 192.168.0.4 --- Squid Server ----> 192.168.0.1 Internet Modem
Here is my config so far:
# ADDRESS NETWORK BROADCAST INTERFACE
0 ;;; local Lan
192.168.0.251/24 192.168.0.0 192.168.0.255 ether1
1 ;;; WAN
192.168.9.100/24 192.168.9.0 192.168.9.255 ether2
0 chain=srcnat action=masquerade
# DST-ADDRESS PREF-SRC G GATEWAY DISTANCE IN..
0 A S 0.0.0.0/0 r 192.168.9.1 1 et..
1 ADC 192.168.0.0/24 192.168.0.251 0 et..
2 ADC 192.168.9.0/24 192.168.9.100 0 et..
So do i need to add a route or use the ROUTEROS Proxy and point and a parent proxy.
I WILL UNDERSTAND THIS ONE DAY! :shock: If anyone can point me in the right direction to a simple way to configure this, as i am very new to ROUTEROS and SQUID so its a learning curve.
Then all i have to get working is NLB and failover..... then all done, PROJECT FINISHED!!!!! I have to say i would not have got this far with out this forum!! THANK YOU ALL!!!!!
Hope you can help...
Regards
D
Darren Eley
normis
Re: Port 80 redirect to standalone Squid Proxy server
Wed Jul 09, 2008 3:05 pm
what exactly was confising there? it's as simple as it gets. two steps:
1. set parent proxy in proxy settings
2. enable proxy
rednetwifi
Wed Jul 09, 2008 3:07 pm
oh i think i have been confusing myself more than anything... Will give it a try.
Darren Eley
rednetwifi
Wed Jul 09, 2008 3:11 pm
I need to install the package, do i need to reinstall the whole lot? I am running on a demo version to get setup then going to buy the licence.
Can i get the package when using a demo?
Darren Eley
normis
Wed Jul 09, 2008 3:18 pm
webproxy is not working in the demo version. you can try it only in the key-less 24h version.
another approach would be to not use any webproxy on the RouterOS, but just make a DST-NAT rule with action DST-NAT to redirect all TCP:80 traffic to your Squid
rednetwifi
Wed Jul 09, 2008 3:24 pm
ip firewall
dst-nat protocol=tcp dst-port=80 Action dst-nat to-address=192.168.0.4 to-ports=3128
Would that be correct then?
Darren Eley
normis
Wed Jul 09, 2008 3:34 pm
looks correct to me
rednetwifi
Wed Jul 09, 2008 3:39 pm
ok, that seems to be working, now i have a problem with squid i think. I get this error.. :(
ERROR
The requested URL could not be retrieved
While trying to process the request:
GET / HTTP/1.1
Host: http://www.google.co.uk
User-Agent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-GB; rv:1.8.1.15) Gecko/20080623 Firefox/2.0.0.15
Accept: text/xml,application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
Accept-Language: en-gb,en;q=0.5
Accept-Encoding: gzip,deflate
Accept-Charset: ISO-8859-1,utf-8;q=0.7,*;q=0.7
Keep-Alive: 300
Connection: keep-alive
Cookie: PREF=ID=111371bc4a18835c:TM=1211629667:LM=1211629667:S=TmP82Z5GPKJkLUT-; NID=12=chy9FDypusRC8gb7w7ZNlHqolb-YF7JDgYz-4P5Pjsn8u1Rbj3Owo95IdtuA3TWM8MoVAAlY3TZ8qI1NQt0DKW9k9N3Nc1HPOHZhzYSl-vQfWt4hIWadJmFKkbN00i-y; S=photos_html=Hux7A7CkRziZm-EnpvUdyw
The following error was encountered:
* Invalid Request
Some aspect of the HTTP Request is invalid. Possible problems:
* Missing or unknown request method
* Missing URL
* Missing HTTP Identifier (HTTP/1.0)
* Request is too large
* Content-Length missing for POST or PUT requests
* Illegal character in hostname; underscores are not allowed
Your cache administrator is webmaster.
Darren Eley
normis
Wed Jul 09, 2008 3:47 pm
maybe try searching this forum? I see a lot of similar issues:
http://forum.mikrotik.com/viewtopic.php ... xy#p101456
(there is some solution also)
Equis
Forum Veteran
Forum Veteran
Thu Jul 10, 2008 1:00 am
Do some google of setting your squid to be transparent proxy.
I think this will fix that error
rednetwifi
Thu Jul 10, 2008 10:56 am
Once again thanks to the Forum i was able to get squid now working correctly as a Transparent Cache.
Now got to work on failover just in case it stops working. If anyone is having problems configuring squid, please email me and i will send you my squid.conf setup with the RouterOS Config so you can setup like it did...
OK now failover
Darren Eley
Users browsing this forum: techlord and 49 guests
