ivanperino
Dude + CompactFlash + RB1000
Tue Sep 02, 2008 5:55 pm
Dear Genius:
I need to perform dude server on RB1000 but a problem has arisen. HDD space is not enough!
I´ve installed a 4GB CompactFlash 4x into the external CompactFlash slots in RB1000 and it has been detected and formated by WebProxy but what I really need is to use that memory card with Dude Server.
How can I do it? CompactFlash memory added does not appear in >system resourses print
Moreover, when I try to add an image (on the dude background for example), the file is transferred to the HDD memory making the HDD Free space smaller.
I cant find the new memory installed. However, RB1000 Brochure says that WebProxy, UserManager backups and Dude Server can use memory card.
If someone enjoys answering to me, THANK YOU!
Ivan Perino
sergejs
Re: Dude + CompactFlash + RB1000
Wed Sep 03, 2008 12:19 pm
Currently you cannot run Dude server on Compact Flash with RB1000, but we are working on it.
AdinaNet
Tue Sep 09, 2008 5:49 pm
I hate to ask, but is there an ETA for this feature? We're needing to move from x86 machines to more "appliance" oriented hardware, ASAP.
Thanks!
Taylor
sergejs
Fri Sep 12, 2008 2:01 pm
There are no information about data, when feature will be ready.
tricake
Tue Oct 07, 2008 4:07 pm
Will it make into 3.0 final?
sdrenner
Thu Oct 23, 2008 8:30 pm
Boss just ordered me an RB1000 to use for our office router/firewall and to put dude on.
When will we be able to use CF for the Dude??
sdrenner
Tue Oct 28, 2008 4:26 pm
Does anybody know?
joshelhoff
Tue Oct 28, 2008 9:46 pm
Can this be done now?
sergejs
Wed Oct 29, 2008 4:01 pm
Currently there is support for User Manager and other data storage by '/store', in the future the same option will be available for the Dude.
sdrenner
Wed Oct 29, 2008 4:10 pm
ETA?
or
When?
remotelylocated
Sun Nov 30, 2008 2:16 am
Is the Future Here Yet?????
normis
Mon Dec 01, 2008 9:34 am
right now Store can be used for User Manager and Webproxy, Dude support will be added soon
sdrenner
Fri Apr 03, 2009 6:41 pm
Any update as to when? It's been what 4 - 5 months since you said soon.
andreacoppini
Trainer
Trainer
Sat Apr 04, 2009 12:27 am
Try upgrading to v.3.22
I just did exactly this a few days ago.. Works brilliantly. In fact, At first I installed Dude on the internal storage (NAND), but this caused the sector writes to shoot up by 12,000,000 every day (yes, 12 MILLION)... which can't be good for the NAND. I stuck in a CF card and moved it to it from the Stores window.
sdrenner
Tue Apr 07, 2009 12:29 am
So you are running dude on your rb1000 and the CF?
andreacoppini
Trainer
Trainer
Tue Apr 07, 2009 2:39 am
Yes, I am (was) doing just that. RB1000 doing hotspot, NAT and queues, running Dude with the store on a 512Mb CF, and Web-proxy also on the same CF.
This was only a temporary setup for a couple of days, but it worked fine for as long as it was running.
sdrenner
Wed May 27, 2009 6:48 pm
Soon! This was last said back in December.
Any ETA on soon?
sergejs
Thu May 28, 2009 12:03 pm
Dude support for store was added long time ago,
/store> print
Flags: X - disabled, A - active
 #   NAME                   TYPE                 DISK                 STATUS
 0 A dude1                  dude                 micro-sd             active
 1   web-proxy1             web-proxy            system               backup
 2   dude2                  dude                 system               backup
andreacoppini
Trainer
Trainer
Thu May 28, 2009 12:49 pm
and I can confirm that... been using it that way for a while now.
some people need to learn how to use the scroll bar
sdrenner
Thu May 28, 2009 3:47 pm
K, thanks
uumar
Tue Jan 05, 2010 7:21 pm
how do i store webproxy cache contents and usermanager database in the comact flash on my rb1000?
sergejs
Thu Jan 07, 2010 11:30 am
You can add second store to the same disk.
sdrenner
Fri Mar 19, 2010 10:33 pm
Hey upgrade quesiton?
I installed dude on my rb1000 long time ago.
I just can't remember how I did it. And now i would like to upgrade to 3.5
Can someone give me some steps to upgrade?
sergejs
Mon Mar 22, 2010 4:29 pm
Upload Dude package to FTP and reboot the router, it should be saved as correct store.
sdrenner
Mon Mar 22, 2010 4:36 pm
into the CF?
sergejs
Tue Mar 23, 2010 10:20 am
No, you should upload it to root directory in /files.
The same place where you upload packages to upgrade the router.
