MUM Europe 2020
el berto
Upgrade ROS: just a doubt
Tue Jul 15, 2008 4:20 pm
Hi, I would like to upgrade my OS on RB333: if I've correctly understood, I go on the RouterOS download page.
Here there are these coices:
RouterOS 3.11
* All files (requires a Torrent client)
* Combined package (http)
* All packages (Includes optional packages: view content)
* Routing beta package (http)
* MPLS beta package (http)
* RouterOS 3.11 Changelog
The correct download is Combined package, right?
Then I upload it on the routerboard and reboot, right?
If I upload a RouterOS for another RB (for example RB112), may I recover anyway the board?
Thanks.
normis
Re: Upgrade ROS: just a doubt
Tue Jul 15, 2008 4:26 pm
yes correct.
nothing will happen if you use the wrong packages.
el berto
Fri Jul 18, 2008 10:54 am
Uhm....
I've tried tu upgrade ROS 2.9.x to 3.11 on RB112: with the old ROS all was working fine, except a little bug with snmp.
Now, with ROS3.11, when I enter via Winbox (there is a cable connection) I find all windows (wireless tables: interfaces-registration, New Terminal, IP-addresses, as examples) blank, so I have to wait several seconds to see anithing.
What cuold be the problem?
slipstream1
Fri Jul 18, 2008 2:26 pm
Have you upgraded the bootloader? You will see high cpu usage and rb slow downs without bootloader upgrade.
From new terminal, under winbox: system routerboard---->print----->upgrade, after accepting upgrade you will need to reboot the routerboard for the upgrade to be complete.
el berto
Fri Jul 18, 2008 2:45 pm
Don't worry, I made the upgrade, then reboot, yesterday. Since yesterday I've rebooted several times.
Users browsing this forum: No registered users and 26 guests
