MUM Europe 2020
munsell
Connecting router to User Manager (radius server)
Mon Aug 04, 2008 7:52 pm
We have a radius server set up with user manager and we are trying to add a routeros router with hotspot setup to our radius server. The router is added onto the web interface for the radius, however we are unable to get the router talking to the radius server. How is this done?
Thanks,
Munsell
skye1
Re: Connecting router to User Manager (radius server)
Mon Aug 04, 2008 11:32 pm
This link should help. You set the ip and secret for your usermanager on the client system.
http://www.mikrotik.com/testdocs/ros/2. ... radius.php
munsell
Mon Aug 04, 2008 11:50 pm
Thanks for the link but we already went through all that and it was quite unhelpful.
sergejs
Mon Aug 18, 2008 9:51 am
You need to go through the following steps;
- information about router at 'Routers' on the User Manager;
- User Manager/RADIUS server should be added in 'radius print' configuration on the MikroTik Router;
- Force HotSpot to use radius, ip hotspot profile use-radius=yes
Additionally if you have User Manager and HotSpot on the same router, then use 127.0.0.1 address,
http://wiki.mikrotik.com/wiki/User_Mana ... ame_router
micha94
Mon Aug 18, 2008 12:14 pm
I had exactly the same problems, but since I entered 127.0.0.1 as RADIUS-Server it works now.
Users browsing this forum: MSN [Bot] and 3 guests
